Site Search
Section Image
uhf aerials
Submitted: Tuesday, Apr 01, 2003 at 00:06
Mike
I have a GME 4400 uhf radio, I am going to buy a 6.5db ground independent aerial.........Question, which is the best brand to buy?, I was told Polar is a good one.......regards Mike.
Advertisement
ThreadID: 4158 Replies: 4
Views: 516 FollowUps: 1
AnswerID: 16551   Submitted: Tuesday, Apr 01, 2003 at 02:19
Member - Wayne replied:
I am no expert on radios but I have the electrophone 6.5db ground independant on my TX4400. I figure if they build a great radio, I might as well trust their aerial too % %:-) %
Reply 1 of 4
AnswerID: 16552   Submitted: Tuesday, Apr 01, 2003 at 02:20
I am no expert on radios but I have the electrophone 6.5db ground independant on my TX4400. I figure if they build a great radio, I might as well trust their aerial too.
wayne % %:-) %
Reply 2 of 4
AnswerID: 16595   Submitted: Tuesday, Apr 01, 2003 at 12:43
Jarrod replied:
G'day Mike,
Two brands to recommend in the type of antenna you have decided on. Polar, as you have suggested is an excellent antenna, We use them on nearly all of our work cars ( marked police vehicles!!) as is RFI or RF industries. ( I think this one is available thru Dick smith) well used to be anyway. Was about $80, My advice would be to also buy a base mounting spring.
When you say Ground independant I assume you mean the 200mm (or so) "chrome tube" that a normal 5/8ths co -linear ( stainless steel or fibreglass antenna, about 500mm overall length, with a coil just under 1/2 way up) type setup ?? - these are an excellent choice, when mounted on a bullbar. Both the above antennae are very rugged, and only use quality components. I've had the RFI version, and it's been on my last 4 cars !! never had a problem with it. Ive got the Stainless antenna on mine, with the spring, has bounced straight back following a roo strike at 80Kph. ( can't say the same for the TJM bar) 100 series now has ARB!!! If youre' going to terminate the co-ax yourself, pay particular attention to the instructions, with regard to lengths of braid, inner insulation/conductor etc. If youve not done this before, I would strongly reccommend you buy the antenna with the co-ax already fitted. Remember, when fitting, heaps of silicone around the bottom of the antenna, where the coax runs up inside the shaft of the chrome tube. - I've had a few apart, and found that water had "wicked" up into the internals, causing corrosion and internal problems. Not good for comms at all, and cable ties to keep the co-ax from slapping around or rubbing through any barwork or body metal.
Hope this helps,
Jarrod.
Reply 3 of 4
FollowupID: 10245   Submitted: Tuesday, Apr 01, 2003 at 15:40
nbi posted:
G'day Jarrod,
Just read your reply about the aerials, just out of interest was the TJM bullbar an alloy or steel bar? The T15 (?) winch bar or something else, I only ask because I'm trying to decide which bar to go with. I'm planning side-rails and step as well and also hoping to fit water tanks under, which may be a problem with the side-rail/step setup. Thanks Neil.
AnswerID: 16635   Submitted: Tuesday, Apr 01, 2003 at 20:05
Bob replied:
Mike,
Polar are pretty hard to beat, for their size. You can always unscrew the whip, and put on a 6" unity gain, for clearance etc. Hooroo...
Reply 4 of 4
Activities Index
Sydney & Harbour Bridge Ride Cycle Tour Sydney & Harbour Bridge Ride Cycle Tour
Sydney - NSW
Experience a great way to see the sights, learn about Sydney's history, ride through historic neighb
Barista Basics Course - Melbourne Barista Basics Course - Melbourne
Melbourne - VIC
Are you passionate about coffee and want to learn how to make really great coffee?
Penguins EXPRESS! (354) Penguins EXPRESS! (354)
Phillip Island and Gippsland - VIC
An evening tour for those with time constraints that takes you directly to the natural phenomenon of
 	 Cooking Class In Thai Cuisine Cooking Class In Thai Cuisine
Melbourne - VIC
Ever wanted to learn how to cook Authentic Thai?
Book Now - Things To Do
