Patrol 4.2 radiator water
Submitted: Thursday, Dec 21, 2006 at 16:41
OldMike2
My feind has a 2002 Patrol TD4.2 diesel and something is amiss with the cooling system. Firstly, it moves a lot of coolant into the header
tank, but not back again. Second, it seems to build up too much pressure in the system,hence the overflow.
Has had radiator cleaned internally. Has new radiator cap. I don't know about the header
tank cap.
Has replaced the coolant lost during the radiator clean process with
water and
Caltex additive. This mixed with the existing (unknown brand) additive.
Having exhausted most of the possibilities, would it be possible for a reaction between the two differing additives to cause a pressure build up?
My reason for asking; he said that it will build up some pressure in the system overnight without running the motor.
Mike
Reply By: Member - Roachie (SA) - Thursday, Dec 21, 2006 at 16:51
I would suggest your mate totally flush the system and replace with ONE kind of coolant. When flushing, he should also flush the heater (by setting the dashboard control to "HOT") and also remove the bung in the block just near the turbo, so that the coolant drains out of the block too.
As for the coolant not syphoning back into the radiator from the header
tank; it sounds like the hose that joins these 2 is not making a perfect seal at one end or the other. I had the same thing happen with my PWR alloy radiator when I first installed it.......the spigot just below the radiator cap was narrower than the one on the plastic GU
tank, and the hose was not sealing properly. So, when the
water expanded, it lifted the radiator cap and was forced through the hose to the header
tank........but, when the radiator cooled back down and wanted to suck back in, all it sucked was fresh air, cos the hose wasn't a tight fit.
Hope this helps.
211555
Reply By: OldMike2 - Thursday, Dec 21, 2006 at 17:11
Thank you for your prompt reply, have already rung frIEnd and let him know.
Thanks again
mike
211560
Reply By: Member - Shane D (QLD) - Thursday, Dec 21, 2006 at 17:20
How ya goin Mike'
I noticed you mentioned that the radiator cap was replaced,is the new cap right?(recovery system)
With out pressing the panic button too soon it might be worth testing coolant for traces of carbon which will indicate head crack/head gasket problem,this is usally the reason why the cooling system over pressurise the radiator cap
Shane
211561
Follow Up By: OldMike2 - Thursday, Dec 21, 2006 at 17:26
Thanx,
Who could do the carbon test? Lives at Yarrawonga, on the Murray.
Mike
471651
Follow Up By: Member - Shane D (QLD) - Thursday, Dec 21, 2006 at 20:02
haven't got a clue down that area,most w/
shop's would have some ability re diagnosing head problem
471697
Reply By: donks1 - Thursday, Dec 21, 2006 at 17:47
the two replies are spot on. although i'd try the first option first, for obvious reasons. NEVER mix coolants. it creates a chemical reaction which can not only cause simptoms you are describing but it will destroy alloy heads, ( n/a in your case) but pipes, heater cores and radiators
check the caps are recovery, change the coolant and make sure there are no air pockets in the system
good luck
donks
211569
Reply By: Sand Man (SA) - Thursday, Dec 21, 2006 at 19:00
Someone correct me if I'm wrong, but IMHO the pressure relief cap should be on the overflow
tank and a sealed cap placed on the radiator.
By this excess
water flows into the overflow
tank and as the system cools down, is sucked back into the radiator. If the pressure becomes too high, it is the cap on the overflow
tank that opens to relieve excess pressure.
All hoses should be checked to ensure that they are not collapsing too. The one at the bottom of the radiator outlet especially should have an internal coil reinforcement to reduce the chance of the hose flattening and restricting flow.
211576
Follow Up By: Member - Roachie (SA) - Thursday, Dec 21, 2006 at 20:18
G'day SandMan......howya goin'?
On the more recent Patrols, there IS a pressurised overflow
tank plus another (what I call) "header tank". However, on my 2000 model, there is no pressurised overflow
tank. The radiator itself has the spring-loaded cap and when that is breached, the coolant flows into the sealed plastic bottle. This bottle only has a screw-on plastic cap with a rubber hose going down into the bottle and another short hose coming back out to take any overflow out and onto the ground.
471709
Reply By: 666toy - Thursday, Dec 21, 2006 at 19:04
Sounds like my 4.2 work ute ...buggered head gasket or head itself..get pressure tested asap (or you could just shove 2 bottles of chem weld in & hope for the best) mines been like it for 6 months i am waiting for the donk to crap itself. (it has done 450,000 on the original donk so its allowed to die hehe)
Dont mix coolants but unlikely to have a chem reaction causing pressure build-up.
If its a head gasket or head don't bother with coolant just use rain
water until you have it repaired...........................666TOY
211578
Reply By: Member - 'Lucy' - Friday, Dec 22, 2006 at 00:02
After being 'educated ' on this
forum over the past years I find it hard, nup! make that impossible, to believe that a Nissan Patrol has something go wrong with it.
Now if you were talking about a Toyota or a JEEP then I would understand.
You sure its a Patrol and not one of those Disco things.
My reference sources for coming to such a conclusion are :
(1) member Bonz (who knows anything and everything)
(2) member Truckster ( who is never wrong and prefers nude chicks to
Forum members)
(3) member Roachie ( who is trying his best to turn his 'new' GU into a diesel/gas injected Hummer - also is Nissan's antipodies DIY R&D agent)
211618
Reply By: nismo - Friday, Dec 22, 2006 at 22:32
hi there ,i suggest to drain out the coolant from the radiator,block and heater core and use nissan coolant.has the thermostat been checked/replaced.if your vehicle is fitted with a header
tank that means your overflow bottle is under it.your radiator should have just a plain cap on it and your header
tank must have the pressure cap.make sure the pressure cap is the correct one,suggest geniune.goodluck.
211749
