GU Rear Wheel Bearing?
Submitted: Tuesday, Jan 23, 2007 at 18:42
ThreadID: 41542 Views:2577 Replies:4 FollowUps:2
G'day All
After a weekend of playing in the mud, I have a tinny scraping noise coming from the driver side rear wheel area, that is more noticeable when I go around left hand corners. I took the wheel off and washed the area out thoroughly , but each time I try to turn it I get the scraping noise and it is particularly difficult to turn in one spot and I can not see anything scraping on the brake disc. Any suggestions gratefully appreciated.
Thanks in Advance
Snowy
Reply By: David from David and Justine Olsen's 4WD Tag-Along - Tuesday, Jan 23, 2007 at 18:55
Is there something jammed between the backing plate and the disc or the backing plate bent?
AnswerID: 217305
Follow Up By: Snowy 3.0iTD - Tuesday, Jan 23, 2007 at 18:59
No backing plate is straight and clean.
FollowupID: 477764
Reply By: Red One - Tuesday, Jan 23, 2007 at 18:56
Had the same thing happen where a stone lodged between the disc guard & the disc.
NRMA said that the wheel hub etc would have to be removed to get it out.
Found a wedge shaped piece of wood and force the guard away from the disc and out came the stone.
AnswerID: 217307
Reply By: Snowy 3.0iTD - Tuesday, Jan 23, 2007 at 19:14
Upon further investigation there is also a rumbling to go with it, so I suspect a wheel-bearing on the way out, thanks for the input though guys.
Snowy
AnswerID: 217310
Follow Up By: joc45 - Tuesday, Jan 23, 2007 at 19:44
Just had to replace one of mine on my GU. The inner seal had leaked, which diluted the grease in the bearing, which in turn forced grease out of the outer bearing and over the brake. Some evidence of surface scoring, so the bearing was replaced. Too big a job for me, so had a guy do it - Nissan price for bearing was about $290, had a non-Nissan bearing put in (<$150). Maybe could have chased it up cheaper myself, but happy with job.
Gerry
FollowupID: 477773
Reply By: Leroy - Wednesday, Jan 24, 2007 at 09:06
Ah playing in the mud will do it. I had one of mine changed fortunately just before a trek to the cape a few years ago. Lucky enough to get it under warranty. The bearing that came out was bathing in a pool of brown sluge - a combination of grease and brown muddy water.
Leroy
AnswerID: 217432
