Fly screen over radiator or not?
Submitted: Sunday, Jan 14, 2007 at 17:36
ThreadID: 41202 Views:10858 Replies:10 FollowUps:3
After a trip I noticed that I had a clogged radiator. Day tips off road clog it with mud and road trips with insects. I am thinking I need to do something about it. I assume the quickest and easiest thing to do is a bit of fly screen. Can anyone enlighten me as to wether its a good idea or not, and are there any issues to doing it. I have 4 radiators up front and cleaning them all out it a pain. (on the side some radiator cleaning tips would also be handy)
thanks.
Reply By: Member - Roachie (SA) - Sunday, Jan 14, 2007 at 17:45
More info would be handy.....what sort of vehicle? Why does it have 4 radiators (or are you including oil cooler, intercooler, air conditioner's condenser etc).
A rule of thumb is that turbo'd vehicles need free-flowing air (at least the Patrol's do), and Nissan recommend NOT to use a insect screen on it's turbo trucks.
AnswerID: 215255
Follow Up By: F4Phantom - Sunday, Jan 14, 2007 at 17:57
ok, its a tdi, but the engines air cooler is a horozontal radiator with an intake scoop for air. The front 4 radiators are the main water one, aircon, auto tranny cooler and I forgot what the last one is for perhaps a seperate oil cooler or something. Some of them are mounted low and dont influence the radiator but the air con is in front of the radiator. make is pajero. I would hate to overheat the engine through not enough air on the other hand I will likley do this if it fills with bugs.
FollowupID: 475550
Reply By: Motherhen - Sunday, Jan 14, 2007 at 18:22
If it's going to get clogged with insects, then the less airflow with a screen would be preferable to no airflow with a blanket of locusts. Farmers use shade cloth when the locusts are bad.
AnswerID: 215264
Reply By: Member - Barry M (NSW) - Sunday, Jan 14, 2007 at 18:41
I have used a flyscreen type filter on a couple of Hilux used as agricultural spray
rigs & works fine but required daily maintenance, sometimes hourly in bad seed conditions but I would be reluctant to recomend same in your case. I found that
the majority of rubbish etc actually got in not through the front grille but through the vents & gaps under & through the Bull bar. I fitted a shadecloth screen under
neath & works a treat, wears out occassionally though. I imagine there is an
aftermarket screen made for your grille you could try. Just keep one eye on the
temp needle.
Compressed air is good, from the inside, but sometimes access can be difficult,
avoid direct contact with cooling fins & I have seen fins flattened by too much
pressure & the wrong angle of application. Many local cockies use shadecloth in the
centre of the bullbar to deflect grasshoppers, seems to work too.....oldbaz
AnswerID: 215268
Reply By: John R (SA) - Sunday, Jan 14, 2007 at 18:59
All our off-road vehicles have doubled-over fly screen (two layers) in front of the radiator, mainly for grass seeds.
The local Toyota dealer actually does this standard (that's to say, when I picked up my Hilus he'd done it without being asked, and said they do it for virtually all the 4wds they sell) because most people round here do it anyway.
Go for it.
AnswerID: 215272
Reply By: Peter 2 - Sunday, Jan 14, 2007 at 19:00
Flyscreen is the go for highway and local trips, if going into desert country I take a piece of shadecloth to put over the bullbar/outside as well.
Only use the nylon/fibreglass flywire as the aluminium and metal ones rub and when mixed with red dirt and water corrode very quickly.
I just get the overall width required, 1200/1500 etc and rock down to the hardware and buy enough for about three screens, cut them to size and shape and keep a spare in the truck in case you need a replacement while on a trip.
I tie mine in with cable ties.
Much easier sweeping the crap off the outside with abrush than picking it out of the cores, never had a prob with cooling on a variety of vehicles either.
AnswerID: 215273
Follow Up By: Member - Davoe (Nullagine) - Monday, Jan 15, 2007 at 11:16
I have found shade cloth over thegrill to be of imited value (may help) in 75 tojo utes at least. the fan sucks up crap between the air con rad and into the engine rad also pleeeenty of crap into air con rad despite hade cloth. I had to brush out he air on rad 2wice in 50k once and use a special leaning tool that gets between the 2 rads to blow out the engine rad at Norseman - That was with a shadecloth blind- didnt seem to stop much at all s the fan sucks crap in and around it
FollowupID: 475675
Reply By: F4Phantom - Sunday, Jan 14, 2007 at 19:58
Thanks for all that, I will use some nylon screen and see how it goes.
AnswerID: 215282
Follow Up By: RustyHelen - Monday, Jan 15, 2007 at 09:13
Stating the obvious but put it on the bar or grill if no bar, not on the radiator screen itself, ie keep it as far forward of the radiator as you can.
Rusty
FollowupID: 475653
Reply By: Bros 1 - Sunday, Jan 14, 2007 at 20:43
F4phantom,
I have had a fly screen mounted in front of my radiator for years with no noticeable rise in engine temp. It slides upward and out for cleaning. On my rig pic you can see it mouted behind the spotties. Made out of ally frame with security grill backing.
Seems to keep the rubbish out.
Bros.
Work is the curse of the down and out bludger.
AnswerID: 215291
Reply By: mike w (WA) - Sunday, Jan 14, 2007 at 20:50
As mentioned fly screen is your best option. There are premade screens available from auto shops, but they charge you for the privelage :)
Beaaware that some shade cloths available also have a wind rating, i.e. they will cut air flow by x%.
AnswerID: 215294
Reply By: Member - Arkay (SA) - Monday, Jan 15, 2007 at 10:07
With the mesh screen (soft material), measure up, get some 2" black clothh tape, & sew a perimeter all around. At strategic points put some brass eyelets in, add string/rope or similar to tie to the bull bar or parts of the underside of front of vehicle. Take care to avoid any contact, rope or mesh, with any visible painted parts as dirt/mud is picked up and abrades the paint.
AnswerID: 215383
Reply By: V8Diesel - Monday, Jan 15, 2007 at 12:41
I wouldn't leave town without it. You can get a plastic flyscreen (not metal or covered metal) from Bunnings. Get the biggest width and plenty of it. Use cable ties on triple folded seams. Worth spending the time to do a neat job for efficiency and aesthetics. I put mine behind the grille so you wouldn't even know it's there.
Having dealt with both locusts and spinifex you must do a thorough job. Keep it away from the radiator and make sure you get the whole way underneath too.
With grass seeds they will still get in no matter what you do but this slows them down.
AnswerID: 215407
