Landcruiser 100 Series centre diff lock
Submitted: Monday, Dec 18, 2006 at 19:52
ThreadID: 40477 Views:11923 Replies:5 FollowUps:1
Does anyone know if there is a modification to prevent the centre diff from locking automaticly when low range is selected on the constant 4WD 100 series. I would like to be able to tow my heavy van in low range on hard surfaces if required.
Any ideas would be appreciated.
Ken
Reply By: luch - Monday, Dec 18, 2006 at 20:01
Dont know if you can modify it.....
But an alternative is to put Free wheel Locking hubs on the front, when you need Low range on a hard surface just unlock the front hubs you will achieve the same result
AnswerID: 211064
Reply By: raunchy - Monday, Dec 18, 2006 at 20:23
Hi Ken,
yes you can, I found some sites while surfing, Have a surf or wait until a response comes to you. I thought about it, but as I have the TD with an auto, I have never not been able to push 3.5 tonnes of trailer around while parking so didnt see the need
Ray
AnswerID: 211076
Reply By: Member - Phil G (SA) - Monday, Dec 18, 2006 at 20:38
LCOOL 100series site lists the same article as the 80series:
http://www.lcool.org/technical/80_series/centre_diff.html
AnswerID: 211081
Follow Up By: atoyot - Monday, Dec 18, 2006 at 22:16
Yes, I've done it with no problems; just a simple connection to unplug, tape up and secure. One small thing though, you've got to remember to press the difflock button, and I've got the UHF handset hanging near the button; must have bumped it off somewhere on the French Line and had a hell of a job getting over some dunes, then the co-pilot pointed it out to me! Whoops.
FollowupID: 471126
Reply By: Wayne-o - Monday, Dec 18, 2006 at 21:43
not sure about that vehicle, but i assume there will be a fuse and or relay, just pop it out!!! easy!
AnswerID: 211090
Reply By: Robnicko - Tuesday, Dec 19, 2006 at 15:50
Ken,
Hop underneath your car and remove the circle plug that is located at the back of the transfer case (approx 11 o'clock) when looking towards the front of the vehicle. I have done the same on my 80 series. It allows you to go to low range without activating the centre diff lock. The button on the dashboard then becomes the real centre diff lock/4wd button.
Rob
AnswerID: 211203
