Fullriver AGM's in Adelaide and flat panel TV
Submitted: Thursday, Jan 04, 2007 at 23:30
AdlelaideGeorge
I'm in SA and would be interested to hear from anybody that has bought a Fullriver in
Adelaide recently - who are the SA dealers and what is the current price for a 100AH model - thanks?
Also - has anyone got a flat panel telly to take
camping?- do you have digital too? is there such a thing as 12v DVD player?- what type of aerial is most effective for analogue reception when travelling? Anyone bought such equipment in
Adelaide?
Again - thanks in advance.
George
Reply By: Member - Jason S (SA) - Friday, Jan 05, 2007 at 00:01
Get into Dick Smiths.
Ask these questions and they will supply.
Yes to the 12 volt DVD player.
213328
Reply By: Member - Arkay (SA) - Friday, Jan 05, 2007 at 08:00
Don't know about Fullriver, but Batteryworld stores have a good range of products, there are several of them depending on where you are located. The Glynde one is near us (Ph.8365-3709 Vince) is our local. Ask about the U.S. made Dyno range or Google the internet for this range of batteries.
213348
Reply By: Zig-n-Zag - Friday, Jan 05, 2007 at 09:18
Flat panel TV for
camping? What for? The idea of going
camping is to get away from the normal way of day to day activity. If it is for the kids, forget it, get them to get creative and to appreciate the surroundings. All entertainment does not need to come through a TV.
We have a holiday
shack on the
Murray river and although we do have a tv in the
shack it rarely goes on, the kids are all directed outside to play and get exercise (mind and body).
213361
Reply By: Raymond from Wanderin 4 Wheelers - Friday, Jan 05, 2007 at 11:10
Hi George
Recommend Dick Smith for the LCD TV and DVD and Set top box and inverter. You can negotiate the price down if you buy all together. 240 volts is easier to get and to run from the battery through the inverter.
Check with Fridge & Solar Qld, they ship the Fullriver around OZ
Ray
Tag-a-long wash your mouth out, the little lady needs her Oprah fix each day while the kids play outside
213384
Follow Up By: AdlelaideGeorge - Friday, Jan 05, 2007 at 12:35
Thanks all for the replies - Ray: I can get a 15" LCD flat panel telly from JB hi fi for $350 (from memory). I can also buy a separate DVD/CD player (with its own screen) from Dick Smith and connect the two up. They are both 12v/240v. Is their any real benefit in having 240v via an inverter to power 240v eqiupment when I can get 12v stuff for these prices?
[The LCD screen is powered via a 12v power adaptor from the mains and I imagine the circuitry in the panel would tolerate me cutting off the adaptor and simply attaching the 12v wires directy to my AGM battery]
473743
Follow Up By: disco1942 - Friday, Jan 05, 2007 at 14:41
Don't cut the power brick off the lead. Make up a new lead or get some one to make it for you - the plugs are available from DSE and similar
places. You can then use the power brick to operate the appliance off 240 V when available.
473777
Reply By: Raymond from Wanderin 4 Wheelers - Friday, Jan 05, 2007 at 14:34
Hi George
Don't cut of the plug, just buy the plug and some wire and put it to the AGM battery. I just found I had more choice of units if I went 240 volts and have the inverter already. Use it to charge the phone and computer
Ray
213432
Follow Up By: disco1942 - Friday, Jan 05, 2007 at 14:46
There are plenty of choices in 12 V appliances. You don't have to look at ones "specially made for 12 V." When you are looking at TVs and the like look behind the panels and see if they have a 240 V lead going into them or if they are powered via a power brick (then check if its output is 12 V - most are.)
473779
Reply By: disco1942 - Friday, Jan 05, 2007 at 15:00
George
re your question on antennas - Any antenna is equally suitable for analogue or digital reception. Both types are just radio waves - the only difference is the way the information is encoded on the carrier. The biggest problem with digital is the co-axial cable. Long runs of it can pick up interference that cam wreck the signal and cause problems. You need double shielded cable to keep the interference out. This effect happens more on the UHF channels and effects analogue channels but you only suffer a bit of a degraded signal in this case. When domestic installations "need" there antennas replaced for digital it is generally the cable not the antenna at fault.
Many will think that all co-axial cable is fully shielded - it is not. The cheap cables with only braid shielding are are often only about 45 - 60% shielded. This may not matter much at HF but at UHF it does. The only cable worth purchasing for UHF TV is the type that has an aluminium foil shield as
well as the braid.
213435
Reply By: AdlelaideGeorge - Friday, Jan 05, 2007 at 18:23
Thanks very much once again each - I'll think I'll get a PALSONIC TFTV1520D 38cm 'combo' LCD TV/DVD player and a proprietary cable they supply to convert to 12v DC direct from my battery. I'll be very careful to check the aerial effectiveness too.
213485
Reply By: Motherhen - Tuesday, Jan 09, 2007 at 20:12
We got a KROSS LCD from eBay - before Woolworths started selling them (cheaper than ours too). Works straight off the 12 v. Picture is beaut - speakers were a bit tinny so have added decent speakers from DSE. Bought a Lenoxx 12 v DVD player becasue it was the only one we ould find that was a true 12 v without screen.
214293
