Patrol mk vs gq vs gu
Submitted: Friday, Dec 15, 2006 at 09:20
ThreadID: 40368 Views:4143 Replies:5 FollowUps:6
Which one of these sits highest in stock form (including the ute)? Also what difference can I expect in terms of increase in performance (seat of the pants) from a 4.2 gq as compared to a 3.3 mk?
Reply By: Truckster (Vic) - Friday, Dec 15, 2006 at 09:37
sits highest - you mean roof line? or ground clearance?
Also some GQ and GU's are leaf in utes which sit different again.
Performance is a personal thing really, your best bet is to go and drive both...
AnswerID: 210450
Reply By: Leroy - Friday, Dec 15, 2006 at 09:48
a friend reckons his 3.3td pulls better than a latemodel 3.0td and thought the 3.0 should of gone a lot better (we're talking about a 20+ year old motor!) I haven't driven both so can't comment really.
Leroy
AnswerID: 210455
Reply By: Lawrence - Friday, Dec 15, 2006 at 11:31
Seat height
AnswerID: 210470
Follow Up By: Truckster (Vic) - Friday, Dec 15, 2006 at 13:02
so you want to know which has the highest seat height -???
Do you need more leg room, you want to sit high to look at chicks norks in the car next to you/?
Maybe a bit more info on what your looking for/after would help...
FollowupID: 470510
Reply By: Lawrence - Friday, Dec 15, 2006 at 13:16
All of the above. Really interested in off and on road visibility as well as chassis height for ground clearance
AnswerID: 210480
Follow Up By: Truckster (Vic) - Friday, Dec 15, 2006 at 13:31
GO with the GQ.
MK/Q's while not a bad truck are very much long in the tooth and you can expect to spend $ on them.
GQ's very bulletproof, the TD42 probably the best engine in any offroad truck for reliability - no rocket, but will go 600,000 easily if treated properly.
GU - great offroad, I've updated to one now, no regrets, but Im looking at more touring than hardcore this time.
Depends on what offroading your intending to do.
FollowupID: 470513
Follow Up By: Willem - Friday, Dec 15, 2006 at 21:50
Arrr Trucky....yer softening with age.....:-D
FollowupID: 470593
Reply By: Member - Duncs - Friday, Dec 15, 2006 at 22:33
I would have to agree with Trukee.
Having owned examples of all three models I reckon the GQ was the pick
My MQ SD33 was a solid old truck, did most of what I asked of it and was super reliable. It was however slow (The SD in the engine name stands for slow diesel) and uncomfortable. It also had a 24v electrical system which was a nuisance. Not many 24v accessories out there.
I then went to a very heavily midified GQ which was fantastic. Good visibility off road, looking over the bonnet. Fairly compact and easy to know where the edges of the car were. Once again bullet proof 4.2 mine had a turbo so performance was pretty good too.
The Gu I am now driving is a lovelly car. Solid and reliable, far more comfortable than the GQ which was miles better than the MQ. It is still a solid performer off road but it is a bit more difficult to see where it is. Seat height is a bit lower and the bonnet is less square so you can't really see the end of it, bull bar does help here. But it is the same out the back and to some extent down the sides too. Because of the more cureved shape it is just a little harder to knwo where the edges are. It is also a bit heavier and burns a bit more diesel. It is a great touring wagon. In the space of 10 days recently I did a trip to Sydney, for me that is about 26 hours in the drivers seat for the return trip. In a 4 day trip that doesn't leave a lot of time for site seeing. I was then working for 4 days before a trip to Adelaide. Leave home Thursday evening arriving in Adelaide that night. Then left Adelaide Aiport on Friday 5:30pm to drive home (5 hours, and just one wee stop.) The GU was very comfortable for both trips. While I could have done it all in the GQ I would have been in pain. The MQ simply would not have been fast enough to do all of that.
Hope this helps
Duncs
AnswerID: 210570
Follow Up By: Marn - Saturday, Dec 16, 2006 at 00:10
MQ not fast enough?? The old mans MQ turbo would do 160kph plus. How fast do you travel?
FollowupID: 470624
Follow Up By: Truckster (Vic) - Saturday, Dec 16, 2006 at 00:33
you should send it to a museum then.
FollowupID: 470629
Follow Up By: Member - Duncs - Saturday, Dec 16, 2006 at 12:33
Comfortable cruising in hte MQ was about 80 kph if I did not want to listen to the missus I just put my foot down and stayed on 90kph.
Much beyond that the old SD33 just wasn't happy
FollowupID: 470676
