Hilux door chime-very annoying
Submitted: Sunday, Dec 10, 2006 at 22:34
ThreadID: 40242 Views:15748 Replies:4 FollowUps:6
Hi folks,
Many months ago I read a post about disabling the chimes that occur when a 2005 lux door is open and the key is in the ignition. Somehow a code can be entered which stops the annoying beeps.
Did a search but unable to locate it. Can anyone help please.
Paul
PS. please excuse my lack of acknowledgements to any answers submitted tonight.........I'm off to bed.
Reply By: Erwin - Monday, Dec 11, 2006 at 05:53
Paul
Try post 35462
AnswerID: 209690
Follow Up By: Member - Paul S (VIC) - Monday, Dec 11, 2006 at 06:43
Thanks Erwin, quite a lot of info there.
Appears to be more about seat belt alarm rather than ignition key, will try it later.
Appreciate your response.
Paul
FollowupID: 469720
Follow Up By: Member - Paul S (VIC) - Monday, Dec 11, 2006 at 06:46
Correction:
Appears to be more about seat belt alarm rather than ignition key/door alarm.
Paul
FollowupID: 469722
Reply By: John R (SA) - Monday, Dec 11, 2006 at 07:35
Paul, sing out if you have any more questions. I'm not aware of any codes, but I've pulled a couple of plugs and retained my sanity.
AnswerID: 209697
Follow Up By: Member - Paul S (VIC) - Monday, Dec 11, 2006 at 07:47
Thanks John,
I'm a bit reluctant to pull plugs as I don't want to lose the alarm altogether; is helpful to be reminded the lights are on etc. before leaving the vehicle.
Will try disabling through codes first.
Thanks,
Paul
FollowupID: 469725
Follow Up By: John R (SA) - Monday, Dec 11, 2006 at 10:20
Pulling the plugs under the seat and from the ignition bolt only stops the chiming if you don't have your seatbelt on, or you leave the key in the ignition and open the door.
By all means go the code route. I was unaware that you could do this - my dealer only told me to pull the plugs. They seemed genuinely unaware of any codes. Maybe the CFA bloke has a better hotline to Toyota!!
FollowupID: 469751
Reply By: Col_and_Jan - Monday, Dec 11, 2006 at 08:19
There was a fellow on the forums.overlander.com.au site who helped with this code. It was to help the CFA guys, who got really annoyed with the chimes. He didnt post the code on the site, but helped via pm. That site is down at the moment, but when it is on-line, just do a search.
Col
AnswerID: 209702
Follow Up By: Member - Paul S (VIC) - Monday, Dec 11, 2006 at 10:03
Thanks Col, I will check that.
Paul
FollowupID: 469747
Reply By: newlux - Monday, Dec 11, 2006 at 10:55
Check out www.newhilux.net there is info on the forum there to get rid of the seat belt buzzer and the key in ignition buzzer, and they do work, I have stopped these buzzers on my lux and life is now much better.
Mick
AnswerID: 209721
Follow Up By: Member - Paul S (VIC) - Monday, Dec 11, 2006 at 12:18
Ta Mick, I'll check that out also
Paul
FollowupID: 469777
