Off road towing
Submitted: Thursday, Dec 21, 2006 at 12:50
ThreadID: 40545 Views:2962 Replies:3 FollowUps:4
In a previous post I have said that we are about to go to the Snowy mountains area with a camper trailer in tow - not real rugged stuff but off road non the less.
I have plenty of on road towing experience (towing a rally car all over the state in a previous life) but was wondering what tips people may have about off road towing.
Any advice would be welcome (I never cease to be amazed at the willingness of people here to share their knowledge).
IanM
PS The camper has electric brakes fitted.
Reply By: Member - Bucky (VIC) - Thursday, Dec 21, 2006 at 13:28
Take your time pls, and keep everything in perspective, and use engine ( gears ) to break downhill, and that way you will keep breaks cool for when you really need them ...
Also you can use your electronic breaks to act as a anchor, to keep you straight on steep stuff, but your engine and gears are still the best bet
When going up steep stuff ,, use low range and 1st gear, and revs up to 2/3 towards the redline or otherwise you may find out that your vehicle will stall, and its a long embarrasing reverse lesson
Good luck
Bucky
AnswerID: 211524
Reply By: Redback - Thursday, Dec 21, 2006 at 13:55
Most people never learn to reverse the trailler and this is one way of knowing how to control a trailer, weight is important too knowing how much your trailer weighs loaded and unloaded, also the capabilities of the tow vehicle when offroad, mainly because the added weight will effect the momentum going up steep slopes.
I find when i approach a steep incline i select low range reguardless of whether it's rutted, slippery gravel, or even not that steep, and i alway look at the best way to go up (ie) best and easiest line, even if i have to walk up a fair distance, also if you have a locker or any other traction aid, then engage it.
The most important thing in my opinion is always have an escape route if alone, always look at the terrain before attempting it and you don't feel comfortable DON'T attempt it, but if you can don't travel alone, this way you have a recovery vehicle if anything does go wrong.
A good idea is if you have another 4b with you and it doesn't have a trailer send them up first, make it the lead vehicle.
Keep the weight down to a minimum and make sure the brakes are adjusted up well and pads are good, wheel bearings are greased and hitch is greased too, alot of people forget this.
Under no circumstances attempt any steep climbs or desents with a NON BRAKED TRAILER.
The worst part of going up steep inclines is not the steepness so much but obsticals on the climb and this includes errosion humps and i can tell you from experience the errosion humps in the High Country are BIG.
a WINCH in my opinion is a must when towing offroad, also chokes for times when you may need to unhitch, on a steep hill.
Training, if you have never towed on or offroad, most important don't rush things and don't do anything if your not sure.
Make sure your 4X4 and trailer have adequate clearence.
Thats just some of the things one should look at.
Baz.
AnswerID: 211528
Follow Up By: Member - John - Thursday, Dec 21, 2006 at 14:20
Baz, I think I know what you are talking about when you mention "chokes", but can you please explain, just in case I am on the wrong tram... Thanks, John
John and Jan
FollowupID: 471610
Follow Up By: Member -Signman - Thursday, Dec 21, 2006 at 15:58
I think 'chocks' is the word Redback is looking for.....
FollowupID: 471622
Follow Up By: Redback - Thursday, Dec 21, 2006 at 16:22
Yep that's it, chocks or something to stop the trailer from rolling, even anchor it to a tree if there's one nearby, big rock anything really.
Baz.
FollowupID: 471633
Follow Up By: geocacher (djcache) - Friday, Dec 22, 2006 at 09:11
A couple of drag chains make a good means of securing a trailer in the high country. Make sure they are about 5m long. One out to each side to a nice mountain ash will hold it.
FollowupID: 471787
Reply By: Member - Karl - Thursday, Dec 21, 2006 at 15:19
My advice is to take it slow and easy - remebering that you have a trailer behind so once your vehicle clears the obsticle the trailer still has to clear it.
I am assuming that it is set up for off road use, in particular the trailer hitch. If you are using the standard 50mm towball hitch you are going to be extremly limited to your choice of tracks due the limits of the towball.
Also make sure if you let air out of your vehicles tyres then you let the air out of the trailers tyres - they should be equal to the rear tyres.
Enjoy your self.
AnswerID: 211535
