Radio/cd installation in caravan
Submitted: Sunday, Dec 10, 2006 at 16:21
billv
Probably simple to lots of people, but to install a car type am/fm radio/cd player in a caravan, is it as straightforward as connecting the unit to the van's 12v power; connecting a pair of speakers and connecting the aerial? Or am I missing something. I was intending to build a shelf to take the unit including speakers and substituting it for the inadequate 240v am/fm radio fitted to the van from new.
I'm happy to be told I am an idiat for not knowing. Thanks.
Reply By: kimprado - Sunday, Dec 10, 2006 at 16:32
Billv
Nobody is an idiot on this site until they prove it.
Good luck with the installation.
Kim
209610
Reply By: Member - Barry M (NSW) - Sunday, Dec 10, 2006 at 16:37
Sounds like you have it sorted already. Be sure to include a fuse in the power supply line & earth the unit as
well..good luck with it...oldbaz.
209612
Reply By: billv - Sunday, Dec 10, 2006 at 16:44
No, barry, I haven't had a reply yet except to tell me that I need to prove I'm an idiot before anyone believes me. Perhaps because I spelt the word idiat instead of idiot gives me a start.
209613
Reply By: Mr Fawlty - Sunday, Dec 10, 2006 at 17:59
Yep It's as simple as you say...I actually went for a car radio, cd & dvd player combo. I also used an automatic power aerial that I put inside a space that was available, this saves having to actually put up the aerial and also lets me forget about having to put it down. I was also able to rout the speaker cabling through cupboards & secured the speakers to the underside to make the installation look professional. I bought a 3 outlet RCA block for the video leads so that I just plug them into the TV for video. It took me a day or so to do the job but most of the time spent was working out the fine detail. The most important thing is to make sure everything is secure.
I was lucky I had a void over the stove to cut out to mount the box in etc. If you give me your email I can send you some pics.
209622
Follow Up By: disco1942 - Sunday, Dec 10, 2006 at 23:59
All car aerials leak
water - particularly the power ones. If it is mounted within the body of the van provide it with a drain to the outside.
469711
Reply By: Ozrover - Sunday, Dec 10, 2006 at 20:01
billv.
Yep, It's no harder than installing one in your car, if anything it may be easier. (no computers to stuff up) 8 )>
I just replaced the old cassette tape player in the camper with a MP3/CD/radio unit, the only difference that I found was that I had to install a switch to mimic an accessories power line from the ignition switch, as
well as a power supply from the battery.
For an aerial I used an old CB coax lead with a screw on aerial.
Made sure that everything is nice and tight, so hopefully it won't rattle itself to death.
209636
Reply By: Mikee5 (QLD) - Sunday, Dec 10, 2006 at 20:26
Billv,
These units need 2 types of power, 1 is permanent on to keep station memory/preferences alive, 2 is the on/off usually wired to Acc in the car. In my van they did not include 1 above (or hooked them both together) so each time I switch off the van for travel or storage the stupid radio forgets everything. I plan to hook up a permanent on wire soon. This will result in a small battery drain so this too will need an on/off switch to stop this drain during long term storage.
Mike.
209643
Follow Up By: disco1942 - Sunday, Dec 10, 2006 at 23:55
Mike
You are probably better off installing a large switch in the load line near the battery. This will take care of all phantom loads - however make sure it does not prevent any charging devices you use to charge the battery when it is in storage
469710
Reply By: billv - Sunday, Dec 24, 2006 at 17:06
Excuse my rudeness, but I omitted to thank all who gave me helpful suggestions. Many thanks and greetings for Christmas
211915
