airlocker vs prolocker
Submitted: Tuesday, Jan 23, 2007 at 10:31
DJK
has anyone had any experience with either of the above dif locks... I will be putting into back of v8 Landcruiser..
Reply By: Robin - Tuesday, Jan 23, 2007 at 11:02
Used a few , got a couple of airlockers in my petrol patrol.
All good , except for odd air leaks , one in the rear doesn't do much.
Robin Miller
217228
Follow Up By: GoneTroppo Member (FNQ) - Tuesday, Jan 23, 2007 at 11:23
Had twin airlockers on three vehicles now.
Trouble free except for some air leaks on early unit 1995, fixed under wararnty.
Also lack of some sort of non return valve sucked small amount of diff oil up to compressor. Again quickly fixed. (this was after very heavy and prolonged usage, more that most would ever experience)
477671
Follow Up By: Member -Signman - Tuesday, Jan 23, 2007 at 12:21
Hi Robin
You say 'one in the rear doesn't do much'.. In my vehicle I have to engage the REAR locker before I can engage the FRONT locker..is this normal???
Also, like others..air leaks into diff (seal o-rings stuffed??) and diff oil vapour back thru the solenoid..
Apart from that..all good.
477677
Follow Up By: Middle Jeff - Tuesday, Jan 23, 2007 at 12:50
Hi Signman
The default wiring is to have rear on befor you can turn on the front, it is not hard to change, if you look at the wiring diagram it is easy to work out.
I did
mine so If I have to climb a ledge on a bit of an angle you turn the rear of to stop it from crabing, pretty rare but have done it a few times.
Have fun
Craig
477682
Follow Up By: Robin - Tuesday, Jan 23, 2007 at 12:56
Hi Signman
The reason you have to engage rear first is simply because on how wiring loom was done .
Its politically correct from ARB's point of view to go rear first.
Your flexibility is reduced because it is perceived to be safer that way.
I could go on about this , but simply ask the question "What about when you need to use lockers in reverse".
Just changing loom to link switches to power instead of via rear locker relay will fix.
Did my own install , and took more time to get air inlet up high , and care with O-ring , as its easy to get it wrong.
No oils issues ever.
Robin Miller
477683
Reply By: Dave from P7OFFROAD Accredited Driver Training - Tuesday, Jan 23, 2007 at 14:24
We have a Prolocker in the front of the Company GU. I have had no problems with it.
217254
Reply By: Truckster (Vic) - Tuesday, Jan 23, 2007 at 16:33
Theres a thread on OL with a dude with issues on a Prolocker - wont unlock..
Not sure where hes at with it
They are both as good as each other with + and -.. I'll go ARB again when I get one, as I never had a problem in the past... Unless Alan decides to do me an unbeatable deal on one :) Come on buddy, I know your reading this...
217267
