fitting air compressor.and extra power outlet
Submitted: Wednesday, Jan 10, 2007 at 13:12
Member - BUNDY BOY (WA)
hi everyone ...heres one for the sparkys ...im fitting my air pump..(tyres only)into the rear draw system ....alls
well 6ml power cable from second battery......direct with fuse to pump......works
well.....now i want to put 1 of those 4 plug cigjacks..in there as
well ...(only for a
camp light/or something small.when
camping ....)now could i tap into the power lead ive run for the air pump.....as not running anything unless im pumping up the tyres.......??????just to save running another lead up to it ????..
cheers Bundy
Reply By: Sand Man (SA) - Wednesday, Jan 10, 2007 at 13:44
Yes Bundy,
No worries.
A correctly rated fuse for the cable size will protect the circuit from overload, whatever you plug in.
214411
Reply By: newlux - Thursday, Jan 11, 2007 at 09:50
I did the same thing in my Hilux. I have storage _Affordable_Storage_Drawers.aspx in the tray and I left the L/H drawer slightly shorter which left me enough room to mount my Max-Air compressor and a Fuse box in the space.
I used 8 BandS wire routed directly from the battery to the fuse box and then from there I have taken power for the compressor and power for 12v accessory outlets in the tray. This system has been in place for nearly 12 months and works faultlessly.
I have also mounted a 3L airtank under the tray with air outlets in the rear. So the compressor is activated via a dash switch and also a pressure switch on the airtank. A 3L
tank is not enough to inflate a tyre on its own but it is enough to get a good blast of air for cleaning etc.
Here is a couple of pics of the compressor and fuse box mount before it was fitted to the 4x4. I haven't got any photos of the set up post installation. Good luck it makes life a lot easier!!!
Mick
214615
Reply By: newlux - Thursday, Jan 11, 2007 at 10:08
try again
214623
Reply By: Member - BUNDY BOY (WA) - Thursday, Jan 11, 2007 at 10:18
hay thanks guys ......didnt think it would be a prob .but . its better to get some feed back .thanks for the help.
.Bundy
214629
