REGULATOR
Submitted: Tuesday, Dec 12, 2006 at 12:09
ThreadID: 40288 Views:3536 Replies:7 FollowUps:9
Where do I connect the consumer connections to from a Steca PR 20A. i have 2 100amp hr AGM batteries in a caravan driving lights, water pump ,17 in LCD ,12volt dvd radio, fridg only when Landcruser is running, no invertor, imput from 25amp hr charger,123watt solar panel,Landcruser
Reply By: Wizard1 - Tuesday, Dec 12, 2006 at 12:20
I google Steca and up came Solar Panel Australia why not give them a call as I assume they would experts in the field of solar...I'll even give you the website..
www.solarpanelaustralia.com.au
Now how easy was that...give google try next time, you'd be surprised what info you can get.
AnswerID: 209944
Reply By: Merylin - Tuesday, Dec 12, 2006 at 12:44
Thanks. Been googling everyone, but they really don't want or can't give me an answer - distributerjust said . . . 'we don't connect this facility'.
Ted
AnswerID: 209948
Reply By: porl - Tuesday, Dec 12, 2006 at 13:05
Can't quite picture what you mean but my steca 15A is pretty straightforward. From memory it has positive and negative holes to screw in from your solar panel, clearly marked "Input" and the same marked "output". So the solar panel's positive lead goes in the Steca "Input" positive hole and its negative lead goes in teh negative marked hole you screw them tight. The "Output" leads go to your battery terminals.
Hope that makes sense.
AnswerID: 209950
Follow Up By: Wizard1 - Tuesday, Dec 12, 2006 at 13:18
After re-reading the post I'm a little confused at what is actually connected to the regulator. I was led to beleive that the regulator fed power to the battery/s then you run all your "stuff" off the battery/s.
FollowupID: 469976
Follow Up By: porl - Tuesday, Dec 12, 2006 at 13:21
yeah, that was my take too, not sure what was meant by "where do i plug the consumer stuff" - all that stuff is connected direct to the battery.
FollowupID: 469978
Follow Up By: Merylin - Tuesday, Dec 12, 2006 at 19:16
Steca input output OK its connected up and working but its the third connection which shows load from Caravan lights pump etc also auto cutout when batteries low its a Steca 20 amps but I dont think this matters Ted
FollowupID: 470036
Reply By: Alloy c/t - Tuesday, Dec 12, 2006 at 20:31
Steca has 3 terminals , l/hand, + and - is for solar panel imput .... middle terminals +and - go to battery .... r/hand terminals + and - generally are connected to a terminal block from which you connect all the power using equipment ie: lights /fridge/tv ect ect , that way the Steca reads input from solar panel and amp "draw" from all items "connected " ,ONE major point is that you cannot connect a charger /generator to the Steca 20 , ,if you want to recharge other than solar you must disconnect the Steca ,otherwise the fault code will become fault "16" , not even in handbook ,tis the code for missuse so NO warranty claim.
AnswerID: 210014
Reply By: techo2oz - Tuesday, Dec 12, 2006 at 21:02
Hi if it is the PR 2020 let me know your email addy and I'll send you the manual for it. From what I can gather there are 6 screw terminals. 2 for solar, 2 for battery and 2 for load (consumer items)
For heavy draw items such as invertors they should be connected directly to the battery.
AnswerID: 210020
Follow Up By: Merylin - Wednesday, Dec 13, 2006 at 07:01
Thanks its a PR20A have the manual, what do I connect the 2 leads from consumer items to,(the manuel says connect to consumer items,not clear to me) first dealer said direct back to battery then no we dont connect then maybe through a shunt HELP
FollowupID: 470085
Reply By: Derek from Affordable Batteries & Radiators - Tuesday, Dec 12, 2006 at 22:06
Hi Merylin
We stock BP Steca products. Try this link...
a href="http://www.stecasolar.com/en/art/uid_kategorien/0000581/id_matchcode/up_solarladeregler/id_artikel/0000092/bop/0/chksum/4fb3b55e8148d5d3226210db61141597/beetools.html">STECA
It is quite simple. Battery in....Solar In....Load Out...
The charger and car charge circuit must NOT go through the reg !
Derek.
AnswerID: 210045
Follow Up By: Derek from Affordable Batteries & Radiators - Tuesday, Dec 12, 2006 at 22:11
Link failed.
I will try again.
STECA
FollowupID: 470066
Follow Up By: Merylin - Thursday, Dec 14, 2006 at 12:08
Derek the Steca is connected to panel and batteries, working OK ,now where do I connect consumer wires to. Merylin
FollowupID: 470319
Follow Up By: Derek from Affordable Batteries & Radiators - Thursday, Dec 14, 2006 at 14:27
Hi Merylin
Connect your load (Lights, Radio, Fridge) to the last 2 connectors. 'LOAD'
Note that your total load must not exceed the amp rating of the regulator.
If you have a inverter or other large load it will need to be connected to the battery and not the regulator. (Note: This will bypass the amps used feature)
Derek.
FollowupID: 470337
Follow Up By: Merylin - Thursday, Dec 14, 2006 at 15:58
So Derek if I disconnect the plus and minus leads that drive frid, lights etc, from the batteries (no regulator)and plug them into the regulator thats it Merylin Where are you?
FollowupID: 470344
Follow Up By: Derek from Affordable Batteries & Radiators - Thursday, Dec 14, 2006 at 18:56
Yes quite right.
FollowupID: 470368
Reply By: disco1942 - Thursday, Dec 14, 2006 at 16:10
The handbook for this regulator can be downloaded from:-
http://tinyurl.com/vf5zj
Take note of the section in page 6 headed "2.3 Grounding" It is important not to
earth more than one of the negative terminals. If you do you will short out one
or more of the current shunts. These current shunts are what the metering in the
unit uses to measure the solar panel and battery currents. Short these out and all current values will be shown as ZERO. The state of charge (SOC) readout will be
useless also as it uses the shunts for its calculations. You can however use these
regulators in a positive earth installation and earth all the +ve terminals (this
is because they were originally designed for telephone installations.)
If you connect anything to the battery like chargers and heavy loads (inverters)
you will upset the SOC readings. Reason - this type of controller measures the
charge and discharge current into and out of the battery through the current
shunt - if you charge or discharge the battery in any way other than through
the controller then its SOC readings are meaningless. The reason that these
very expensive controllers are employed is to be able to measure the SOC
isn't it? If you are going to connect anything directly to the battery then you
may as well use something cheaper like a Morningstar Prostar.
AnswerID: 210337
