NISSAN PATROL GQ COIL CAB BOUNCE
Submitted: Friday, Mar 28, 2003 at 22:02
mark
I have a 93 GQ Patrol ute when sitting on 55 to 65 km/hr in 4th gear the rear end bounces as soon as the clutch is pressed it stops bouncing .I,ve had it checked several times each time they fix something different ,new tyres,new rims,removed and checked tail shaft,removed and checked shockers,replaced sway bars.If any-one can help it will be much appretiated as its getting verry expensive.
THANKS MARK
Reply By: Eric - Friday, Mar 28, 2003 at 23:26
Mark.
Sounds like a phasing problem with the drive shaft. the yokes on the ends of the drive shaft must be a mirror image of each other, if they are not slip the spline off and rotate them untill they are. If they are already correct check the condition of the bushes in the
suspension arms, if they are plastic not rubber get rid of them and fit rubber ones. Eric.
16365
Reply By: mark - Monday, Mar 31, 2003 at 15:29
THANKS ERIC I WILL TRY THAT AND LET U KNOW HOW I GO.
16503
