80 Series - Oil Usage
Submitted: Thursday, Jan 25, 2007 at 08:50
Member - John K (VIC)
Guys
I hope someone can help me with a question about oil being sucked into the motor from the rocker cover. I have a 1991 Turbo Diesel. After 500,000km I had the motor completely rebuilt including overhaul of the pump, injectors and turbo.
At the last 10,000k service I noticed the oil level slightly down and fresh oil being drawn in through the bypass hose connecting the rocker cover to intake duct/inlet manifold. Local Toyota mechanic indicated that the tabs inside the rocker cover need to be closed to 10mm or less to prevent oil being drawn through the bypass hose. The tabs were checked and found to be only 2-3mm gapped.
I checked this problem with other local Turbo Cruiser owners who have no oil issues.
Can anyone advise me how to fix this problem.
Reply By: Wayne-o - Thursday, Jan 25, 2007 at 10:08
Hi john,
one thing that can cause the oil to be forced through the bypass into the air ducting is blow back through the sump, usually and indication on worn rings, although in your case i hope not only 10k out of a rebuild. Although if the motor was not run in correctly, ie the
bore was not sufficiantly scored, there may be some blow back (pressurisation of the sump). Suggest a compression test to confirm. and a word to the bloke who did the rebuild should be under warranty i would think. But what ever you do, don't tap that bypass line off, i have seen it done....what a mess!
Good luck pal, let me know how you go!
cheers,
the Wayne-o
217685
Reply By: Member - Davoe (Nullagine) - Thursday, Jan 25, 2007 at 11:10
Im with wayne - its not just cruisers but in any vehicle it indicates blow by from worn rings. My ihz does it (230k) but it does not use any significant amount of oil
217710
Reply By: Member - John K (VIC) - Thursday, Jan 25, 2007 at 11:41
Thanks Davo & Wayne
Motor has 1 year unlimited warranty. Have taken vehicle back to engine rebuilders for checking. Both compression and leak down test confirmed that there were no issues with rings and they have confirmed that no excess blowby is evident.
Strictly followed warranty conditions for running in motor.
217720
Reply By: Member - DOZER- Thursday, Jan 25, 2007 at 14:51
Best way to check is to put a
water trap in that line and see what amount of oil you catch. It could be oil leaking from the turbo seal aswell....why do u think it is the bypass supplying the oil if there is no bypass?? When the turbo is on song, there is alot more compression in there, id suggest the most probable reason is the bores/rings...but a oil catch can as sold on ebay, or the
water trap wioll show it up.
217760
Reply By: luch - Thursday, Jan 25, 2007 at 17:04
My old 80 series 1HZ had those tabs open enough to put your finger inside, closed them up to 1 or 2 mm my oil consumption went from 1 litre per 5000kms to nothing.
i did find before this that some oils burnt fast my best result was Castrol RX Super
Check with your mechanic and try a different oil
How much are you Using ?
217781
Follow Up By: Member - John K (VIC) - Thursday, Jan 25, 2007 at 17:56
Approx. half litre in 5000k. Local diesel mechanic also suggested a change of oil. He also checked turbo, however, as the turbo was completely rebuilt in July 2006 he was of the opinion that the turbo was not the problem.
I will try change of oil.
478225
Reply By: Merce - Thursday, Jan 25, 2007 at 22:24
John,
I am a Diesel mechanic and own a 80 series with a 1hdt engine which I rebuilt in november. These engines have a small brass restrictor in the oil feed to the head from the block. This part is very small and sits in the block. I didn't even notice it when I pulled it apart and cleaned the engine down. When i was about to put the engine back together a guy I work with told me about the restrictor(as he put one back together a few years back) so i had to order one as
mine had gone missing. When i spoke to the place where the block, crank and head were done they didn't even know about it until they looked up their parts list. If this restrictor is not fitted 3-4 times as much oil ends up in the head which travels down the bypass hose and through the engine. If the engine didn't use oil down the bypass before the rebuild i can't see how it could be the rocker cover. It may not be this but you may have trouble getting this fixed as it is a big job to take the head back off. Good luck.
217840
Follow Up By: Member - John K (VIC) - Friday, Jan 26, 2007 at 08:33
Thanks for your comments. Prior to the rebuild, there was a small amount of oil but nothing like the amount now. Just rang the mechanic and engine rebuilder to ask about the brass restrictor. neither can confirm whether the piece was there? The rebuilder is willing to take the head off to check if the problem persists and change of oil type doesn't improve things.
478283
Follow Up By: Merce - Sunday, Jan 28, 2007 at 16:02
If they didn't see it and they had the engine apart there is a good chance it's not in there. Its good to see they are prepared to check.
478623
Reply By: thomasando - Friday, Jan 26, 2007 at 17:52
Mine typically uses about 1L per 1200km or so (300,000km). It's better on long highway runs (about half that at a guess). It was suggested some time ago that I check and adjust the tabs inside the rocker cover - it probably wont help in my case, however as I think I may have bigger issues. Never got around to doing it until today. Go to do it today and get all the bolts/nuts out/off, but the head wont come off - the A/C pipe that runs along the firewall seems it may have been repaired. There is, what looks like, a pipe joiner right in line with the rear right nut (as you stand at front of engine looking to back), and it is just the right size that it prevents me from getting the rocker cover off.
Does anybody else have this (ie. is it a standard fixture), or is it something specific to my truck only? I must say I was disappointed that I couldn't get it all apart!
Also, where does one buy Castrol RX Super? I've had it recommended to try, but I can't find it at Autobarn, Repco or Super Cheap. There's a few other independent auto shops where I live, but I haven't tried them yet. Any tips?
217927
Follow Up By: luch - Monday, Jan 29, 2007 at 18:49
Burson Auto parts
Super cheap auto
sell Castrol products
478844
