tent peg puller
Submitted: Friday, Jan 05, 2007 at 20:54
ThreadID: 40909 Views:7075 Replies:17 FollowUps:14
hi all hope you all had a great chrissy and new year and enjoyed a holiday if you had one. Now the question i have after packing the tent up in the pi##$ing rain is this?, have any of you come up with a good design on a thing to pull out those tent pegs that you just can't get out ,and i have tried using the other end of a peg but with the mud and the rain mixed together it is just to damn slippery
Regards BigFella
Reply By: Kev M (NSW) - Friday, Jan 05, 2007 at 20:56
Big Fella,
I have seen somewhere but I cant remember where a tent peg pulling device that has a handle on one end and a hook on the other, similar to a fish hook remover.
Maybe someone else will be able to tell you where to get one from
Kev
Russell Coight:
AnswerID: 213515
Reply By: Member - Crazy Dog (QLD) - Friday, Jan 05, 2007 at 20:58
Check here my man:
scroll down and check this puller - works a treat and you can make one similar if you want
Grrr!!!
AnswerID: 213517
Follow Up By: porl - Friday, Jan 05, 2007 at 21:11
I was gonna mention that archimedes developed a good system that can be easily replicated with stuff around a campsite but that device pretty much does it all in one and applying his useful technique of leverage.
FollowupID: 473862
Follow Up By: Trevor M (SA) - Friday, Jan 05, 2007 at 21:36
I always have trouble fitting in the neccessities. Whilst I have no doubt it would work, I just don't have room for everything like that. I guess I will just struggle for a few minutes getting the odd tent peg out that resists.LOL!
Trev
FollowupID: 473868
Follow Up By: Member - Jeff H (QLD) - Friday, Jan 05, 2007 at 22:23
C Dog,
You wouldn't believe it. We're among those few dinosaurs still on dial up. Checked the Hillbilly site. Cut the lawn (grass),enjoyed a beer, took a shower, and arrived back to see the last picture of a wok loading.
Yes! I thought, 3 to go .(Hi ten pegs, then the puller.Yes, almost there.)
To quote a recent British comedy "Computer says No."
(As in no flamin images of the puller.)
Anyway, we use 10mm ss rod with chain link welded near top. Works for us, beats standard design hands down, and may the bloke who puts 'em on the market drink to our health.
(I now sit back in anticipation of the flood of design errors that we've overlooked)
FollowupID: 473876
Follow Up By: Blaze - Saturday, Jan 06, 2007 at 02:26
I made my own, Use a piece of 5 or 6mm rod, 60 to 80cm long. Bend one end like a tent peg and from the other end come down 30cm and weld a nut on the rod, now slide a piece of tube 15cm long and 1mm larger than inside dia than the rod used down to the nut and weld another nut on the top. To use put hook end under the peg to be removed and slide tube upwards, works a treat, maximum space taken up is length plus about 15mm dia for tube.
FollowupID: 473902
Reply By: Sarg - Friday, Jan 05, 2007 at 21:02
Coleman make a good one, Check out their site under tent accessories
AnswerID: 213519
Follow Up By: mike w (WA) - Friday, Jan 05, 2007 at 23:16
Is that the one with a malet on one end, puller on the other?? Looks a treat
FollowupID: 473884
Follow Up By: Member - Karl - Saturday, Jan 06, 2007 at 23:19
Yes - it is called a Wakjac I think. BCF have them at the moment for about $40. They are bright yellow so it would be hard to loose. I am going to get one shortly.
Karl
FollowupID: 474054
Reply By: Geoff (Newcastle, NSW) - Friday, Jan 05, 2007 at 21:47
If you own a Landcruiser, just use the jack handle.
Greatest multi use piece of 4wd'ing equipment ever made the Landcruiser jack handle. It pulls tent pegs, puts billy's in the coals and retrieves them. Also works for camp ovens and their lids!
I've even been known to use it on the jack in the rare event of a flat tyre!
Geoff.
Geoff,
AnswerID: 213529
Reply By: Member - Blue (VIC) - Friday, Jan 05, 2007 at 21:47
big fella...
I use a pair of fencing pliers, they have a recess in the front of the jaw for the peg and tail of sorts for levering stiff ones out of hard ground...
AnswerID: 213530
Follow Up By: Member - Blue (VIC) - Friday, Jan 05, 2007 at 21:49
P.S think I paid $7 bucks from The Warehouse....
FollowupID: 473870
Follow Up By: Member - Pedro the One (QLD) - Friday, Jan 05, 2007 at 22:13
Good idea Blue ............
Similarly, I have been using cheap multi-grips for years, they live in the tentpeg bag with the hammer, some cane toads and about seven varieties of ants, spiders,lizards etc ..........a bonk with the multi-grips tends to pacify them, though .
Multigrips are also really useful at the campfire for FIRMLY lifting hot thingies off and on the fire .................. cheapies cost about $5 and well worth it !!
Hi to Crazy Dog in CNS ...........
Great link, that HillBilly site .................. excellent products and some great ideas, ay!!!
Many of them are incorporated in the famous Pedro's Pole BBQ, which is available for community viewing on my Members Profile !!
If you'll pardon a little boasting .... and total cost was about one and fourpence ha'penny, if my memory serves me correctly ??????????
FollowupID: 473874
Reply By: madfisher - Friday, Jan 05, 2007 at 22:03
Claw hammer works as well as anything and ytou probaly already own one
AnswerID: 213534
Reply By: cowpat - Friday, Jan 05, 2007 at 22:12
There is such a thing: Site Link I have one; simple but very effective. In hard soil (where you've had to use a metal mallet to hammer the pegs in in the first place) you must twist and pull at the same time. No need to touch the pegs to get them out of the ground and into the bag. Casper
AnswerID: 213536
Follow Up By: Mainey (WA) - Saturday, Jan 06, 2007 at 00:20
I use this one myself and would recommend it to anyone.
It greatly reduces the pressure required to remove the peg from hard or soft ground.
FollowupID: 473892
Reply By: MartyB - Friday, Jan 05, 2007 at 22:18
Here is a few more examples.
www.campertrailers.org/tent_peg_puller.htm
from Marty.
AnswerID: 213538
Reply By: mike w (WA) - Friday, Jan 05, 2007 at 23:14
I got one of my heavy duty tent pegs, a piece of round bar about 70-80 mm long, drilled a hole the same diameter as the peg in one side of the pipe, inserted peg, welded and a coat of cheap paint (preferably bright colour) Works a treat. If you need to use it as a lever, use your hammer as a fulcrum...
AnswerID: 213550
Follow Up By: Member - Jeff H (QLD) - Saturday, Jan 06, 2007 at 00:29
Whoa there mike ol mate; the claret is still clouding the corneas, courtesy of Chrissy.
My image is that you have a length of pipe with a stub of 1/2 " rod into the pipe, welded, 'n then I lose it.
Any more clues ?
FollowupID: 473893
Follow Up By: mike w (WA) - Saturday, Jan 06, 2007 at 11:36
Pretty much, however I used a tent peg as it already has the hook in it, and instead of bar it should have read 'pipe'.
Hope the sun is out and cleared the cloud from in front of your eyes ;)
FollowupID: 473928
Reply By: Member - Phil G (SA) - Friday, Jan 05, 2007 at 23:30
Just rotate them 360 degrees to free it up, then I pull them with pliers.
AnswerID: 213552
Reply By: Sarcophilus harrisii - Friday, Jan 05, 2007 at 23:59
BF
1/4"Dia rod (old bolt?), 50mm long welded into claw of hammer. Lever if required and pull same angle as peg was impailed. Easy and cheap
Happy pulling, LOL
Wisey
AnswerID: 213556
Reply By: Member - Bucky (VIC) - Saturday, Jan 06, 2007 at 06:22
The best tent peg puller I have ever used is a " claw hammer ",, and I only use those big heavy duty pegs.
Problem is that I see a lot of people trying to yank the pegs out ,,,, WRONG !
Simplist way is to not hit them all the way in, then use the claw of the hammer and twist them in their own hole first ( rotate the hammer ) the pegs virtually fall out
Never had to struggle yet !
Cheers Mate
Bucky
AnswerID: 213568
Reply By: Fragle_Rock (VIC) - Saturday, Jan 06, 2007 at 10:30
Here is my ultimate tent peg puller
!MPG:12!
AnswerID: 213599
Follow Up By: big fella - Saturday, Jan 06, 2007 at 12:05
Fragle-rock this design i like. have you just taken a head off a hammer and welded it onto a piece of pipe with a hook on it
Regards BigFella
FollowupID: 473935
Follow Up By: Fragle_Rock (VIC) - Saturday, Jan 06, 2007 at 13:35
Wish I could take credit for it....but I can't. I actually came across this hammer/peg puller in a camping store some years back. I think it cost about $5. Wouldn't be hard to make, it is just as you suggest big fella, a piece of pipe welded to a a steel hook and a solid cylindrical piece of steel for the hammers head.
It has been extremely useful.
FollowupID: 473958
Follow Up By: Member - Drew T (Melbourne) - Saturday, Jan 06, 2007 at 20:20
I saw one of these in Freedom Camping & I was very impressed with it. The week before I had made my own by getting a claw hammer & cutting off one claw & cutting again to make a point .. very effective & you need the hammer anyway for getting the pegs in!
FollowupID: 474028
Reply By: Member - Boo Boo (NSW) - Saturday, Jan 06, 2007 at 11:44
big fella
I'd lend you my peg puller but she's working at the moment
Regards Bob
AnswerID: 213608
Reply By: big fella - Saturday, Jan 06, 2007 at 12:03
Thanks to all the replies you have certainly given me an excuse to maybe get the welder out or should i say the get the mate over
Regards BigFella
AnswerID: 213612
Reply By: Pajman Pete (SA) - Sunday, Jan 07, 2007 at 11:08
We just use a cheap claw hammer with the claws ground down with an angle grinder. Dual use - we use it to belt them in when we arrive and use it again to get them out.
It gets most out easily and for the real tough ones we use the claws to grab the top and rotate them before pulling.
Pete
AnswerID: 213803
Reply By: ross - Sunday, Jan 07, 2007 at 14:37
I havent needed one but I reckon a dent puller with a hook on the end would work ok too. $10-20 from supercrap
AnswerID: 213823
