BJ40 series Landcruiser Disc Brake conversion Advice Please
Submitted: Sunday, Jan 14, 2007 at 17:14
luch
Hi all
My Brother is Doing a Disc Brake conversion on his 40 series.
He has got The front diff from a 60 series which he will swap over the Swivel Hub Assembly, Callipers, Discs, Ect
But we would like some advice from any one who has done a conversion like this before
Does he need a new Booster and master ?
Does any modifications need to be made to the rear brakes as it has two wheel cylinders not one like the 60 series ?
What other problems may we encounter while doing this conversion ?
Luke
Reply By: Peter 2 - Sunday, Jan 14, 2007 at 19:08
I did the same job to a 45 series troopy years ago using Hilux front bits, only difference was non vented and vented discs.
I had to change the master cylinder to a 60 series one, booster was ok, the rear proportioning valve needed some tweaking from memory.
I didn't have to do anything to the rear brakes from memory, but can't remember whether it had one or two wheel cylinders either ;-))
If it doesn't work fit the 60 series rear brakes.
215276
Follow Up By: luch - Sunday, Jan 14, 2007 at 20:07
How did you find the brakes after converting to discs ?
475567
Follow Up By: Peter 2 - Sunday, Jan 14, 2007 at 22:05
They always worked very
well, the main reason I did the conversion was so that I had brakes after river and
creek crossings as the drums took forever to dry out. Also less hassle not having to clean mud out of the drums.
475604
Reply By: Tim HJ61 (WA) - Sunday, Jan 14, 2007 at 23:18
Luke,
I8HMUD
forum is pretty good for this technical stuff -
forum.ih8mud.com/ - and they have a special
forum dedicated to each series.
Tim
215347
