Daylight saving problem
Submitted: Friday, Dec 08, 2006 at 15:14
Dave Thomson
Hi All,
anyone know how to set the clock on the computer so that it reads the right time when you switch it back on again the next day ? tried all the buttons to synchronise it but it just keeps going back to the original setting, probably because it's been set at 8 H's GMT and it cant cope with a change, we're in
Perth,W.A.
thanks in advance,
Reply By: Member -Signman - Friday, Dec 08, 2006 at 15:18
Could you set it to +9hrs GMT ????
209300
Reply By: equinox - Friday, Dec 08, 2006 at 15:22
Try setting it your BIOS when the PC starts up.
Usually hold down F6 or Delete upon start up then set the clock from in there.
And remember to vote no!!!!
209303
Reply By: XpLoiT - Friday, Dec 08, 2006 at 15:28
reason why is cause of the microsoft patch to update
perth to daylight savings time.
i suggest going to www.microsoft.com and looking at this
support.microsoft.com/kb/304303
hope this helps
dave
The
Grey Nomads
209305
Reply By: Gerhardp1 - Friday, Dec 08, 2006 at 15:29
Because WA is backward with respect to D/S, Windows PCs don't know that it has now moved out of the dark ages.
Microsoft may have released a patch for this, but you can set the clock in Control Panel, Date & Time, Time Zone, and turn OFF the auto adjust for D/S checkbox.
Also turn off the Internet time update in the next tab as
well. Set the time to what you want and it won't change again. You can then manually change it back when D/S ends.
Not too onerous with only a couple of mouse clicks.
209306
Reply By: Steve63 - Friday, Dec 08, 2006 at 15:36
You have not really given enough info. Usually if you change a standalone pc's time it will stay put. If you are on a network or use one of the online time correction programs it will check with a server for the time and make the required adjustments. This is OK as long as the server has the correct time and the regional settings allow for daylight savings. (If adjust for daylight saving is not checked in date/time Time zone then check it and try again). I assume you have applied the patch from microsoft for daylight saving in WA see Site Link. If this fails try altering the BIOS time.
Steve
209308
Reply By: Trevor R (QLD) - Friday, Dec 08, 2006 at 16:05
Move to QLD and you won't have to change the clock T-I-C. hehehe
Trevor.
Ooopps sorry, they just put the "full house"
sign up, everyone else beat you to it.
209315
Follow Up By: Member - Traveller (QLD) - Friday, Dec 08, 2006 at 18:13
Spot on Trevor! They sure get their knickers in a knot over this clock changin'!
469312
Reply By: Member - Phantom (WA) - Friday, Dec 08, 2006 at 17:54
I don't think that you have a full explanation yet so I'll try.
If you double click on the time in the bottom right hand corner, the pop up wil have three tabs. Open the rh one and unclick internet time. Then click the cntre tab and change it to Tokyo time (GMT +9.00). then close the box and it should be perfect.
209346
Reply By: Ray Bates - Friday, Dec 08, 2006 at 18:00
Try setting you clock to Osaka time
209348
Follow Up By: howie - Friday, Dec 08, 2006 at 22:23
i'm a seoul man myself.
go the d/s, it's 20:22 and still light outside.
469364
Reply By: ExplorOz Team - David - Friday, Dec 08, 2006 at 23:12
The answer is available here - There are update available for all versions of windows Site Link
209389
Reply By: Dave Thomson - Saturday, Dec 09, 2006 at 16:32
Thank you David, you'll be pleased to know that one did work, but thanks also to all who helped,
regards,
209465
