Wheel nut torque (or not)
Submitted: Saturday, Dec 16, 2006 at 16:33
ThreadID: 40404 Views:19520 Replies:12 FollowUps:8
Just got the Cruiser back from the tyre (tire) dealer. Checked the wheel nuts. vary from 70 to 130 ft lbs. I will be talking to him on monday!!!
Reply By: Member - Phil G (SA) - Saturday, Dec 16, 2006 at 17:09
Yep, I always check them too. Mine are the same numbers as yours:
209 Nm (154ftlb)for steel and 131 Nm (96 fltlb) for alloy.
But it must be pretty hard for these guys to keep track of these specs for all the different vehicles - the Prado and 80series wheel nut torque was 113Nm which is a lot different to the fatter studs on the 100series
AnswerID: 210662
Follow Up By: Shaker - Saturday, Dec 16, 2006 at 19:23
It's their responsibilty to keep track of wheel torques, they don't have much else to learn!
FollowupID: 470728
Follow Up By: Mikee5 (QLD) - Saturday, Dec 16, 2006 at 21:27
Thanks Phil,
You are right 154ft lbs, I thought 130 was too tight for my arms and wheelbrace. I will have to get a long bar and socket!!! How could anyone ever get this tight with the bendy tool provided by Toyota?
Mike.
FollowupID: 470734
Follow Up By: Member - Phil G (SA) - Saturday, Dec 16, 2006 at 21:56
Hi Mike,
Yeah, - the specs went up a lot when they upsized the studs to 14mm. My old dodgy Torque wrench doesn't go up to 150 ftlb!! I use some one inch bar to slip over the Toyota brace so they undo easily. Can't imagine how anyone could undo them with a four corner brace. I also smear the threads with a touch of grease even though Toyota tell you not to. But I check them for tightness often enough.
FollowupID: 470738
Follow Up By: Member - Davoe (Nullagine) - Sunday, Dec 17, 2006 at 14:42
wouldnt have a clue what the difference is but I gather never sieze (silver) is recomended but grease is not - dunno why either
FollowupID: 470824
Reply By: cowpat - Saturday, Dec 16, 2006 at 18:47
At least they didn't strip any threads. I've never been back to TyrePower (Bulleen, Victoria) since I picked up the landcruiser and two front wheel studs were stripped. I was told "that sometimes happens on Landcruisers, we don't know why". Casper
AnswerID: 210674
Follow Up By: Luke SA - Sunday, Dec 17, 2006 at 13:18
"that sometimes happens on Landcruisers, we don't know why". Thats not good enough they should've changed them at their expense as it was their fault before you picked up your cruser
Cheers Luke
FollowupID: 470817
Reply By: Tim (vic) - Saturday, Dec 16, 2006 at 18:59
I think it is "set the rattle gun flat out then tighten"
Tim
AnswerID: 210677
Reply By: Member - Ed. C. (QLD) - Saturday, Dec 16, 2006 at 19:13
Personally, I'd be thankful that none of 'em were overtorqued, whereupon I'd then be free to torque 'em up myself to correct specs...
I mean, _everybody_ checks their nuts after a wheel change, right??? (and regularly thereafter, right???)....
I very much prefer the above scenario to one in which the nuts are waay overtorqued (bl@@dy rattle guns!!!) thereby potentially damaging the studs...
I'd definitely be thankin' the bloke.... YMMV;-))
Regards, Ed. C
Confucius say.....
AnswerID: 210681
Follow Up By: Member - Phil G (SA) - Saturday, Dec 16, 2006 at 22:01
Yeah Ed, I'm with you on this one.
Thats a great bit of Desert Pea on your photo. Where did you come across it? We usually find some north of Oodnadatta but saw a fair bit near the atomic bomb site at Emu 2 years ago.
FollowupID: 470739
Follow Up By: Member - Ed. C. (QLD) - Saturday, Dec 16, 2006 at 22:45
G'day Phil,
That one was beside the Gary Junction Rd between Kiwirrkurra & Jupiter Well..
There'd been quite a bit of rain in the area not long before we went through there (May '04), and they were out in profusion, and most of 'em in their prime..
That was the first time I'd been "up close and personal" with such a specimen, and they are indeed a thing of beauty!
Regards, Ed. C
Confucius say.....
FollowupID: 470744
Reply By: T-Ribby - Saturday, Dec 16, 2006 at 20:18
Just ask him for two things, a loan of his rattle gun and the location of
his car in the garage carpark.
T.R.
AnswerID: 210687
Follow Up By: Richard Kovac - Saturday, Dec 16, 2006 at 23:37
Yer sure
HE'S a tyre fitter Doh...
large tattoos and properly rides a Harley..
And any way if some dick asked me for that, I'd tell him were to go.. LOL
FollowupID: 470750
Reply By: Rob from Family First Aid Supplies - Saturday, Dec 16, 2006 at 20:57
you know some times i wonder to take a basic touque rench with me at times as if you rattle up the nuts or break your 4 cornered wheel brace you really don't know if they are too loose or too tight. what is a touque wrench worth compared with the satisfaction knowing that the job is done right!!
ps i have had 16yo in the best places doing up wheel nuts and you belive it is done right. the onus it always on us the drivers!!!
rob 0412041668
AnswerID: 210693
Reply By: Member - Jeff H (QLD) - Sunday, Dec 17, 2006 at 02:24
Not this morning.
This one is too good to lose.
AnswerID: 210739
Reply By: Robin - Sunday, Dec 17, 2006 at 09:22
Hi Mike
I get so I don't let them fit my wheels , good thing about having a few sets
is that when need new tyres I have just dropped in the old wheels, saves leaving the car to.
Don't torque up mine either , just make sure I go round each whel at least a couple of times with wheel brace , but before hand usually make sure the studs are in good shape with a little grease.
Then always go back next day and re-check.
Robin Miller
AnswerID: 210746
Reply By: Sand Man (SA) - Sunday, Dec 17, 2006 at 10:03
My local tyre dealer has a workshop policy of using the rattle gun just to spin them up, but finish off with a hand torque wrench.
What torque? Don't know, don't care.
The fact that I saw them finish of manually was good enough for me.
No chance of stripped threads or snapped studs.
Bill
AnswerID: 210748
Reply By: nowimnumberone - Sunday, Dec 17, 2006 at 12:14
i fitted tyres for about 10 years.
must have tightened 1000000000000000000 wheel nuts.
never used a torque wrench on any one of them
used to tighten with the rattle gun on lowest setting and check by hand.
number of wheels that came loose.
none.
AnswerID: 210762
Reply By: Polaris - Sunday, Dec 17, 2006 at 14:19
After we bought our Hino RB145 bus (coaster size) I attempted to take a wheel off. What a nightmare!
I couldnt move the nuts with a 600mm bar on the factory wheel brace - so tried my 200 ft/lb half inch rattle gun - still no movement.
So took the vehicle to a tyre joint with a much larger compressor and a 3/4 drive 750 ft/lbs rattle gun!
Still couldnt move the nuts.
Ended up moving them with two guys (both over 100Kg) swinging on a 2 meter long piece of pipe on a 1 inch drive socket!
Have no idea why it was necessary to tighten them that tight.
The Owners handbook speifies 174-216 ft/lbs on oiled threads!
Have had instances with our cars and 4x4's where over-zealous tyre fitters have stretched the threads on the wheel studs. Any situation where it is difficult to run the nuts on by hand usually indicates that the stud threads have been stretched. Studs like this should be replaced - they will break at the most difficult time!
AnswerID: 210778
Reply By: Shaker - Sunday, Dec 17, 2006 at 14:27
Wheel nuts/studs have a tightening sequence & torque setting the same as a cylinder head.
The difference is that if a cylinder head fails, it won't kill you, losing a wheel may well!
AnswerID: 210779
