Heat Exchange in a RV Troopie
Submitted: Friday, Jan 05, 2007 at 08:58
Wayne (NSW)
I went to fit the heat exchange for the shower on the 78 Series Troopie and it does not fit where it did on the 75 Series
On the 75 it fitted on the lip near the fire wall over the top of the motor. On the 78 the rocker cover is bigger and there is a pipe that goes from the crossover pipe around the back into the exhaust manifold.
The front of the motor is out as
well near the oil filler cap, again the rocker is too high.
I was thinking about just behind the head light on the passenger side. Vertically mounted with the top near the battery or behind the winch on a bull bar. I can mount it there out of the way but I am worried it might act as a cooler and not allow the heater to work properly. Last year I was away for winter up north and will be again this year so the heater might not be required.
Any other ideas of where to fit the heat exchange? The engine bay is standard, factory turbo diesel, except for the dual battery set up on he passengers side.
Wayne
Reply By: Member - Phil G (SA) - Friday, Jan 05, 2007 at 09:19
Gday Wayne,
I've seen them mounted inside the bullbar on vehicles with little room under the bonnet. It won't affect the heater.
That space behind the passengers side headlight is pretty useful. I have my winch solenoid box and a blue tongue compressor mounted there.
213362
Follow Up By: Wayne (NSW) - Friday, Jan 05, 2007 at 09:28
Phil,
Thanks for the info.
I will put the hydraulic winch on soon so the control box will not be a problem and the air compressor is mounted in the back of the vehicle.
Still might go for the bull bar mounting of the heat exchange.
Wayne
473679
Reply By: Dave(NSW) - Friday, Jan 05, 2007 at 16:13
Sell the Troopie & buy a 4.2 Patrol heat exchanger fit's perfectly on the fire wall LOL.
213456
Follow Up By: Wayne (NSW) - Friday, Jan 05, 2007 at 16:22
Dave,
Now you are being silly.
I have just about finished fitting the heat exchange, the hydraulic winch is next.
Wayne
473817
Reply By: Member - Tour Boy- Friday, Jan 05, 2007 at 16:29
Hi Wayne,
Off topic but are you interested in selling the rear
seat and belts?
Tour Boy
213461
