Site Search
Section Image
David - follow up Message No. wanted
Submitted: Friday, Feb 02, 2007 at 04:40
Member - Arkay (SA)
When someone replies to a message (etc.) that one puts up on the site, you get a message back which quotes, amongst other things, a Follow Up ID number and an Answer ID number. I would find it most helpful if we also got an Original Message ID number, so that one can easily go back to that message and pick up the thread. Or am I missing something? Does anyone else have this problem, or a solution to it?
If you're not living on the edge you're taking up too much space
Advertisement
ThreadID: 41874 Replies: 4
Views: 631 FollowUps: 3
AnswerID: 219148   Submitted: Friday, Feb 02, 2007 at 06:17
Oz Travellers replied:
Ummm maybe I am just being blonde but this is at the top of your post
David - follow up Message No. wanted PostID: 41874
and on the left side where I clicked to read the messages the same number 41874
Carolyn
Click Image to Enlarge
Where to go and what to see next........?
Reply 1 of 4
AnswerID: 219149   Submitted: Friday, Feb 02, 2007 at 06:27
Wayne (NSW) replied:
Arkay,
I assume that you are reading this reply as a email that has been sent to you.
At the very top is the POST ID, in this case 41874.
If you then go to the part just before the start of the reply from me you will see "Response On line". Click here and the thread will appear.
I hope this helps.
Wayne
Canning Stock Route 2009
Good - Better - Best
Never Let It Rest
Till Your Good Is Better
And Your Better Best
VKS Mobile 2292
Reply 2 of 4
AnswerID: 219163   Submitted: Friday, Feb 02, 2007 at 08:13
Robin replied:
Have had similar issue Arkay , when look at my email list summary . It shows a number of posts but without reference to the message number.
E.G. this is what appears under hotmail -->
" ExplorOz Forum FollowupID: 479582 to AnswerID: 218975 fr... Feb 1 5KB "
(the above contains two fields "from and subject")
Whilst you can open each email in turn and it will display message number its not the most efficent approach, when you have a number of replies.
There are compromizes to appreciate in each of these things and its good to ask the question ->
What is the user trying to get out of his email summary ? And what is less important and can be left to when the actual email is opened.
I believe knowing which message the email refers to should have highest priority.
But whats constitutes "knowing" ?
The current system makes a direct connection to your previous posting(message or answer) however that connection is effectivily often devalued because know one would remember there last answer ID number anyway, so little real information is conveyed.
You could apply this logic to the actual message number as well and while the connection with a message number (post id in this forum) is limited, it is remembered more than an answer ID number, particularly as the more replies you get will re-inforce its memory.
You could then say , why not display the message title, as this would enable most to clearly identify the message . Issue here is that the limited text spaces as per my above example gives little room for more than a few words.
So in summary for this post I think following would convey more useful information to the user and takes up the same number of character spaces
Current way
Alternative way
Message 41784 " David - follow up Messa ...............
The value of the alternative way is devalued also as a message becomes longer with many replies and further as a message breaks off into another subect , however what it is being compared with is a number which if it is an answer ID number has almost no connections .
Robin Miller
Reply 3 of 4
FollowupID: 479828   Submitted: Friday, Feb 02, 2007 at 17:40
ExplorOz Team - David posted:
Robin,
Well though out response. I see what you are saying. Basically put up the main PostID and the topic regardless of whether it is a reply or followup. Just always maintain the same elements in the Subject field. Is this correct - I can this simply let me know also see my response to Arkay below.
David & Michelle
Always working, not enough travelling ;-)
FollowUp 1 of 2
FollowupID: 479862   Submitted: Friday, Feb 02, 2007 at 19:43
Robin posted:
Yes David Just ID the then subject.
The essential reason being because it conveys useful information.
In looking down a long list of emails , you can see the replies relevant to any given topic, whereas the Follow up and Answer Id's have a much looser relationship, and in fact can't be related easily to each other if you follow up to, two replies in any given post.
The followup and Answer ID should however been in the email that is then opened.
I would like to see Akay's input about the two different ways.
Robin Miller
FollowUp 2 of 2
AnswerID: 219199   Submitted: Friday, Feb 02, 2007 at 11:18
ExplorOz Team - David replied:
Arkay,
I understand what you are saying maybe I could simply add the main PostID at the beginning of the subject so somthing along the line of:
PostID: XXXXXX - FollowupID: 479720 to AnswerID: 219188.
Would that solve it for you. Then you could sort on subject and the system should put the element of the system together. Let me know - I can make this change easliy.
David & Michelle
Reply 4 of 4
FollowupID: 479847   Submitted: Friday, Feb 02, 2007 at 18:59
Member - Arkay (SA) posted:
This last solution would be beaut. Would help dumb lazy bunnies like me... Post ID, Followup ID, Answer ID. But don't spend precious hours on it if there is not much demand. Thanks for bothering to answer.
Activities Index
Barrington Tops Private Charter 4WD Ecotour for 2 Barrington Tops Private Charter 4WD Ecotour f
Sydney - NSW
A full day exploring the scenic edge of the Hunter Valley, and climbing to over 4000ft above sea lev
3 Day Six Foot Track Guided Walk 3 Day Six Foot Track Guided Walk
Blue Mountains - NSW
3 day guided walk of the famous Six Foot Track from the Blue Mountains to Jenolan Caves.
Aphrodite Body Indulgence (2.25 hours) Aphrodite Body Indulgence (2.25 hours)
Townsville Region - QLD
Relax while our nurturing beauty therapist pampers you from top to toe with a full Body Massage,a fu
BBQ Christmas Feast Class - Sydney BBQ Christmas Feast Class - Sydney
Sydney - NSW
Do you fancy cooking up a BBQ feast at Christmas? Then this is the class for you.
Book Now - Things To Do
