4.2 iTD v 4.2iTD
Submitted: Tuesday, Jan 09, 2007 at 21:20
Wayne-o
pulled the big patrol out behind a mates turbo 100 today, and both went for it burning through as much of the worlds oil supply as we possibly could, but the 100 just pulled away, not by
miles, but it was pulling away continously. Both are 4.2 iTD and both are manual, similar weights and tyre size etc........is it simply the common rail and direct injection that makes them that bit quicker, or are there other differences that make the engine deliver more power.....(please no, I love toyota answers) Cheers, the Wayne-o
Reply By: Exploder - Tuesday, Jan 09, 2007 at 21:34
Computer controlled, Directed injection common rail, beats indirect mechanical injection any day that’s all it is.
I am sure there are differences in the engines as
well but the above is what will make the big difference.
Extreme reliability in tuff conditions comes at a cost and that cost = meat pie engineering, Less Pro-Formance and rather Average fuel economy.
214305
Follow Up By: Member - Roachie (SA) - Tuesday, Jan 09, 2007 at 22:20
I wasn't aware the big tojo utilised common rail technology , yet? I'll happily stand corrected if I'm wrong of course........
For sure they are direct injection, whereas the old 'trol donk (the same one that Noah used to push the Arc along), is still indirect injection.
474549
Follow Up By: Geoff (Newcastle, NSW) - Tuesday, Jan 09, 2007 at 22:24
No need to stand corrected yet Roachie.
My 2006 model RV Troopy with the same engine, minus the intercooler is very definitely not common rail.
Sure the injection and fuel pump are controlled by a plastic brain but it's not common rail.
Geoff
| Geoff,
474553
Follow Up By: Exploder - Wednesday, Jan 10, 2007 at 18:08
No I am wrong in this case. I was going off Wayne-O’s supplied information in his original question when I typed my answer.
I didn’t think it was a Common rail engine either till I read the post and thought I must have been mistaken.
474724
Reply By: atoyot - Tuesday, Jan 09, 2007 at 21:36
GU - old tech diesel with turbo and intercooler tacked on, after a few internal mods (a bit more to it than this but for brevity).
100 - modern diesel with later injection system etc, designed from ground up for T/IC.
78/79 - almost same motor as 100 minus intercooler (just for information).
The GU woud still flog my 1HZ, which is like the GU without the T/IC.
214307
Reply By: Truckster (Vic) - Tuesday, Jan 09, 2007 at 21:54
why do you sound suprised? The TD42 came out in mid 80's... old school bulletproof donk... none better.
214311
Reply By: Member - Ed. C. (QLD) - Tuesday, Jan 09, 2007 at 21:59
What diff ratios is the 'Cruiser running??
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
214313
Follow Up By: Member - Roachie (SA) - Tuesday, Jan 09, 2007 at 22:22
Yep, diffs and gearbox ratios are all different AFAIK......, but there's no denying the tojo donk is a much more modern and (on paper at least) , a more powerful unit.
474552
Follow Up By: Luke SA - Wednesday, Jan 10, 2007 at 09:18
I think you might have hit the nail on the head with that one Roachie, (gearbox ratios) as my uncle has a 2000 100 series and when I drive it, it seems like it needs a 6th gear when cruising. Although it is a non turbo model pov pac.
Cheers Luke
474592
Reply By: Member - Davoe (Nullagine) - Tuesday, Jan 09, 2007 at 22:52
no common rail in the Toyota With a cr 4.2 it would probablysmoke the tyres while pulling away.
Bottom line is it is a more advanced motor with DOHC and better matchd turbo and intercooler
214329
Follow Up By: Member - Phil G (SA) - Tuesday, Jan 09, 2007 at 23:02
Davoe,
Correct about no common rail, but
Its not a DOHC. Its a 24valve SOHC, which utilises a bridge arrangement so 2 valves work off each rocker.
474558
Follow Up By: Wayne-o - Tuesday, Jan 09, 2007 at 23:45
it is single over head cam, but 4 valves per cylinder. 150kw on paper
474571
Reply By: Wayne-o - Tuesday, Jan 09, 2007 at 23:49
well, im not surprised, but i'd rather be in
the desert with my dirty old school, keep the oil companies in business poo-trol! and i have a turbo territory if i wanna go fast, but i was curious, and now im not, sweet as boys, roll on the weekend, cause there is mud to be found, hills to conquer, rock to climb, shrubs to stract the paint, and beer to be drunk!!!
Cheers everyone, the Wayne-o
214342
Reply By: Bilbo - Wednesday, Jan 10, 2007 at 00:18
Wayno,
You have an attitude problem Wayno,,,,,,,,all that enjoying yourself - disgraceful.
The IHDT-FE engine in the 100 series Landcruisesr is a scorcher of a donk. By far, the best 4WD diesel motor in the world - I don't count those "GMC engines" such VW's etc - we've yet to see 'em do 500,000 kms in "Oz" conditions. The Tojo engine is quicker than my 6.5 litre V8 Chevissan. I really miss my 100 series in lots of ways, but the Chevissan is better as bush truck. A Nissan 4.2TD just will never catch a 1HDT-FE Tojo engine.
Mine used to go like a sports car when I tramped it in 1st. It hit the rev limiter before I could grab the gear lever to put it in 2nd!! Even towing an 18 foot caravan it was quick!!
Stay out of that mud or yer Mum'll shout at yer,,,,,,,,,,
Bilbo
214345
Follow Up By: Member - Captain (WA) - Wednesday, Jan 10, 2007 at 00:33
Hi Bilbo,
When I have driven the cruiser 4.2TD, it certainly has a heap of power, but I felt it lacked low down torque compared to the GU 4.2TD (and even the old cruiser 1992/4 4.2TD). I'm talking 600-900rpm range, not say 1,200rpm up.
While I reckon the cruiser 4.2TD is arguably the best TD all-rounder, for off-road sheer low down luggability the patrol 4.2TD still comes out tops in my book even with its old school design IMHO ;)
Captain
474576
Follow Up By: Bilbo - Wednesday, Jan 10, 2007 at 01:15
Captain,
Like you. I've driven both 'n yer right about bush work - the Nissan is better at low RPM. The 100 series Td 'Cruiser - I was up 'n down the box all the time trying to to stay "in the grunt range". But on the open road the 'Cruiser is the winner.
There's only one thing better than the 4.2 Nissan for slow grunt style bush work,,,,,,,,,
Bilbo - and his Chev ;)
474579
Follow Up By: Member - Captain (WA) - Wednesday, Jan 10, 2007 at 01:18
Gotta agree with that, though Roachie may want to take you to task :)
Captain
474580
Follow Up By: Member - Roachie (SA) - Wednesday, Jan 10, 2007 at 07:58
G'day blokes,
I've only had the hubs locked in once so far on the new Chevvy.....just did a short run down the
sand dunes between
Wallaroo and
Moonta. I stumbled across a bogged 60 series and managed to extract him without raising a sweat.
On that short jaunt, I was certainly impressed with the low down torque......it just has that GRUNT from idle. It's no race car and I can't bring myself to ring it out any higher than about 1700 to 2000.
My only reservations are my lack of knowledge of the motor in general. I've been a bit reluctant to change the fuel filters (it has the standard one plus a CAV) cos I'm worried I might get an air lock; and from what I've read, these are a b!tch to bleed. Just little things like that, that I have to come to terms with.
I'm also still trying to find the oil pressure sender unit, so I can fit my buzzer to the circuit. It has a remote oil cooler and that makes me nervous cos if a hose blows I don't currently have an audible warning, just the dash light (which I may not see in time!!!).
474589
Follow Up By: Member - Captain (WA) - Wednesday, Jan 10, 2007 at 09:58
Hi Roachie,
Extracting bogged cruisers with a nissan seems to becoming more common ;) Just wait until you have tow Pesty out again, or will he claim its not really a nissan with a chev motor in their???
I am sure you will sort the big mother of a motor out in time, its not like you look under the bonnet much in your spare time!
Captain
PS. if only you could get a 6.5 chev on a novated lease...
474595
Follow Up By: Bilbo - Wednesday, Jan 10, 2007 at 12:13
Roachie,
The oil pressure sender until is located at the very rear of the engine block, on the passenger side"V". It'd be a bit of a bugger to get a spanner in there from what I can see, but I've never had to have a go at it.
You'll see where it is when ya get that CD. It left yesterday.
Brunswicks reckon it's easy to get at and fit a "T" piece, but I dunno. It doesn't LOOK easy.
Bilbo
474626
Follow Up By: Member - Roachie (SA) - Wednesday, Jan 10, 2007 at 13:16
Thanks for that Bilbo, I have seen that lug and thought it was for the
water temp sender unit. I'm not interested in removing it and putting in a "T" piece etc......all I want to do is tap into the wire and rig-up a buzzer that comes on whenever the red dash light (oil pressure) comes on. That lug is easy to reach on
mine cos the air filter box isn't sitting over the top (like I imagine yours is?).
Cheers and thanks for disc too.
Roachie
474637
Follow Up By: madfisher - Wednesday, Jan 10, 2007 at 15:20
Fellas,
We have a 22
seat coaster at work with that lovely 15okw motor with a 6 speed manual and it flies.Had to get it accross to
mudgee recently in a hurry, went across the turon at
sofala in fifth planted it and it started accerating up commioners
hill in 5th, had to back off for sharp crn and lost boost, back to 4th, back on gas and had to back off because I had caught a Forrester. Only bus I have driven where you could lose your lic. in one go but I love it apart from the too soft
suspension
We also have a D4D HiACe 14 seater and its no slouch either
Cheers Pete
474665
Follow Up By: Exploder - Wednesday, Jan 10, 2007 at 18:12
Don’t be afraid, as they say “If you want to Rev it, CHEV it” LOL
474728
Follow Up By: Member - Roachie (SA) - Wednesday, Jan 10, 2007 at 19:28
Quote: "If you want to Rev it, CHEV it".......Strewth mate, I don't even know what the red-line is supposed to be on this jigger!!!! hahaha
474746
Follow Up By: Bilbo - Wednesday, Jan 10, 2007 at 20:41
Roachie,
About 3,900 RPM is what I've found so far in documentation.
I've had it up to 4100 though ;)
Bilbo
474773
Follow Up By: Member - Davoe (Nullagine) - Friday, Jan 12, 2007 at 11:17
I disagree with the low down tourque of the TD vs the NA criser (talking utes here at least) I have driven both a work. The TD seems to be lacking down low but only coz it takes off so well at higher revs. I found the turbo nearly immpossile to stall at idle speed in too higher gears and cerainly had far more bottom end at low speed that the NA 4.2
475169
Follow Up By: Bilbo - Friday, Jan 12, 2007 at 12:46
I dunno Davoe. My TD 'Cruiser used to almost stall when I got lazy on the way to work, if I started off in 2nd. I had to slip the clutch a fiar bit to get up the rev range. I didn't do it very often.
The N/A 4.2 Nissan never did - but it was ute & prolly had lower gearing - and the Chev well,,,,,,,,,I could start off in 3rd!!,,,,,,nah that's taking things a bit too far!
I'm planning next years trip to the
Pilbara to "find my fortune". I'll PM you for any info about ground up there.
Take care,
Bilbo
475188
Reply By: Member - Brian (Gold Coast) - Wednesday, Jan 10, 2007 at 07:48
There would be a difference in the turbo set up as well I think?? Happy to be corrected here but AFAIK the GU turbo is "conservative" as well as having a restrictive exhaust?
I had a quick "run" against a mates GU a few months back and he commented at how quick my GQ with the aftermarket turbo is in comparison to his standard GU.
I know that the Toyota is a great engine, perhaps the turbo is another one of the factors involved?
Brian
214355
Reply By: Member - Karl - Wednesday, Jan 10, 2007 at 09:18
Maybe he was just a better hoon driver :-)
Quicker on the reflexes etc.
214366
Reply By: Member - DOZER- Wednesday, Jan 10, 2007 at 11:44
2000 technology vs 1990.....
The td6 is an old reliable donk with a turbo and intercooler added, just like they used to do with Safari gear, but now it has Nissan on it...
The toyota however, is an improvement on its 1995 model multivalve...by adding to it electro control, it uses more pressure in the injection system to give better atimisation for cleaner burn and more power, add to that a front mount intercooler (where it should be to minimise thermal loading and increase efficiency) overhead cam technology to reduce friction....in a phrase... better design... (do i get a job as a salesman mr Toyota) but the main reason.......direct injection just like the 3 litre patrol motor.....but in a 4.2.....the 3 litre is obviously more stressed than the 4.2 at making close to thesame power figures...
Anyone own an old Rodeo 2.8 t/d or a new Jackeroo...both good examples of powerful small direct injection motors....all the trucks
on the road are direct aswell...just the jap 4wd motors that keep the indirect because (their excuse is) they suit the Jap smog regulations...
Lastly, the oil in a yota could well be retained for tripple the service change, they dont polute the oil anywhere asmuch as the indirect injected motors, which would start to become paiste after 5000 kms.
214396
Reply By: Trevor R (QLD) - Wednesday, Jan 10, 2007 at 14:14
I have spent about 6 grand all up on enhancing my Nissan and I would be most interested to put it up against the Cruiser, on paper mine has similar if not a bit more than the factory cruiser but it has cost me 10 grand less than those going out and buying the cruiser from new. The big difference would be
top end speed being more in the cruiser over mine but who gets away with driving at more than 160 these days anyway.
See you out there one day.
Trevor.
214423
Reply By: Robin - Wednesday, Jan 10, 2007 at 16:03
Wayne its just power - a 3lt Nissan will pull away from you to.
The 4.2 Nissan diesel is an 18-19 sec car (0-100kmh)
The Tojo 4.2 is 15sec (Base model 20 sec)
My Mates 4.2 Nissan with exhaust and tune up is 15 sec
The 3 lt Nissan is 16 sec +- 1/2 depending on model.
The 4800 Nissan is 10-11 secs
Robin Miller
214442
Reply By: gbc - Thursday, Jan 11, 2007 at 09:55
Come November this argument will be moot with the introduction of the tojo twin turbo V8 diesel.........drool drool.........I might be able to afford one in 2011?
214617
Reply By: TerraFirma - Thursday, Jan 11, 2007 at 12:13
The Toyota 100 series do not use Common Rail technology yet, the new Hilux and Prado do but these are different engines. The Toyota engine has more low down torque than the Nissan and this is probably why.
214662
