High Temp glue
Submitted: Monday, Dec 18, 2006 at 16:39
Grumpy in WA
Can anyone recommend some high temp glue to glue back the seal on our oven? I know its a bit off topic but I am sure many of you know some products that could help. That staff at the local bunnings (if you can find them) are all 15 and too busy chatting each other up to be of any help.
Thanks in advance.
Reply By: luch - Monday, Dec 18, 2006 at 16:46
Hi Grumpy
try the selleys website
Site Link
211008
Follow Up By: Grumpy in WA - Monday, Dec 18, 2006 at 16:47
Thanks for that. I'll go and have a look now...
471048
Reply By: _gmd_pps - Monday, Dec 18, 2006 at 16:53
3m Weatherstrip Adhesive - Black .. works
well
but also on the fingers :)) any auto
shop should know it
gmd
211009
Reply By: 666toy - Monday, Dec 18, 2006 at 17:13
Good old silicon will do the trick silastic clear works
well in high temp applications
211017
Follow Up By: luch - Monday, Dec 18, 2006 at 19:48
You need to be carefull with silocon as it gives off nasty fumes ect during the curing process, but yes it works
well up to 250 deg c (automotive type)
471085
Follow Up By: hoyks - Tuesday, Dec 19, 2006 at 21:31
Some silicone sealants also release formaldehyde when they get hot.
Formaldehyde is very bad for you and I think it makes the biscuits taste funny too.
471305
Reply By: Member - Mike_L (SA) - Monday, Dec 18, 2006 at 20:07
Or try the Loctite catalogue....
Site Link
Mick.
211068
Reply By: Member - Phil G (SA) - Monday, Dec 18, 2006 at 20:31
Not sure of the right answer, but superglues, contact adhesive, and normal silicon won't stand the heat, and all have some toxic fumes.
My suggestion is Sikaflex adhesive, as it is flexible, adheres strongly to anything, and is not toxic. Its a polyurethane adhesive.
211078
Follow Up By: Member - Phil G (SA) - Monday, Dec 18, 2006 at 20:32
And forgot to add, is there any chance you can reattach it with some self-tappers?
471095
Follow Up By: 666toy - Monday, Dec 18, 2006 at 22:30
hey phil not wanting to get into a argument but silastic does & will stick in extreme heat i have used it quite a few times includeing on exhurst systems
471133
Follow Up By: 666toy - Monday, Dec 18, 2006 at 22:33
i meant exhaust . guess i am having one of those nights
471135
Follow Up By: Member - Phil G (SA) - Monday, Dec 18, 2006 at 22:40
I've used Silastic on exhausts too but only ever as a sealant - not as an adhesive. I reckon Sikaflex would be the better adhesive though.
471136
Follow Up By: ERIC DRUMMOND - Tuesday, Dec 19, 2006 at 05:52
If using black Sikaflex use surgical gloves & clean up with Methalelthalkeytone(MEK)
471175
Reply By: Member - Bradley- Tuesday, Dec 19, 2006 at 12:29
RTV-159 or RTV-102 even rtv-106, will do the job, these are HIGH TEMP silicones, we use then on the turbine engines, they stick like you know what to a blanket on a clean surface, very hard to remove once set, all have an acetic cure (gives off the vinegar small). made by dow corning.
only problem is they are red in colour.
get from industrial suppliers, blackwoods etc..
Oh and they have a multitude of applications for the fourby ;-)
211173
Follow Up By: Member - Glenn D (NSW) - Tuesday, Dec 19, 2006 at 21:14
I use a Dow Corning one called 3145 , I am sure its really high temp ( 1200 C or F I cant remember), its
grey in colour but doesnt have the bad vinegar ( acetic acid ) smell. Its also called adhesive / sealant so sticks very
Glenn.
471301
