Cruise Control for an Old Diesel
Submitted: Thursday, Dec 21, 2006 at 00:50
ThreadID: 40537 Views:2813 Replies:7 FollowUps:2
Just wondering if any of you owned ( or will admit to owning ) a Pajero NG with the 2.5td and ever went down the path of after market cruise control?
I use my NG to pull the boat about the state and am thinking strongly about it.
Merry Xmas!
Jason
Reply By: keepingitreal - Thursday, Dec 21, 2006 at 10:23
Hey Jason, Probably not really related. I've got a '98 100ser GXL Manual Diesel, aftermarket turbo with aftermarket cruise control. It works fantastic. Igot the model where you can set 3 preset speeds. Great!!!. Works from about 30km and up. All the controls are steering wheel mounted and easily accessible. Hope this is of value to you! Regards Kirsten
AnswerID: 211502
Reply By: Member - Pesty (SA) - Thursday, Dec 21, 2006 at 10:55
Have a Command AP 50 on my 60 series deisel, non turbo, and it works great, you have to get used to using it on a low powered vehicle, but saves heaps of leg ache.
I do mostly country driving, but find it great for staying on the speed limit in the big smoke.
Chees Pesty
AnswerID: 211505
Reply By: stevesub - Thursday, Dec 21, 2006 at 11:21
We have Autronic criuse control on our 78 series non-turbo diesel Troopy. Best accessory we fitted after the CB.
Easy to use, works even better than the Rangie cruise control and we use it all the time. Fortunately our part of Australia does not have any real steep hills where it could be a bit of a pain but then again, you usually cannot use the cruise control in hill country anyway as usually where there are hills, there are corners to slow down for.
Great anti-ticket device.
Stevesub
AnswerID: 211512
Reply By: joc45 - Thursday, Dec 21, 2006 at 16:02
Jason,
I ran an AP50 on my old 4.2 N/A Mav (which was no ball of fire) and it worked fine provided you kept the speed to no more than 100km/h, tho out on the open undulating country, 110 was fine. Wasn't towing anything, tho.
Gerry
AnswerID: 211543
Follow Up By: 243dave - Friday, Jan 05, 2007 at 18:52
just to change the subject a little bit i was reading your coments in an old forum on making the speed sencer work instead of useing the magnets you were saying you had a circut to do this is it posible to get a copy of that circut so i can do the same thanks from dave davedon at iinet dot net dot au if you read between the lines theres my email adressthank again
FollowupID: 473849
Reply By: Member - Jason S (SA) - Thursday, Dec 21, 2006 at 17:24
Very big cheers to keepingitreal, Petsy, stevesub and joc45.
I suspected as much. I have had plenty of CC's on petrol engines but never fitted one to a diesel before.
Have a good one all.
Jason
AnswerID: 211563
Reply By: Member - Oldplodder (QLD) - Thursday, Dec 21, 2006 at 17:35
My 2.8l NH (1996) has cruise control as standard.
It is a cable system attached to the accelerator cable.
Couldn't see why it wouldn't transfer over if you can get one from the wreckers.
GLX, GLS and Exceed has them. Not the GL.
There is an over ride switch on the dash, the control stalk under the wipers, and the control canister just behind the battery.
Only hassle I have found is that it goes to full throttle on any loss of speed, even coming out of a dip, and pulling the accelerator down. Now the pajero doesn't have that much power anyway, so I find it a waste of time except on anything but a really flat road. Then the hand throttle works almost as well.
AnswerID: 211566
Follow Up By: Member - Jason S (SA) - Thursday, Dec 21, 2006 at 19:22
The Pajero has a bigger turbo that has been 'hi-flowed' ( Cleaned up ) so it goes much better than the OEM. Still could do with more but.
My hand throttle is knackered. I thought that the cost of replacing it might better be spent on an after market cuise control.
No worries about hills here in Adelaide. We have the Adelaide hills and then it is a drive to find any more.
Cheers Oldplodder
Jason
FollowupID: 471683
Reply By: stevesub - Friday, Dec 22, 2006 at 09:49
A hand trottle is dangerous as it takes too long to get back down to idle when compared with a cruise control where a quick brush of the brake pedal dis-engages it immediately.
I used the hand throttle a couple of times before we got the cruise control and found that it was no use at all except maybe on very long straights.
Stevesub
AnswerID: 211644
