6mm wire for fridge hole in trailer
Submitted: Tuesday, Jan 16, 2007 at 13:53
pixiemops
Hi guys
This may seem a silly question but I want to know what is the best way to protect a 6mm twin wire that I intend too feed through a hole in the side or bottom of a trailer.
I will drill the hole then feed the wire through but then what do i do to stop the wire rubbing raw etc. I thought put some silicon there but don't think that would be too good .
Reply By: Member - Toytruck (SA) - Tuesday, Jan 16, 2007 at 13:56
pixiemops,
a rubber gland to accomodate the wire and hole drilled to suit. This will pretty much water/dust proof it also.
Toytruck
215645
Reply By: vcbb - Tuesday, Jan 16, 2007 at 14:01
I picked up some rubber grommets from the local hardware store and it did the job
215649
Follow Up By: pixiemops - Tuesday, Jan 16, 2007 at 14:03
wow that was fast thanks alot guys for your help
475929
Reply By: Member - Toytruck (SA) - Tuesday, Jan 16, 2007 at 14:10
pixiemops,
as you can see this
forum is a wealth of expert and expedient information....ha ha ha ha ha ha.
Toytruck
215653
Reply By: Shaker - Tuesday, Jan 16, 2007 at 14:40
If it is in the body, for a few cents you get dust &
water proof compression glands from any electrical wholesaler like Middendorps etc.
215658
