Site Search
Section Image
100 series 1hz engine rattle
Submitted: Wednesday, Jan 03, 2007 at 15:42
bandk
Afternoon all,
Can anybody help me with a noise that is progressively getting worse.It sounds like a ball bearing in a soft drink can getting shaken real fast and only occurs from 2500 rpm to 2600 rpm mainly in second and third gear.It doesn't do it in neutral so its real hard to pin point.It seemed to start after I gave it a tank full of bio diesel.
Any ideas/solutions much appreciated.
Thanks Brad.
Advertisement
ThreadID: 40831 Replies: 8
Views: 1008 FollowUps: 9
AnswerID: 213060   Submitted: Wednesday, Jan 03, 2007 at 16:52
Member - Tour Boy replied:
After you used all that bio up did you change the filters and run normal diesel in it to see if the noise is still there. Sounds to me like a bit of crap stuck in one of the injectors that the bio loosened up. Maybe a bottle of injector cleaner will sort it out?
Tour Boy
Crossing the Burnett River
Click Image to Enlarge
If it's custom it's mine,
If it isn't it's hers!!
Reply 1 of 8
FollowupID: 473321   Submitted: Wednesday, Jan 03, 2007 at 17:17
bandk posted:
Thanks Tour Boy,
Just had an 80'000 k service so presumed they changed the fuel filter.I'll try some moreys or chemtech cleaner and stay the hell away from bio. Ever had any results from injector cleaner yourself ?
Brad.
AnswerID: 213063   Submitted: Wednesday, Jan 03, 2007 at 17:26
Was the service b4 or after the noise started. If b4 you may need to do the filters again (try the inj. cleaner first)
I've had good results with injector cleaner in both petrols and diesels. But now I add 500ml of unleaded to 90lt of diesel every couple of months just to keep everything clean. Last set of injectors lasted 270,000km and still not smokey but naturally a bit worn in the tips.
Tour Boy
Reply 2 of 8
FollowupID: 473323   Submitted: Wednesday, Jan 03, 2007 at 17:38
luch posted:
Yep Thats the Secret good clean fuel & filter change every 10 000km,
My Injectors have never been touched 273 000 kms still getting good economy no excessive smoke getting any where between 11.5 to 14 litres per hundred 1hz Turbo
FollowUp 1 of 2
FollowupID: 473324   Submitted: Wednesday, Jan 03, 2007 at 17:38
bandk posted:
Service was after the noise started.Had a long range tank fitted at the same time as the service and the mechanic asked me if I'd been running it on cooking oil because what was left in the old tank was thick as. Definitely be trying the cleaner.
FollowUp 2 of 2
AnswerID: 213069   Submitted: Wednesday, Jan 03, 2007 at 18:09
Mate do the injectors as a last resort as the later 1hz injectors are around $700 whereas the early 1hz are $350. Brother in law had similar symptoms (noise and power loss) in his hilux after going the bio (now he knows why it was cheap) but a new tank of diesel and a good flogging and it came good by itself.
Tour Boy
Reply 3 of 8
AnswerID: 213072   Submitted: Wednesday, Jan 03, 2007 at 19:00
Gold Member (WA) replied:
Bandk
i know the noise your talkin about, my 99 cruiser does it and so does my mates 02 model 100 series, i went to a mechanic and questioned him and he reckons its a common thing form the 1hz, its the valves and they need adjusting. ive put all about thison the forum before about 3-4 days ago.
good luck
Reply 4 of 8
FollowupID: 473351   Submitted: Wednesday, Jan 03, 2007 at 19:27
atoyot posted:
Does anyone know for a fact if many Toyota dealers actually have shims to adjust the valves? All I ever get from them is that they are within tolerances, but a mate in the diesel business reckons he ends up doing them for the local dealer.
FollowUp 1 of 4
FollowupID: 473438   Submitted: Thursday, Jan 04, 2007 at 07:22
bandk posted:
G'day Gold Member,
I've had a look through the forum but could only find your post about the transfer case oil. Part of the 80 000 k log book service is a valve clearance check.After a certain 4wd service centre in Wangara had my truck for ten days my wife had to pick it up as I had flown back to work.It was then that they came up with some bull bleep story about why they couldn't do the valve clearances.I will be taking it back as soon as I get home.As I am in W.A. as well, just wondering if you could let me know the name of your mechanic in the hope of finding some one reliable.
Thanks Brad.
FollowUp 2 of 4
FollowupID: 473441   Submitted: Thursday, Jan 04, 2007 at 07:30
Member - Phil G (SA) posted:
Andrew,
If you order the shims, they usually have to get them from interstate!! I think its also common to machine shims down until the clearance is correct, rather than replace.
"Within tolerances" usually means they have had a listen to the motor and it "sounds OK".
Mt Finke
LandCruiser HDJ79
FollowUp 3 of 4
FollowupID: 473519   Submitted: Thursday, Jan 04, 2007 at 12:51
cowpat posted:
Haha why am I not surprised. At least here locally (Heidelberg VIC) the Toyota dealer has them in stock. They are not cheap so I am surprised why they wouldn't charge for them and use as many as possible! Casper
FollowUp 4 of 4
Activities Index
Traditional Thai massage - One Hour Traditional Thai massage - One Hour
Sydney - NSW
Experience rejuvenation throughout your entire body with a traditional Thai massage.
Ripple Relaxing Russian Pamper Massage  - 1.5 hour Ripple Relaxing Russian Pamper Massage - 1.
Brisbane - QLD
Save $60! Russian massage is a unique, beautiful relaxing style of massage.
Explore the Coorong by Kayak Explore the Coorong by Kayak
Fleurieu Peninsula - SA
Explore the Coorong World Heritage Area on a unique kayaking adventure.
Helicopter Twilight Joy Flight Helicopter Twilight Joy Flight
Sydney - NSW
A romantic helicopter joy flight over Sydney Harbour at dusk is an absolutely magical experience tha
Book Now - Things To Do
AnswerID: 213103   Submitted: Wednesday, Jan 03, 2007 at 21:16
666toy replied:
Definitely sounds like a valve problem have it checked pronto.
I doubt it is the fault of biodiesel just unlucky for you . Biodiesel does loosen up a lot of crud in your tank but thats a good thing once it is clean you wont have any fuel problems.
Reply 5 of 8
AnswerID: 213173   Submitted: Thursday, Jan 04, 2007 at 08:50
Member - Karl replied:
Give the guys at Robson Bros in Bentley or TLC in O'Connor a call. They have a good reputation for working on 4WD here in Perth. TLC only do Toyotas and are very knowledgeble.
Personnally I don't think that the problem it is because of the Bio other than it cleaning out your fuel lines.
Karl
My new scoop
Everyone is entitled to my opinion!!
Reply 6 of 8
FollowupID: 473470   Submitted: Thursday, Jan 04, 2007 at 09:07
bandk posted:
Thanks Karl,
Now I know why I should have gone to Robson Bros.Sometimes trying to save some hard earned ends up costing more.
Brad.
FollowUp 1 of 2
FollowupID: 473583   Submitted: Thursday, Jan 04, 2007 at 19:34
Member - Karl posted:
Brad,
No problems - being mechanically and technically challenged I am used to breaking things and then having to take it to an expert to fix :-) so I tend to get to know who the good ones are :-)
Whilst I haven't used Robsons I know a number of people who have and they speak highly of them. I tend to use TLC as I have an 80 Series 1HZ with an after market turbo and they do a good job and take time to slap me around and tell me where I went wrong - also they are closer to Rockingham, where I live.
Hope you get the problem sorted out. One piece of advice - look at fitting a Lucas CAV filter adaptor. Costs about $140 but the cartridges only cost $5 - $8 dollars and you can see when they need changing - esp using Bio. I change mine every 10000 kms.
Karl
My new scoop
FollowUp 2 of 2
AnswerID: 213279   Submitted: Thursday, Jan 04, 2007 at 19:22
Brad
i usually go to a place called TLC Auto centre in perth that is 23 stockdale road O'conner (08)93143714
Reply 7 of 8
AnswerID: 213371   Submitted: Friday, Jan 05, 2007 at 08:55
bandk replied:
Thanks one and all
Brad
Reply 8 of 8
