12vDC flat panel tellies
Submitted: Tuesday, Jan 09, 2007 at 19:40
AdlelaideGeorge
Hi aain
further to my post 40877, I am still getting the run around from manufacturers (I've emailed some) re whether or not their LCD tellies that are run from 'bricks' (power adaptors) will therefore run on 12vDC from a battery - you'd think some of them had never heard of a battery! I have explained that the voltage may be 13.5volts (or even a little more) but that normal voltage drop will bring that down. I have asked if that voltage is within the 'usual' tolerance of typical circuitry for these tellies - none of them know for sure (fair enough you might say) but (frustratingly) none of them will find out - not fair enough I think. Retailers are not keen on me connecting one their demo models to my Thumper to check it out - funny about that!
The question is: has anybody reading this actually fitted the barrell plug type that goes into the tellie (from the 'brick), to a cigarette lighter (or Hella type) plug and plugged into a normal, everyday, run-of-the-mill car (or similar) 12v DC battery? Did it work OK and is it still working?
Thanks in advance
George
Reply By: Member - Uncle (NSW) - Tuesday, Jan 09, 2007 at 20:06
Hi there George, I've just been out and done exactly that! The TV powers up, but then switches straight back off again. Maybe it is not getting full current as the cord I have is only a thin one and not the designated 12volt one for the telly. We only purchased this one yesterday and will see if there is one available for it.
214290
Follow Up By: AdlelaideGeorge - Tuesday, Jan 09, 2007 at 20:24
Wow what a coincidence - yes - at 12v DC the telly requires a fair few amps I suspect and small gauge wiring may be the problem. On the other hand - is it that the circuitry is getting too many volts to deal with and is immediately shutting down???
The only manufacturer that I have come across with a proprietary 12v DC adaptor on offer is Palsonic - unfortunately the only model they have powered by a brick has an in-built DVD player and I have bought a separate unit because I want to use that as a portable one. They don't have any other suitable size LCD TV/panels that are 12vDC driven. Their adaptor was $27 and I was told at Jaycar electronics that that is great value as 12v dc voltage regulators (which is what it probably is) are horrendously expensive.
Geo
474527
Follow Up By: Member - Uncle (NSW) - Tuesday, Jan 09, 2007 at 21:07
Hi again George, just had a rummage around for another thicker lead and , bingo, telly fires up and stays on this time, must have been the other lead as I suspected. The LCD we bought draws 30 watts. cheers unc
474535
Reply By: honestjohn - Tuesday, Jan 09, 2007 at 20:26
g'day george go to dick smith buy a 15" flat screen,we paid about $490 last year in
darwin on our way around the good country.you get your brick for 240v ,and a 12 v lead ,with a cig. connection.i cut off cig connection and put a hella plug on ,not a problem with either lead,going very
well
214295
Follow Up By: AdlelaideGeorge - Tuesday, Jan 09, 2007 at 20:31
Hi HJ-do you happen to know the brand name of that unit please? I have been into Dicks in
Adelaide and the (sole) 15" (or is 17"????) telly they have does not come with a 12vDC connector. I'll go in again if you can give me the make and model please.
Thanks muchly......
Geo
474528
Reply By: honestjohn - Tuesday, Jan 09, 2007 at 20:41
george it could have been 17" but name it has is DSE in the middle of frame down the bottom model no.G3812 and its 38cm i hope of some help just been out and checked it
214299
Follow Up By: AdlelaideGeorge - Tuesday, Jan 09, 2007 at 20:49
Cheers - Dick Smiths still sell that brand so I'll 'phone them and see if they'll get me one in.
Thanks a lot
Geo
474533
Reply By: Kazza055 - Tuesday, Jan 09, 2007 at 21:50
I purchased a 17" Digitor from Dick Smiths Site Link 12 months ago.
It has a "brick" power supply with a 12V output and I made up a lead to suit for the van - works a treat.
Bob Cheers
214310
Reply By: avro - Tuesday, Jan 09, 2007 at 22:03
Just make sure that the polarity of the 12 volt lead is the same as the polarity out of the power brick. You can use a digital multimeter to check this. I neglected to do this with my Koss flat panel, and you guessed it, the 12 volt lead I used had a negative centre (which is unusual) and the power brick was positive centre. Expensive lesson as they do not have the polarity protection diode and fuse that any equipment should have. She no work no more........
Regards avro
214317
Reply By: zha zha cruiser - Tuesday, Jan 09, 2007 at 22:12
Hey George,
I was in tandy (same as dick smith) just the other day and was about to purchase an LCD flat screen for my camper trailer which has been wired up for 12 volt. The sales guy told me to get some special $7 adapter and only certain LCd's were capable to work on this small adapter/plug. The alternative was to purchase an inverter for 49 bucks or the 300 watt inverter for 89 bucks. Let me know how you go george as I thought I would research it a bit more before paying out the money. Cheers lyndal
214320
Follow Up By: AdlelaideGeorge - Wednesday, Jan 10, 2007 at 13:07
Hi - I went into Tandy (
Adelaide Central Plaza) today. The manager actually tried to help!!!! He got the box out for the display product and sure enough it doesn't come with a cigar lighter adapter. However he said it would be perfectly OK to use their own adapters - there they were on the J hooks and one model comes with several different barrel plugs for polarity changing - see the previous postings for how critical the polarity is.
The adapter is $24 or so - that cost plus the unit is still good value and the picture looked excellent - they had one on. The manager said they were $500 a year ago.
R
Geo
474636
Reply By: Derek from Affordable Batteries & Radiators - Tuesday, Jan 09, 2007 at 22:31
Hi AdlelaideGeorge
I have put a lot of time into bringing in 12V LCD TV's.
12V DC 17 inch with built in DVD player.
...and yes we supply a 240V AC supply.
Why not just visit the site sponsors.
Derek.
214325
Follow Up By: Derek from Affordable Batteries & Radiators - Tuesday, Jan 09, 2007 at 22:32
Opps....
15 inch available with no DVD. They both have computer input sockets.
474554
Reply By: Upstart - Tuesday, Jan 09, 2007 at 22:56
Another option - I bought a high definition digital tuner which plugs into a USB port on my laptop from Retravison. Cost about $150. The coax cable from the aerial plugs straight in and you do a channel search and then kick back and watch telly. Works
214332
Reply By: Mr Fawlty - Wednesday, Jan 10, 2007 at 16:54
I have a Baumann Meyer and it runs happily off the 12 VDC supply, pulls about 5 amps..
214461
Reply By: Gob & Denny - Wednesday, Jan 10, 2007 at 17:16
we have 1 being fitrted now tin our new van it is a toyoda 240 /12v with built in dvd player it is being fitted by our caravan supplier and he says that there will be no problems
cost $1200 includes swivel arm bracket and installation
steve
214468
Reply By: zha zha cruiser - Friday, Jan 12, 2007 at 07:05
So geo,
What have you decided on? $1200 - I can't afford that. Be interested to know which option u finally went with.
214859
Follow Up By: AdlelaideGeorge - Friday, Jan 12, 2007 at 09:01
Hi - I'll buy the Digitor 17" LCD flat panel from Tandy (it's no BluRay but it's pretty good!) - that's $359. I'll get a $9:00 cigar lighter adpter (with built-in fuse and on/off switch - bare ends for soldering) from them and a barrel plug that fits the telly. Solder it up after checking the polarity and I should be in business - for about $369. Got to
check out omni-directional aerials next. Hills Industries (in
Adelaide) sell a marine/camper unit that should do it (I'm installing all this in a boat and boats 'swing' with wind and tide - important to be omni-directional) but I don't kinow the price yet. Their web site is:
http://www.hillsantenna.com.au/catalog/CaravanMarineantennalo.pdf
R
Geo
475137
