Solar Panels
Submitted: Tuesday, Jan 16, 2007 at 13:48
ThreadID: 41262 Views:4034 Replies:12 FollowUps:31
G'Day all,
I'm close to purchasing my first panel, and I'm leaning towards the BP 40w to run ONLY my engel 40ltr thru a regulator and an 85amp deep cycle. (dual battery system with isolator)
I dont want to go any bigger really as I'm sure this will suffice, and I'm sure I read others actually using this panel for same fridge.
The suntech is a bit cheaper, Kyocera a bit more exy, reckon BP been at it long time and good company.
Anyone care to add any experiences which could be relevant in my final decision
any particularily good or bad experiences with these type / wattage of panels?
Any advice welcolmed
Rgds
Ron
Reply By: Scoof - Tuesday, Jan 16, 2007 at 14:04
Hi Ron ,
I have a 80 watt BP panel and it runs the 40L engel fine , no probs .
Not sure if 40 watt would be big enough but it maybe OK.
I was advised at the time to go with the 80 watt .
Some Sparky will know if it's big enough I'm sure.
Cheers Scoof
AnswerID: 215652
Follow Up By: Ron173 - Tuesday, Jan 16, 2007 at 14:15
Scoof,
thanks, yes 80w would be nice but not enough of the folding stuff at present.
The 40w should be enough as long as its not running anything else, which it wont be.
I'm sure when I last posted when I was investigating panels initially, someone said they ran a 40ltr engel from a 40w ok.
I know people will say I need 100w etc. and buy biggest, but I dont have an unlimited budget, infact its quite constrained at moment, so only aim to buy what I absolutely need.
I only ever would be staying in one place 5 days max, even if one cloudy day, battery should cope.
Guess I shouldnt be so slack n go look up the old thread for a re-read aswell.
I'm more interested in brands, just nice to know your not about to buy a lemon of a panel.
Rgds
Ron
FollowupID: 475933
Reply By: Mike Harding - Tuesday, Jan 16, 2007 at 14:21
Depends where you live and what your style of camping is.
If you only go away for 3 or 4 days at a time a 40W panel and an 85Ah battery will probably be OK.
For longer periods I have my doubts: if you live in Vic then the temperature is generally lower (although it's 40C as I type this! :) and you might last a week or ten days in spring/early summer/autumn. In Qld/NT etc I doubt you would make one week.
There are a lot of variables attached to your question: how much sun/cloud, how well you track the sun, ambient temperature etc. In my opinion you're pushing your luck with a 40W panel but you might get away with it. Buy a $25 (not the $10 one!) multimeter from Jaycar and monitor your battery to ensure it doesn't fall below 11V and _never_ below 10V5 - if the panel can maintain it above 11V then you're OK otherwise you'll need to upgrade.
Mike harding
AnswerID: 215656
Follow Up By: Ron173 - Tuesday, Jan 16, 2007 at 14:58
Mike
3-4 days is my average, 5 is tops and unusual.
Usually nsw in mid to high 30's, and in winter when cool.
Would love to go 65w but its another $200 and with buying a reg too, it starts to bump up, the cook is always up me about $$ on camping, it took me long enough to get her onside for a 40w!!
Meter no dramas, I have a $1100 fluke (paid for by work) and I do monitor my battery voltage as it is.
I try to keep it higher at present by running engine on hand throttle at 2000rpm,
10.5v in my book is zero charge, presently I try to maintain around 11.9v (40%) if poss, but want to get away from running vehicle unless absolutely necessary.
As for tracking sun, I doubt I'd be following it closely but did intend not to just mount flat but to be able to tilt one way in morning, other in afternoon.
I know I will not have any spare, but hopefully just enough, thats why I wondered if panel make made any difference, ie one brand maybe has a 'little' more punch than another? I know watts is watts, but I mean like a 1955cc being a 2.0ltr, and a 2075cc being a 2ltr, is prhaps one panel manufacturer known for a smidge more?
Rgds
Ron
FollowupID: 475943
Follow Up By: Member - JohnR (Vic)&Moses - Tuesday, Jan 16, 2007 at 18:08
G'day Mike, just reading your post I think you are saying with a higher ambient temperature the panels are more effective or am I misreading you? I thought that the hours of sunlight was the positive and the temperature increase a slight but increasing negative for effectiveness.
FollowupID: 475988
Follow Up By: Mike Harding - Tuesday, Jan 16, 2007 at 18:44
Hi John
Like most semiconductors, especially silicon based types, I believe photovoltaic cells become less efficient as their temperature rises (although in something like a MOSFET that may not be entirely true - depends what you want to do with it). My reference to temperature was more in regard to the ambient situation the fridge would have to cope with.
Mike Harding
FollowupID: 475997
Follow Up By: Member - Kiwi B - Tuesday, Jan 16, 2007 at 23:44
Yip' yer ryt here Mike. Was running a 50ltr Waeco last winter on a 65W BP panel. All was fine until the temps got to 35-40deg/C and it all went down hill. Wound-up needing to run gene more in Nov than in July/Aug and I'm pickin' due to ambient temperature.
My thoughts only,
FollowupID: 476107
Follow Up By: Robin - Wednesday, Jan 17, 2007 at 09:04
Yep , when the cell temps go up the voltage out drops a lot.
its easy to get 75c cell temp , and when cell temp goes from 25->75 the output volts drop from about 18 to 14v , wether or not this matters depends on your regulator.
Max power tracking regulators (which few have) are best but if not low volts drop regulators need to be used.
Robin Miller
FollowupID: 476139
Follow Up By: Member - JohnR (Vic)&Moses - Wednesday, Jan 17, 2007 at 10:00
Important to understand Robin. Thanks. Perhaps you can elaborate the ones that have the power tracking regulators so people don't get heading off just because some are cheaper.
Have read on other forums where information is based on price of the goods and not the price/benefit - or the lack there of! It is difficult to decipher good information from colloquial reports so frequently. Not just talk the talk, know what the talk means.
FollowupID: 476145
Follow Up By: Robin - Wednesday, Jan 17, 2007 at 11:38
Hi John
Sure is easy to get the gloss and not what's really relevant.
Probably shouldn't have mentioned MPPT solar regulators as
they are few and far between in Australia.
For those not sure of what I mean if a normal solar panel
puts out 18v at 1amp then its called an 18watt panel however
if battery is charging at 13v then its really only getting
13X1 or 13 watt and this is the real maximum.
Max Power Point regulators convert the 18v to the current batt
volts (13) at around 96% efficentcy and so the same panel can
actually deliver 1 1/3 amps or 30+ % more power via the MPPT.
The actually track both batt and panel voltages and re-adjust
themselves as these change (e.g.sun goes behind cloud).
In case like Ron's where he has an undersized panel then
he can just connect straight to a battery without a regulator
provided you monitor batt volts , as not a lot of chance he will
overcharge.
For set and forget though one should have a reg.
Robin Miller
FollowupID: 476158
Reply By: Robin - Tuesday, Jan 16, 2007 at 14:24
Hi Ron
Hard to say without any related info like how long and where it would be used.
40w would be marginal I think.
It would take years of camping use to pay for the panel cost in fuel used to recharge your battery via car fitted with proper 2nd battery charger.
Robin Miller
AnswerID: 215657
Follow Up By: Ron173 - Tuesday, Jan 16, 2007 at 14:37
I camp in nsw, sometimes in 40deg, but not often, I usually try to avoid the 3-4week hot hot spell, but I regularily camp in high 30's.
can you pls expand on your last sentence?
am I correct in thinking that your saying a panel will cost heaps more than a 2nd battery charger, and it'd be way to go?
If so how does that work / rough cost, I'm assuming this is an alternator beef up, and you run vehicle for 15mins a day or so?
You have me interested now
Ron
FollowupID: 475938
Follow Up By: Robin - Tuesday, Jan 16, 2007 at 15:11
Hi Ron
I see others have replied re- latitudes etc , so I will stick to cheapest way to re-charge for short stays.
The obvious straightforward way is to just run you engine for an hour or so each day and recharge car battery.
This works fine so long as you ensure engine idles fast enough to deliver 14V.
However re-charging a car battery fully takes a long time with a standard alternator, as high current intial charge soon drops as battery volts rise.
Many people with dual battery setups use a charger designed for the job and it charges faster after the intial rush and 1/2hr per day is enough to put back enough power so that system works for 3-4 days. (it does not put back 100% though in 1/2hr)
Usually in 3 /4 days people go for a drive and fridge gets extra charge anyway.
Similarly a cheap generator and charger ($200) can do it if you have them.
Also you can electrically trick alternator into giving more volts - but not reccomended unless you like to play around as some of us do.
Robin Miller
FollowupID: 475948
Follow Up By: Ron173 - Tuesday, Jan 16, 2007 at 15:36
Thanks Robin,
I have a dual system with isolator fitted which is auto change over, so guess thats the type of charger you refer to, my useage is fishing, so once we set up we dont go for drives.
Think I will go with a 50w kyocera, see below as its affordable and gives me extra 10w.
Cant wait for next camping trip now.
i love getting new toys!! LOL
Rgds
Ron
FollowupID: 475950
Reply By: Member - Jeff H (QLD) - Tuesday, Jan 16, 2007 at 15:28
G'day Ron. Don't know what prices you've been quoted.
Mate was quoted $900 for an 85w Kyocera.
Same item at a Tassie net site was$650 +$50 freight.
Someone on the forum had a similar experience with Tassie recently. Good luck.
AnswerID: 215666
Follow Up By: Ron173 - Tuesday, Jan 16, 2007 at 15:32
Yeah thanks mate,
checked that one out, could go to a 50w there for same money as a 40w elsewhere, so thats gotta be the go i think.
Mike are you reading this too, would you say 50w would do me comfortably?
Rgds
Ron
FollowupID: 475949
Follow Up By: Mike Harding - Tuesday, Jan 16, 2007 at 15:42
Sure am :)
For 3 or 4 days with a 50W panel and 85Ah battery I reckon you'd get away with it without a big drama - at the worst you may have to run the vehicle for 30 minutes or so on day 3 or 4. Just try to remember to move the panel 3 or 4 times a day to get the best sun.
With that Fluke you should be able to data log every nuance of the systems performance :)
Mike Harding
FollowupID: 475952
Follow Up By: Ron173 - Tuesday, Jan 16, 2007 at 15:56
Thanks Mike.
LOL fluke used for calibrating A to D converters and needed to be able to read to 3 dec places, you need to go a fair bit up range to get that.
Happy with the 50w kyocera, so should cook be!!
Rgds
Ron
FollowupID: 475959
Follow Up By: Zapper - Tuesday, Jan 16, 2007 at 16:14
Jeff whats the tassie web site you are referring to?
FollowupID: 475963
Follow Up By: Member - Jeff H (QLD) - Tuesday, Jan 16, 2007 at 16:36
Zapper, just took pot luck and googled 'tasmania solar panels'.
Someone else may possibly be more specific.
FollowupID: 475967
Follow Up By: Member - Jeff H (QLD) - Tuesday, Jan 16, 2007 at 16:40
Zapper, yep that works. 'Tasman Energy' , and check their specials.
FollowupID: 475968
Reply By: knight44 - Tuesday, Jan 16, 2007 at 15:34
Hi Ron,
We have a 40l Engel as well, but only a 55AH deep cycle battery to run it. When we're camping (stationary) and with the fridge setting at about 1.5, we get about 36 hours before the low-voltage cutout operates. You should get more than this with your 85AH battery.
I don't think a 40W panel will provide enough power to both re-charge your battery and run the fridge at the same time - but, if that's all you can afford at this time then go for it and see. The only recommendation I'd make is to buy a regulator that will handle 80Ws so that if the 40W panel is insufficient, then buy another 40W panel and use the two together.
I think as far as different brand panels are concerned, a watt is a watt etc. You can check the specs for the different brands, but I don't think you will find either a 38 or a 42 watt panel masquerading as a 40W, unlike your analogy with engines.
Richard
AnswerID: 215670
Follow Up By: Ron173 - Tuesday, Jan 16, 2007 at 15:39
Thanks Richard,
had to ask the question, I think I'm gonna go with a 50w kyocera now, so extra 10w up sleeve, same price as 40w bp so cook cant complain.
Rgds
Ron
FollowupID: 475951
Reply By: vcbb - Tuesday, Jan 16, 2007 at 17:28
What sort of price is the 50 watt Kyocera and where from ? I am interested in the size of the actual panels for storage, I was looking at the folding 80 watt (2x40) being sold by Fridge & Solar, as a kit for $950 with all the bits.
AnswerID: 215703
Follow Up By: Ron173 - Tuesday, Jan 16, 2007 at 17:39
Actual size is about 25 inches square, its not bang on square, one side is marginally longer, but thereabouts.
$420 inc postage
FollowupID: 475983
Follow Up By: vcbb - Tuesday, Jan 16, 2007 at 18:07
Whereabouts from, still need the regulator too, also my research, I couldnt find a 50 watt Kyocera panel
FollowupID: 475987
Follow Up By: Ron173 - Tuesday, Jan 16, 2007 at 18:21
The tassie site, says they were made late 2006, has spec sheet there from kyocera, selling 55w too, so maybe the 50w superceeded by 55w? spec on 50w says max 54w.
He only has 6 left... make that 5, my deals processing!
You still need a reg no matter what panel you get, I can prob build that though.
Rgds
Ron
FollowupID: 475991
Follow Up By: SA_Patrol - Tuesday, Jan 16, 2007 at 22:03
Independant batteries in Pooraka has the 80watt panels for $ 690
FollowupID: 476055
Reply By: Alloy c/t - Tuesday, Jan 16, 2007 at 18:43
Thing is that the variables are many ,IE: how much power does your fridge use ?? in an average scenario your Engle would use 1.9 amps per hr ergo 45.6 amps per 24hr period , no way will you get that amount of power back with only a 40 or even a 50 panel , even a total solar scab[ catching sunrise and constant tracking thru to sunset] would still leave you with a power deficit , as others have said ,when you buy your solar regulator dont skimp on amp"size" ,better to just add more panels rather than a bigger reg every time.
AnswerID: 215716
Follow Up By: Ron173 - Tuesday, Jan 16, 2007 at 20:23
Hmmm poss theory there but its gotta be better than present LOL!
If fridge draws .. you say 1.9.... spec 2.5, say 2.5 max, panel is producing over 3 amps, fridge doesnt run all time, at night even less, surely there has to be a surplus during day?
Ron
FollowupID: 476015
Follow Up By: Ron173 - Tuesday, Jan 16, 2007 at 21:29
I'd love to just buy whatever, but we all have to live to the best of our ability within our means.
I'm in no doubt that a humungous panel n reg would almost run my house, but I have limits to live within, so if it means a day less then it has to be.
I cant justify spending over budget with a family to support. (read wife to please)
I appreciate all the advice n comments, as always, but I'm gonna go with the 50w kyocera.
I will report back on its performance, and I will heed the info on getting the biggest regulator I can to allow for expansion, although I will never run more than my engel on it, only used for bush camping n fishing with kid/s n swag, when in full camp mode/caravan, its a different story, not to mention normally on powered sites, genny back up etc. if not, but a big thanks to you all.
Rgds
Ron
FollowupID: 476040
Follow Up By: Alloy c/t - Tuesday, Jan 16, 2007 at 21:57
Ron , tis simple maths ,ok your spec sheet for the fridge says 2.5 per hr and the panel you have you heart set on says 3 amp per , sun don't shine 24hrs per ,you best case in perfect weather of a 12/14 hr sunlight day is 42amps ,but your fridge as you say is not running all the time ,ok no problem ,thing is when it is actually on the "ON" cycle it is drawing close to 4 amps ,,, the 2.5 amp per hr stated in your spec sheet is the average amp draw per hr over a 24hr period ,ergo 60amps per 24hrs and your panel can replace what ?? 42 amps in perfect sunlight all day ,, still means a shortfall of a minimum of 18 amp hrs per 24 hrs = 1 short lived battery ,, yes you will get 3/4 days in perfect conditions , but you will be sorely peeved when the sun does not come out to play and the milk has curdled and the beer is hot because the heart is set on solar , solar requires maximum input in qty of amperage not the minimum $ otherwise it will disappoint .
FollowupID: 476054
Follow Up By: Ron173 - Wednesday, Jan 17, 2007 at 08:40
Alloy,
appreciate input....but cant agree totally.
The 2.5 amps stated by Engel is NOT an average it is a MAX, have a read on their page, its actually 0.5 - 2.5amps max. heres link
Site Link
I know motors draw more at startup, not the engel, it has soft start where the swing motor gradually works up to full stroke, this is provided by engel for that very reason, to eliminate high startup currents and hence reduce power consumption.
Also your calculation of 2.5 x 24 = 60 amps, this would be correct if my engel NEVER cut out, which as we all know is not true, in very hot temps it will run a lot but still cuts out, and at night it runs even less.
you say I will have a shortfall of 18amps per 24hrs worked out on your figures.
So if we agree that you are 1.5 amps over on my fridge x 24, theres a spare 36, so I'm 18 in credit, before we even take into account it doesnt run 24/7.
I run it at present and get by, running vehicle when needed, so I will be streets in front with the panel.
Batteries not a problem, I get them from a source that replaces them after a short life of very little use, and they are almost brand new, and cost is buttons.
I doubt I will ever have warm beer n curdled milk.
I run my engel in a certain way, will do a post reply at bottom rather than a follow up here, and will explain a bit more.
Ron
FollowupID: 476134
Follow Up By: Alloy c/t - Wednesday, Jan 17, 2007 at 18:28
Ron ,you are in for a dissapointment , I run a 15 lt Engle with fridge bag on setting 2 which equates to 2/4 deg c ,, all up power AVERAGE is 1.87 amp per hr ,cycling on/off which still means a 24hr total of 44.88 amps , NO way will you achieve that amp input with the panel size you have set , the only way that you could possibly do so is to stand behind the panel from sunrise thru to sunset and track the sun movement constantly ..... I have 2 panels ,a 64w Unisolar + a 125w Kycera ,in perfect weather I can get upto 12amps per hr so in theory in an 8hr day I can pump in 96 amps to my battery bank , NEVER EVER happened yet ,very best = 72.4 amp ,,, as I said earlier ,you will be dissapointed and feel "cheated' , done properly solar is tops ,thing is to do it properly you need to increase your budget.
FollowupID: 476257
Follow Up By: Ron173 - Wednesday, Jan 17, 2007 at 20:37
Alloy,
I wont feel cheated mate, like I said its gotta be a big improvement on what I have now, which actually works with a bit of vehicle running.
I have got a 10amp regulator which means as finances dictate, I can buy another panel and have a 100w folding affair, in time I may even buy a 120a/hr battery but the point is its progression on present setup.
I'd love to go buy a 125w panel and AGM battery etc. but truth is some of us have to live by our means, so these things will come in time.
I have 2 4wds, a caravan, and a boat, and a good boat at that, (30k worth) capable of fishing skiing etc., and its all paid for. So I'm just building my collection of accesories slowly and as I see fit.
I will get a panel setup that is socially accepted here someday.
Rgds
Ron
FollowupID: 476299
Reply By: Derek from Affordable Batteries & Radiators - Tuesday, Jan 16, 2007 at 22:16
Hi Ron,
I am going to put a spanner in the works here.
Solar is very expensive and best not to cut corners.
I sell 100's of panels and won't push them on people with a limited budget.
If you are on a budget it would be best to buy another 2x MRV70 105 a/h batteries and this would give you 295 amp hours and should cost around $300.00 for the MRV70's.
This would run the 40L ONLY for around 5 to 7 days. (Depending on temp)
If you don't stay longer than a week this is a cheaper option and you can always add a panel later.
I spent a few hours with an older gent a few months back and we worked out that this was a better option for people who are away for up to 5 days in one place and then move on. If you plan to stay for more then 7 days then solar power or a generator is a good option. In any case 85 a/h is a small battery bank to use solar on when running a fridge.
Derek.
AnswerID: 215770
Reply By: Member - Jeff H (QLD) - Wednesday, Jan 17, 2007 at 00:15
Ron173, I reckon you've done well with your question. No one got s. faced, and your choice of the 50w won't be regretted.
Both 'knight44' (10a reg) and Alloy(tracking), were spot on.
I reckon you may not replace all charge over 24hrs, but even if you half charge each day,it's going to either extend your camping time OR vastly extend the life of your battery.
Plus you have a power source (paid for up front), for 20+ years.
Look forward to your performance reports.
Avoid debts, travel well. Jeff.H.
AnswerID: 215802
Reply By: Ron173 - Wednesday, Jan 17, 2007 at 09:00
G'day all
Thanks for all replies, as usual ALL appreciated and very interesting.
Derek your battery theory is good but I dont wish nor have room for another 2 batteries.
Re power consumption etc, see my follow up to Alloy c/t's figures.
Also prhaps the way I run my engel may make difference too:-
I have 2 85a/hr deep cycle batts, one in vehicle as dual battery at any one time other on float charger with pulse.
Before I leave I swap batteries over, so I have as FULLY charged battery as poss to start. This does make a difference as float charger gets it up higher than vehicle can.
My engel is run as a freezer on position 3, I run it on 240v at least a day before to allow it to cool n soak into insulation. It also has the bag on it.
I have a Tropical ice box, only small 37ltr, which I use 1ltr flat block ice containers in, usually 8 of, these are pre frozen too, and a spare 4 in engel. This is my fridge, for soft drinks / beer / cool food. It is always very cold, and beer is superb from it. Frozen food in engel.
I run engel as full as possible, to provide ballast. during day it reaches -9degc, at night gets down to -18degc, which provides a buffer for the heat of day.
Every morning I swap 4 bottles frozen solid out of engel into esky, and 4 slightly defrosted back into engel. Then its not such a big ask to refreeze them.
Any food for that evening goes into esky to defrost and impart its cold to the esky.
This is my routine at present, I have a batt monitor, and run vehicle for 20mins at 2000rpm when it shows reqd, which can be 2-3 times a day if very hot.
This works. I'm doing it at present. So with a panel if I have to run vehicle on day 3 or 4, thats a huge advance on present.
I'll be going out in a fortnight or so, for a long weekend, so will do a report on my performance as I find it.
regards
Ron
AnswerID: 215834
Follow Up By: Scoof - Wednesday, Jan 17, 2007 at 10:13
Hi Ron ,
Great to read all the reply's, it will be great to also read the report on how it all went with the new panel.
Cheers Scoof..:-)
FollowupID: 476147
Follow Up By: Ron173 - Wednesday, Jan 17, 2007 at 10:27
Scoof,
thanks, I will post it headed '50w kyocera report', so keep a look out for it.
I'll try to be as accurate as possible and will try to provide voltage levels and ambient temps and my fridge temp, and will post it 'fair dinkum' as it happens.
if I end up running vehicle on day 2, I'll report it so.
Safe travels to all
Rgds
Ron
FollowupID: 476148
Reply By: Leroy - Wednesday, Jan 17, 2007 at 09:13
Jimbo,
Why have you not made a comment as you have a 60w pannel and did extensive research into this subject?
Leroy
AnswerID: 215837
Reply By: vcbb - Wednesday, Jan 17, 2007 at 10:31
What site in Tassie were the panels available from
AnswerID: 215850
Follow Up By: Ron173 - Wednesday, Jan 17, 2007 at 21:04
Not sure of exact link, but look up tasman energy on google, will produce the goods.
Ron
FollowupID: 476305
