Fridge Storage.
Submitted: Monday, Jan 22, 2007 at 20:24
ThreadID: 41514 Views:3635 Replies:15 FollowUps:6
I have a Engle 40lt fridge ,
I always give it a good clean out and let air dry before I store it in the garage , the problem is usually when I get it out again it smells kind of musty . I keep it closed cause I dont like the idea of things living in it.
What do others do to keep their fridges smelling normal in storage , I hate cleaning it before and after use !
Thanks ,
Glenn.
Reply By: roosey - Monday, Jan 22, 2007 at 20:34
Glenn.
Simple answer keep it open, it's the only way I know.
Roosey
AnswerID: 217119
Follow Up By: Sand Man (SA) - Tuesday, Jan 23, 2007 at 07:29
Yep,
I agree, keep it open for one or two days, until all moisture has had a chance to evaperate.
I do the same with my icebox and have never had problems from smell or mould.
Bill
FollowupID: 477633
Reply By: Kev M (NSW) - Monday, Jan 22, 2007 at 20:38
I leave some Bicarb Soda in mine. It seems to keep the smell to a minimum.
Cheers Kev
Russell Coight:
AnswerID: 217120
Reply By: Philip A - Monday, Jan 22, 2007 at 20:53
Deodorant that I keep in mine is BEER.
Engel recommends that you run them on 240V between trips,so what better use.
Regard s Philip A
AnswerID: 217122
Follow Up By: Member - Jeff H (QLD) - Tuesday, Jan 23, 2007 at 02:45
You rotten mongrel drunkard: maybe a long lost rellie!! hahahaha. Yes!
FollowupID: 477614
Reply By: Crocks - Monday, Jan 22, 2007 at 21:10
G'day Glenn,
After cleaning and wiping it dry, spray it with Vanilla Fridge Wipe.
Kills odours and smells good. Always store fridge with lid open a bit so air can get in. Nothing will live in it.
I hope this helps.
Crocks.
AnswerID: 217125
Follow Up By: Member - Vince B (NSW) - Monday, Jan 22, 2007 at 21:18
Hi Glen.
Ialso use vanilla once the fridge is cleaned.
FollowupID: 477559
Follow Up By: Member - Pedro the One (QLD) - Monday, Jan 22, 2007 at 22:25
Me, too with the Vanilla Fridge Wipe !!!
Also handy in the Baileys/EvaKool iceboxes ..........
And also keep my Engels running on 240v in THE SHED, filled with 3litre juice bottles of frozen water [ we call it ice, love!] which is perfect for the next fishing trip in the tinnie ...... and when defrosted, doubles as drinking water for me und der Beagle!!!
FollowupID: 477579
Reply By: Member - Phil G (SA) - Monday, Jan 22, 2007 at 21:20
Mine lives in the truck with the lid off.
AnswerID: 217127
Reply By: Red One - Monday, Jan 22, 2007 at 21:30
Fill it full of beer and don't turn it off.
Easy
AnswerID: 217128
Reply By: Member - Oldplodder (QLD) - Monday, Jan 22, 2007 at 21:48
Always store ours with the lid off in the store room under the house.
Give it a wipe out before we use it.
Use some lemon juice to wipe it out.
AnswerID: 217136
Reply By: Member - Stephen M (NSW) - Monday, Jan 22, 2007 at 22:00
Myns on 24/7 was told better to run it then let it sit around. Sits under my pergola with nice coldies at the go. Not sure how true this is or wether it's more for the gas ones as have heard on here they sort of glag up and need turning upside down for a while to get them going obviously not an issue with the engels or waeco's. I just wipe myn out once a fort night with chux cloth and soapy water. No problems or smells YET. Regards Steve M
AnswerID: 217142
Reply By: Member - Ivan (ACT) - Monday, Jan 22, 2007 at 22:15
I wipe mine out when I get home and then put a stubby cooler in the front of the lid - keeps it open enough to keep the smells away - nothing growing in it either ;-)
AnswerID: 217146
Reply By: mike w (WA) - Monday, Jan 22, 2007 at 22:16
Leave mine on 24/7. Usually put a few bottles of water, beers (when I forgo a weeks food inplace) and works sweet. I leave it on the 1 setting, and it cycles between 3.8 and 5 degrees depending on temperature (sits infront of a window)
Just had a look at the manual, and Engel recommends that quote:
"A suggestion is to utilise your engel as a second freezer/fridge or bar fridge at home during these periods (storage)"
AnswerID: 217147
Reply By: Member - AU-2 - Tuesday, Jan 23, 2007 at 00:32
We have an 80 ltr Engel, fairly new, which was used to keep seafood chilled for Xmas, somehow it was left with fishy smelling water in the bottom for 2 weeks afterwards. Nearly knocked our socks off when we opened it! After reading about Bio-magic on this forum, I bought a small bottle to try out in our Porta loo. Made up a brew per the instructions and poured about 1 litre of it into Engel, left it for 1/2 hr, wiped it out, now smells sweet once again, you'd never know fish had been near it.
We will be trying it out in the Porta loo in 2 weeks for the first time, will post results then.
OzeSheila.
AnswerID: 217173
Follow Up By: Max - Sydney - Tuesday, Jan 23, 2007 at 16:57
Hi OS - we've just ordered a starter pack of Biomagic too. Mainly wanted to get rid of the "scenty" smells of the Portapottie and be able to empty it in caravan parks with septic systems, but am intrigued with the cleaning uses too.
Look forward to your feedback.
Max
FollowupID: 477728
Reply By: Steve63 - Tuesday, Jan 23, 2007 at 10:03
I do the same as you and only get a plastic type smell. Basically the same as a new fridge even from the one that is 10 years old. The main thing is to try and prevent spillage in the first place. This is particularly true for meat products. I get meat Vac Packed by the butcher. This helps a lot. If anything has leaked I wash it out with detergent two days in a row then let it air dry for 3 or 4 days. I know that sounds a lot but it seems to be how long it takes. If the air is very humid this may be contributing to your problem. I would resist the urge to use any strong bleach type products as it tends to damage the plastic surfaces and in the end just give bacteria another place to hide. Our fridges are stored closed but not in an overly hot area.
Steve
AnswerID: 217217
Follow Up By: Max - Sydney - Tuesday, Jan 23, 2007 at 16:54
We've washed one of the larger of those trays that meat comes in from the supermarket these days. All meat sits in it as we use the fridge as a freezer when travelling. That solves the meat juices in the bottom problem.
After trips, we wipe the fridge out, take the lid off and put the travel cover over it and store it in the shed. Never had any greebies make their home there. Just bring it in and freeze a couple of litres of water to get the fridge right down to temp 24 hours before we leave.
Been fine for almost 4 years doing that.
Max
FollowupID: 477727
Reply By: Member - Glenn D (NSW) - Tuesday, Jan 23, 2007 at 20:19
Thanks everyone,
Am going to give it the vanilla fridge wipe treatment , then air it out , then put some baking soda in it !
Glenn.
AnswerID: 217328
Reply By: Muzzgit [WA] - Wednesday, Jan 24, 2007 at 00:44
I wipe my fridge out, take the lid off and keep the fridge under the pool table. No smellies for us.
AnswerID: 217403
Reply By: Ron173 - Thursday, Jan 25, 2007 at 15:07
I keep my 40ltr in a cupboard inside, to stop smells, I put a small piece of pencil eraser on the edge of lid, which keeps it open by an inch or so to stop smells forming.
Any small item would do, I just find the eraser fits without sitting on the seal.
Ron
AnswerID: 217765
