Site Search
Section Image
Snorkel versus intercooler
Submitted: Monday, Jan 01, 2007 at 12:17
Member - Jason S (SA)
Happy New Year All!
I have been pondering this question on my own for a while now.
I have an NG Pajero with the 2.5 TD.
I have recently replaced this motor with an updated 1996 4d56T. Basically more anti-pollution garbage on the same motor but it did come with an intercooler.
I have already got a snorkel doing it's thing well.
I am wondering if there would be little , if any , difference in air-in temperature if I was to go down this path?
Jason
The Truck. Bogged in
Click Image to Enlarge
What happens when you are too busy taking in the scenery
Advertisement
ThreadID: 40758 Replies: 3
Views: 851 FollowUps: None
AnswerID: 212729   Submitted: Monday, Jan 01, 2007 at 13:48
Member - John R (NSW) replied:
Gidday Jason,
Not quite sure what your question is, but if it's about temperature differences, the difference between inlet temperatures between snorkel and conventional would be only a couple of degrees if you're lucky.
An intercooler, however would have a significant impact on the temperature between compressor discharge and intercooler outlet. Of course, as well as less heat going into the engine, the cooler air is more dense and hence better for efficiency.
Anybody know a good dentist?I remember when sex was safe and flying was dangerous!
Reply 1 of 3
AnswerID: 212764   Submitted: Monday, Jan 01, 2007 at 17:46
Member - Shane D (QLD) replied:
If the motor has provisions for a intercooler,take advantage of it,snorkel will do stuff all for intake temperature,but an intercooler will
look at cruiser turboed motor outputs (approx)
120 kw/380 nm 7# series
151kw/430 nm 100 series
point is they are the same motor, difference is one has an intercooler!
cheers Shane
Bribie Is
Always keep your words soft and sweet, just in case you have to eat them!
Reply 2 of 3
AnswerID: 212810   Submitted: Tuesday, Jan 02, 2007 at 01:10
Member - Jason S (SA) replied:
Cheers for the help Lads.
Reply 3 of 3
