Tyres - are they he same size??
Submitted: Friday, Jan 12, 2007 at 22:09
Member - Davoe (Nullagine)
Couldnt be stuffed putting them side by size but are the BFG all terrains 30x 9.5x15 on my missus hilux the same size as the factorey spare wich is a 205x16 road gripper f I suspect not??
Reply By: fidlim - Friday, Jan 12, 2007 at 23:10
Hey mate,
checkout www.1010tires.com, they have a tire calculator there, I have used it to calculate myself out of the tyre replacement trouble, but don't forget the load index.
I've tried to have a look at your problem and it seems that not only the spare would be some 3.5 cm narrower than the other tyres but also some 4-4.5cm higher (overall diameter resulting in approximate difference of 2 cms in radius)
closest of the 205series on 16rims would be 205/85R16 but still some 7mm smaller which might make a huge difference in driveability.
I recommend get rid of the spare and buy a one that is the same size as the other
wheels fitted to your vehicle.
KEEP SAFE!
Petr
215030
Reply By: Member - Teabag (Queanbeyan) - Friday, Jan 12, 2007 at 23:12
Try this.....
www.4lo.com/calc/gearmetric.htm
215031
Reply By: Member - Phil G (SA) - Friday, Jan 12, 2007 at 23:28
BFG 30x9.5x15 are 771mm diameter.
Dunlop 205R16 are about 740mm
215033
Reply By: Gramps (NSW) - Saturday, Jan 13, 2007 at 01:03
Davoe,
This is the link Fidlim mentioned
link text
215047
Follow Up By: Bonz (Vic) - Saturday, Jan 13, 2007 at 10:15
oooohhhhh u can make links, now I must speak to David about making these things harder to do hahahahahah, good job Al
475367
Reply By: Member - Davoe (Nullagine) - Saturday, Jan 13, 2007 at 01:21
hmmm the lak of profile on the 205x16 and bfg 16 could make it difficult. Maybe i wont be slack and do the ltimate test - pull the spare off and measure the od then jack the vehicle up and measure the od
215050
Follow Up By: Member - Alastair D (NSW) - Saturday, Jan 13, 2007 at 06:45
Davoe,
The unloaded diameter is of limited use. Different tyres squash down to a different extent when under load. Measure the loaded rolling radius on the vehicle - I take a small spirit level, line up the bottom with the centre of the hub/wheel and measure the distance to the ground. Surprising how much tyres of the same size but different brands vary and I have never found the numbers to be the same as found on the charts.
alastair
475342
Follow Up By: Member - Phil G (SA) - Saturday, Jan 13, 2007 at 15:08
Davoe,
I posted the diameters above. 30mm difference means the 205 is not much good as a spare.
475399
Follow Up By: Member - Davoe (Nullagine) - Monday, Jan 15, 2007 at 02:07
I believe you Phil - she was told they are the same size but i had severe doubts. However have you got it round the right way that the 15 inch tyre is actually 30mm larger than the 16 inch? - just a crsory glance and neither looks to have a particulary high profile
475631
Follow Up By: Member - Davoe (Nullagine) - Monday, Jan 15, 2007 at 16:44
verdict is in. The road gripper had approx 12mm of tread (brand spanker) and the bfg around 4mm (hmm thats gonna cost her some time this year) side by side their appeared to be around 1 inch difference but its hard to be exact. the circumferance of the BFG was 2310mm and the rg was 2350mm.
I suspect a 10.5 15 inch will be alot closer if the 9.5 are replaced plenty of options but In the. meantime I will let her know it is a limp home to be fixed asap if the need arises.
BTW do you know if the 80 series 16/235x85 will fit straight on as
well as the 80 series splits? I think so (2004 hilux) if so there are a few more options if the need arises...................... (how quickly a divorce can happen)
475741
Reply By: Truckster (Vic) - Monday, Jan 15, 2007 at 10:01
in the time it took you to type this, and wait for 2903823904823089 wrong answers, you could have stood them side by side, and even probably changed them, done a tire rotation, and balanced the lot on both cars.
215382
Follow Up By: Gramps (NSW) - Monday, Jan 15, 2007 at 10:07
And where's the fun in that :)))))
475666
Follow Up By: Member - Davoe (Nullagine) - Monday, Jan 15, 2007 at 10:36
what part of "Couldnt be stuffed putting them side by side" didnt you understand?
eriosly though I have just dropped her off at work So I can clean it out from the Weekend s that is exactl what I Will do I told her last night it was dought ful no matter what she was told bt in typical chick fashion I think a visual demonstation is the only way I tink 30mm is too large a difference especially on a 4by where it may wll be further than 10k to the nearest tyre place (If I can talk her into swapping all the gear from my 80 and really testing out a TD Hilux)
475669
Reply By: Rod W - Monday, Jan 15, 2007 at 10:41
Davoe, Whats this "missus" bit? When did this happen? Last time I seen ya you were batching. What went wrong?
Rod
215389
