Pajero electric arial
Submitted: Saturday, Jan 06, 2007 at 16:56
dugsta
Hi, I need to put in a new electric arial.
What would be the best way
doug
Reply By: pajdid - Saturday, Jan 06, 2007 at 18:15
Havn't done one for long time but from memory The insert is easy turn radio on pull up on arial. will come out with nylon end push new insert into hole and turn radio off will automaticaly pull new arial into place. This is for gen 2 pajero ghuess they are all the same
213676
Follow Up By: dugsta - Monday, Jan 08, 2007 at 19:39
Thanks,
last time mitsubishi dealer charged $145 while getting a service
474344
Reply By: fredd - Saturday, Jan 06, 2007 at 18:33
hi all
i have a similar problem with a 1oo series. How do i do it
thanks for any info
fred
213681
Reply By: kiwicol - Monday, Jan 08, 2007 at 19:27
you can get new inserts that fit into electric motor unscrew top side of base of arrial and push motor switch to drive plastic toothed insert out and reverse procedure for new unit. new insert for GQ was $35. Col
214085
