Landcruiser 80 series sub fuel tank
Submitted: Monday, Mar 31, 2003 at 23:56
Andi
A mate of
mine has just purchased an 80 series Landcruiser Advantage (1995) and it has a sub fuel
tank. We have tried to fillthis
tank but cannot do so, there is definately something happening when pull the plug out to change the filling
tank but the obviously there is some sort of blockage, or something we are missing. And yes we flick the lever inside the car first.
Would anyoneknow anything about this.. and if so I would appreciate your comments.
Andi from Victoria
Reply By: Member - Chris - Tuesday, Apr 01, 2003 at 00:53
Andi,
So when you go to fill the sub
tank (with the lever pulled outwards) the bowser keeps shutting off?
You should here a distinct light thump when pulling the lever out which is the flap/valve switching position for transfer of fuel to the sub
tank. If you pull the lever 'fully' outwards and it comes out easy or with no noise there must be a problem with the mechanism.
I've never come across the problem but try "80 series owners online" which is a pretty good website for solving problems etc.
All the bestLove the bush.
Chris
16546
Reply By: tour boy - Tuesday, Apr 01, 2003 at 06:53
Quick question. Is the
tank full and the wire come off the gauge?
16555
Reply By: Kev. - Tuesday, Apr 01, 2003 at 09:29
When he does get it working i would check the filters after using the sub-
tank.
This may have not worked for years and could have stale fuel or rust ect.
If its a diesel you could have other problems like alge or
water from condensation.
BTW- if you want to check if the
tank is full and the gauge reading wrong just jump under and tap on the
tank.
Kev.
16571
Reply By: Andi - Friday, Apr 04, 2003 at 12:04
Thanks guys for help we found part of switching value mechansim to open the sub fuel
tank for filling was bent. We used a bit of WD-40 and brute strength to strighten the rod and fixed it.
He will run it around at
easter using the fuel out of the sub
tank and then we will change the fuel filters as suggested in case the
tank hasn't
been used for a while.
Once again thanks for you help and suggestions!
16866
