Site Search
Section Image
Coleman Hot Water System
Submitted: Monday, Jan 01, 2007 at 18:05
Wilankurgab
Hi All, We have purchased a Coleman Hot Water on Demand system a couple weeks ago and used it twice but now wont go. The only thing I have done to it was change the regulator setting on the accessory mains pressure adapter to provide more pressure. I have a 9KG gas bottle attached. I can hear the sparky thingyme fire and water flows but no fire up of the gas. I have changed the flow regulator back down but still no joy. As we are on holidays I haven't as yet seen an agent, but I thought the gurus on this forum may fire me up?
Advertisement
ThreadID: 40773 Replies: 7
Views: 1189 FollowUps: 7
AnswerID: 212772   Submitted: Monday, Jan 01, 2007 at 18:49
Member - Stephen M (NSW) replied:
Can you actually see the spark from the piezo igniter or not. Maybe it has moved a fraction and is not directly in line with the main burner or not working at all. Just a guess.I dont have the coleman I have the primus one but it might help you out. We had a similiar problem with our hot water system at home when I was trying to light it the igniter wasnt inline so grabbed the good old lighter and lit it directly but I still had to lighn it up properly as there is a little probe thingy no idea what its called but it detects the heat from the pilot light in case main flame goes out it stops the gas flowing through bit of a safety thing but probably totally differant to the coleman set up. Hope fully this helps a bit nothing worse than no hot water. Might have to get the old billy out and boil her up. Regards Steve M
Click Image to Enlarge
What A Life
Reply 1 of 7
FollowupID: 472977   Submitted: Monday, Jan 01, 2007 at 18:54
Member - Stephen M (NSW) posted:
Sorry just thought about it and yours is electronic isnt it. Push the big dial in and she spits out the sparks battery operated. So disregard what I said as it would all mean jack sh@t. Regards Steve M
What A Life
FollowUp 1 of 2
FollowupID: 472979   Submitted: Monday, Jan 01, 2007 at 19:12
Wilankurgab posted:
Thanks Steve,
I may just get the blow torch out!!
I am a bit worried about splitting the two outer casings as this damages a sticker. That may make my warranty void.
Yes mine is battery operated
Wil
FollowUp 2 of 2
AnswerID: 212791   Submitted: Monday, Jan 01, 2007 at 21:12
Muddy doe (SA) replied:
I presume you checked that the battery is fully charged? You said that the pump is running so it must have some power. Just checking the obvious. I have one of these and love it.
Muddy
Playdoe GXL TD Manual with lots of MUD
Reply 2 of 7
AnswerID: 212792   Submitted: Monday, Jan 01, 2007 at 21:18
goldiedingdangdo replied:
I have one and am not sure whether the 9kg LPG will run the unit. The coleman propane cylinder works spot on every time???
Regards Ian
Reply 3 of 7
AnswerID: 212808   Submitted: Monday, Jan 01, 2007 at 23:14
brett replied:
Try turning the knob right up to high as soon as you turn it on and listen for the burner going, when on full it is easily heard. I had a problem with one that would fire up for about a second but then turn off. My guess was it was a faulty flow sensor as it fired up but thought there was no water flow so shut the burner down after a few seconds. I took it back to Kmart and got a new one. I've also wound up the regultor a bit and now get good flow when attached to a 12V shurflo pressure pump.
Reply 4 of 7
FollowupID: 474288   Submitted: Monday, Jan 08, 2007 at 13:42
zad posted:
How do you use a 12v pump with it since it's a 6v battery? Is it as simple as plugging it in? Is there any way that the entire system will run of of 12v in stead of just charging off it?
FollowUp 1 of 2
FollowupID: 474315   Submitted: Monday, Jan 08, 2007 at 16:22
brett posted:
You need to use the mains pressure regulator that is available, it has a solenoid in it that runs off the 6V in the unit, but the pump that feeds the regulator must have it's own power. I use the 12V pump on my camper, as it's a pressure pump it turns off when the unit is turned off as the solenoid shuts off the flow
I have thought of adding a socket so it will run off 12V in emergency's when the battery is flat, but you would need to make something to convert the 12V to 6V, also didn't want to modify the unit as it may affect the lifetime warranty. It's probably easier to carry a spare charged 6V battery.
FollowUp 2 of 2
Activities Index
Gliding Deluxe Flight at 4000Ft  -  Benalla Gliding Deluxe Flight at 4000Ft - Benalla
Wine and High Country - VIC
Enjoy the unique experience of silent flight from 4,000 ft.
Barefoot Lazy Daze 3 days/2 nights DORM Barefoot Lazy Daze 3 days/2 nights DORM
The Whitsundays - QLD
Whitsunday Island holiday package including coach and vessel transfer, backpacker accommodation at L
Learn to Surf - 5 Lesson Package Learn to Surf - 5 Lesson Package
Gold Coast - QLD
What a great way to enjoy the holidays, our 5 lessons package will definately give you the skills
Sydney Beach BBQ Cruise Sydney Beach BBQ Cruise
Sydney - NSW
See the best of Sydney!
Book Now - Things To Do
AnswerID: 212809   Submitted: Tuesday, Jan 02, 2007 at 00:01
Blaze replied:
Hi Wilan,
Try all the things everyone has suggested, but if you don't get it working, take it back to where you purchased it. I own oneof these units, (current one was replaced after secondtrip away) Seems Coleman had a problem with a huge batch of these units, but have replaced all without any worries.
Great after sale service
4X4action  shot
Adventure before Dementia
Reply 5 of 7
AnswerID: 212835   Submitted: Tuesday, Jan 02, 2007 at 10:07
Member - Uncle (NSW) replied:
If the battery wasn't fully charged ours did exactly the same thing. I've replaced the battery since and have also purchased a second battery to keep topped up as a spare. Havn't had an ounce of trouble since. (touch wood). Unc
Mount Moliagul lookout Vic
If you see someone with out a smile, stop and give them one of yours.
Reply 6 of 7
FollowupID: 473244   Submitted: Wednesday, Jan 03, 2007 at 12:04
Pajman Pete (SA) posted:
Where did you get the second battery from?
Any mug can be uncomfortable out bush.
VKS737 Mobile 3580
FollowUp 1 of 3
FollowupID: 473388   Submitted: Wednesday, Jan 03, 2007 at 21:23
Member - Uncle (NSW) posted:
Tricky dicks from memory was $22.00 Jaycar should also have them.
FollowUp 2 of 3
FollowupID: 473442   Submitted: Thursday, Jan 04, 2007 at 07:31
Pete
VKS737 Mobile 3580
FollowUp 3 of 3
AnswerID: 213271   Submitted: Thursday, Jan 04, 2007 at 18:21
Member - malcolm T (SA) replied:
hi
we had a problem with our 2 year old model which we returned and received a brand new one no questions asked.
they have 10 year guarantee
malcolm
Karen and Malcolm
Reply 7 of 7
