Site Search
Section Image
2 unusual noises in my 75series cruiser ute
Submitted: Monday, Jan 01, 2007 at 10:10
Brian B (Mackay Qld)
Hi all! Happy New Year to everyone!
I have two new annoying noises coming from my 1994 75 series landcruiser ute!
1. Somewhere underneath the floor in the vicinity of the accelerator pedal. When i drive off i hear a twirlling/whining noise which disappears when i reach about 65kms/hr.
2. When coming out of a carpark, i hear a crunching/cluncking/grinding noise when returning from 3/4 lock to centre at crawling speeds. Its in 2wd and diffs are unlocked, i can feel it has something to do with steering.
I am about to book it in for its 160,000kms service, but just wondered if anyone knew of these problems.
Brian B
Advertisement
ThreadID: 40753 Replies: 2
Views: 467 FollowUps: 2
AnswerID: 212696   Submitted: Monday, Jan 01, 2007 at 10:24
Bros 1 replied:
Brian B,
And a Happy New Year to you too.
About No.1 i have no idea.
No.2 could be the spring shackle rubbers worn or cv's need attention.
Only 160,000 k's on a 94 model ? Well done.
Bros.
Click Image to Enlarge
Work is the curse of the down and out bludger.
Reply 1 of 2
FollowupID: 472925   Submitted: Monday, Jan 01, 2007 at 10:35
Brian B (Mackay Qld) posted:
I bought it in october 2004, it had 134,000kms on it then. It also came with a new paint job. (clubsport metallic blue)
FollowUp 1 of 2
FollowupID: 472927   Submitted: Monday, Jan 01, 2007 at 10:55
ross posted:
Does number 1 noise go away when your changing gears ,or is it constant till you hit 65?
Is it still there if you turn the engine off and coast downhill?
Number 2 could be as Bros1 says or it could be the spring pack shifting.
You can try torquing them up to a 180lbs and see if it makes a differnce.
Otherwise tierod ends are a likely cause.
Put the front wheels alongside a kerb so its impossible for them to turn,get someone to rock the steering.
You may see some parts move and other stay still at the joints indicating slop.
FollowUp 2 of 2
AnswerID: 212805   Submitted: Monday, Jan 01, 2007 at 22:54
Member - 'Lucy' replied:
No 2 noise - spray/hose the spring packs out with Lanotec, and then it will be - 'Oh! what a feeling'
Trust me - it works a treat an lasts the longest.
It's not pretty
Marriage, One mans insane desire to feed and clothe another mans daughter
Reply 2 of 2
