Site Search
Section Image
Magellan regions
Submitted: Tuesday, Jan 02, 2007 at 21:26
Member - Errol (York WA)
Evening all . Iv'e been trying to workout how to load discover aus onto a 512mg sd card for use in my Magellan Colour . I just cannot work it out . Keep in mind , i'm not that good on puters , but i'm learning . So any help in layman's term's would be appreciated . Iv'e made up the regions in discover aus ,(17) and uploaded 4 regions to the gps ,but now what do i do ? I'm told it can be dunn , but at this stage , not by me . Thanks in advance . Errol
Click Image to Enlarge
Why go overseas when you can ExplorOz
ERROL
Advertisement
ThreadID: 40812 Replies: 4
Views: 485 FollowUps: 9
AnswerID: 212955   Submitted: Tuesday, Jan 02, 2007 at 23:10
Member - Jason S (SA) replied:
What model Magellan?
You will need to upload through the 'Magellan Coversion Manager'
The Truck. Bogged in
What happens when you are too busy taking in the scenery
Reply 1 of 4
FollowupID: 473273   Submitted: Wednesday, Jan 03, 2007 at 14:15
The Explorer posted:
Magellan Colour
Conversion manager is not required in this case - it is for use with eXplorist units - doesnt actuall convert the maps - just transfers them from your computer to the GPS unit after you have created them with DiscoverAus...a task you can do by cutting and pasting anyway.
Carnabys Black Cockatoo
“I was horror–struck to find my poor overseer lying on the ground, weltering in his blood and in the last agonies of death” E Eyre 29 April 1841
AnswerID: 212988   Submitted: Wednesday, Jan 03, 2007 at 09:02
Sand Man (SA) replied:
Errol,
First of all, buy yourself a card reader. These are available from Dick Smiths, etc., and enable the sd card to operate as a removable drive.
Then, go to www.gpsoz.com.au who have an excellent tutorial on how to divide Australian States up into multiple regions so they all fit on the 512 SD card. In fact they will fit on a 64mb SD Card.
On the GPSOZ Website, select FAQ, then DiscoverAus FAQ and all will be revealed.
HooRoo !
Reply 2 of 4
FollowupID: 473217   Submitted: Wednesday, Jan 03, 2007 at 10:32
Member - JohnR (Vic)&Moses posted:
Sandman, you want a 256meg if you want much data and if you want colour data bigger is better than less
On the way to Gemtree
Who?
Multi famam, conscientiam pauci verentur
AnswerID: 213018   Submitted: Wednesday, Jan 03, 2007 at 12:07
Hi John,
You could be right there matey, I'll not dispute that point.
My Magellan Meridian Marine has a black & white screen and I fitted both DiscoverAus and Great Desert Tracks on The SD card in my unit.
Don't have it with me but as I recall it is only a 128mb card.
Errol,
Each State can be divided up into several regions then copied to the card as one.
This is renamed from the default to whatever you like. Renaming is necessary or the second copy will overwrite the original.
The GPSOZ instructions are quite explicit and work very well. The secret is in using a card reader.
Bill.
HooRoo !
Reply 3 of 4
FollowupID: 473249   Submitted: Wednesday, Jan 03, 2007 at 12:19
Sand Man (SA) posted:
Oh,
And why the Card Reader? (Programmer)
SPEED!
You can perform the tasks and save the Regions on the Computer's Hard Drive, but then when you select to upload it to the GPS, walk away for a few hours. It takes a LONG time.
The card reader (Programmer) makes things much simpler and faster and the Card Reader (Programmer) is also useful for transfering pics from your digital camera to the PC without having to connect the Camera to it. Most Card Readers have multiple slots that take SD, XD, CF cards, etc.
As you move from one "region" to another, the map will automatically swap to that currently applicable in the location you are in.
That's my experience anyway.
HooRoo !
FollowUp 1 of 3
FollowupID: 473275   Submitted: Wednesday, Jan 03, 2007 at 14:19
Actual link to GPSOZ instructions
www.gpsoz.com.au/dast_faq.htm
FollowUp 2 of 3
FollowupID: 473328   Submitted: Wednesday, Jan 03, 2007 at 18:17
Forumites,
My apologies for the incorrect capacity information I posed above.
I checked the SD card in the GPS when I got home and it has a capacity of 512mb, of which just under 265mb has been used to store all DiscoverAus regions and Great Australian Desert regions.
I would not want to deliberately mislead people.
HooRoo !
FollowUp 3 of 3
AnswerID: 213021   Submitted: Wednesday, Jan 03, 2007 at 12:34
prado-wolf replied:
Hi Errol,
yes it can be done. I have the Meridian Gold with a 256MB card and i have Discover OZ as well as the Desert maps all on the card.
The size is an issue , you have to first make a change in the Megallan Config file so that you can increase the size of the regions.
Discover OZ can be split up into just 4 regions.
Once you have the regions , upload to the card via a card reader , much faster and you can rename the image one by one.
From memory , there is also some instructions on the megallan site.
Have fun
Reply 4 of 4
FollowupID: 473271   Submitted: Wednesday, Jan 03, 2007 at 14:11
Member - Errol (York WA) posted:
Prado , where do i find the Magellan Config file ? I've got Mapsend Manager loaded but car'nt find the MC file . About ready to give up i think . Errol
ERROL
FollowUp 1 of 4
FollowupID: 473279   Submitted: Wednesday, Jan 03, 2007 at 14:33
The Mapsend.ini file is in the DiscoverAus directory on your computer (on my computer it is Program Files/Magellan/DiscoverAus). You can alter the limit on region sizes by modifying this section of the mapsend.ini file using a text editor (eg notepad)
DEVICE_DEFAULTS]
Com_Port=5
Baud_rate=4800
Memory_Size=8000
Conv_Maximum_Number_of_Regions=9
Conv_Memory_Size=64000
Write_Export_Log=0
Write_GPS_Log=0
In this example I have changed Conv_Memory_Size= from standard 16000 (or thereabouts) to 64000...so now I can make maps up to 64mb in size..but I normally restrict them to around 20mb. It is possible to get all of WA as two files..so Im happy
FollowUp 2 of 4
FollowupID: 473280   Submitted: Wednesday, Jan 03, 2007 at 14:34
..though to solve your actual issue of getting all of Australia onto one card I too recommend getting a card reader....
FollowUp 3 of 4
FollowupID: 473318   Submitted: Wednesday, Jan 03, 2007 at 17:08
Thanks Explorer. Program files/magellan/discoveraus , just isn't on my puter . If it is , i carn't find it . I think i will give up and buy another couple of sd cards . Had a look the GPSaus site and it said that each region can be up to 16mb,s , so had another go at the regions and got it down to 15 now . Havent got a card reader ether , witch dosen't help Thanks Errol
ERROL
FollowUp 4 of 4
Activities Index
Kiteboarding in St Kilda Kiteboarding in St Kilda
Melbourne - VIC
Kite Pilot - Learn the first important steps of kiteboarding.
Half Day Fly Casting Course with John Coles Half Day Fly Casting Course with John Coles
Sydney - NSW
Learn how to cast a fly rod with your Instructor John Coles.
Swan Valley River Cruise and Vineyard Experience Swan Valley River Cruise and Vineyard Experie
Perth - WA
On this Award Winning winery tour you will start the day relaxing on a 2 hour river cruise from Pert
Ocean and River Kayak Adventure - Noosa Ocean and River Kayak Adventure - Noosa
Sunshine Coast - QLD
Join our Ocean and River adventure and kayak the protected Noosa coastline.
Book Now - Things To Do
 Page Sponsors
Phone: 1800 21 21 21
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
