AnswerID: 212860 Submitted: Tuesday, Jan 02, 2007 at 14:00
joc45
replied:
Hi Dave,
This was a problem with, as said, 1999/2000 gearboxes. Related to the spline on 5th gear and mainshaft (spline too short and it gets chopped out). Nissan fixed mine at about 115,000km and over 2 yrs on, it's been ok since.
If the job had been done properly, a replacement (upgraded) main shaft and 5th gear (plus a few minor bits) should have fixed it permanently, so a subsequent failure makes the earlier repairs sound sus.
Recall the bits were approx $1300 for mainshaft and a few hundred for the 5th gear, plus the small bits and labour. Most of the bearings were sealed, so should not have been affected by the crud in the oil.
The main difference with the patrol ute g/box would probably be ratios, but this would not be a big issue. I know that the ratios were different for each of the turbo 4.2, standard n/a 4.2 and petrol model wagons, so expect some difference for the ute. The 4.2 turbo was the highest gearing in 1st.
Otherwise, these gearboxes are pretty bullet-proof, so a 70k box should be just run in. If the price is right, that might be the best option. You might need to retain your speedo sensor gear if you change gearboxes.
Gerry
Reply 4 of 6
