Help Needed Please
Submitted: Saturday, Dec 30, 2006 at 19:44
ThreadID: 40719 Views:2037 Replies:6 FollowUps:2
Hi All
I have just tried to install my new stereo into my bus and am having probs. Can anyone help.
The bus is 24v (2X12v) connected in series. I installed the stereo direct to battery but through a 24v to 12 v reducer. Both possitive and negative direct to battery. Stereo wont work. Checked volts at the in side of the reducer 12.3 v, out 10.6v.
Checked volts at batteries 12.3 v. Something aint right. Shouldnt it read 24v????
Reply By: Derek from Affordable Batteries & Radiators - Saturday, Dec 30, 2006 at 20:07
Hi Oz
You must connect to the (+) on one battery and the (-) of the other.
Don't use the two inner terminals that are joined.
Test with your voltmeter to make sure.
Derek.
AnswerID: 212525
Reply By: Gob & Denny - Saturday, Dec 30, 2006 at 21:07
if you have 2 12v batteries why use the reducer why not connect direct to 1 battery should then give between 12and 13.2vdc?????
steve
AnswerID: 212529
Follow Up By: disco1942 - Saturday, Dec 30, 2006 at 21:16
Because this upsets the charging regime and stuffs the batteries. The one supplying the load receives less charge than the other. Have seen batteries stuffed like this a few times.
FollowupID: 472792
Follow Up By: Bonz (Vic) - Saturday, Dec 30, 2006 at 21:27
Really Disco? Would it do that for the piddly load of a stereo radio? I live and learn.
FollowupID: 472797
Reply By: brad1972 - Saturday, Dec 30, 2006 at 21:22
Why not pick up 24v at the fuse box or under the dash somewhere and save yourself the trouble of running wires to the batteries, if you decide to wire it directly to the battery make sure you put the fuse on the reducer input at the battery.
Brad
AnswerID: 212532
Reply By: Derek from Affordable Batteries & Radiators - Saturday, Dec 30, 2006 at 23:11
Hi again Oz
Stick to the converter.
Trying to connect to only one of the 12V batteries could cause problems. (Earths and other connections could go through the radio and blow it up.)
Give me a ring if you are not sure.
Derek.
AnswerID: 212537
Reply By: ozdragon - Sunday, Dec 31, 2006 at 00:09
Hi All
Many thanks for all the sugestions. I ended up with positive to positive on 1 battery and negative on the other (the earthed one). Checked all connections 24.7 v at the reducer in and 12.9 v out. 12.9v at the plug end that goes into the stereo......then nudda..nothing....lol.
I think the stereo is rooted. I connected a test light and all power is there it just dont work. Will take it back on Tuesday for a replacement. Oh well parents were over for dinner tonight. They were not happy....it was thier chrissy gift to me and the handbrake. As I tried to explain...its electronic..its happens.
Thanks again all.
AnswerID: 212540
Reply By: Chucky - Sunday, Dec 31, 2006 at 08:48
Just check that you have both the 12+ power supply and the memory supply active and a good earth.
Normaly these are red for the 12+ switchable power (from you ignition) and orange or yellow in colour for permanent power for the stereo memory. You can hook these up to the same power source if you are happy to A: turn the stereo off manually every time you are finished with it or B: lose all your preset stations when you turn off your iginition.
AnswerID: 212553
