FollowupID: 480679 Submitted:
Tuesday, Feb 06, 2007 at 09:07
Member - Glenn D (NSW) posted:
Screwdriver bit is just like you would use with a driver drill and could get from a hardware or auto store , I used a short #2 phillips.
Spanner is used to turn the screwdriver bit , which is 1/4" hex and fits in the end of a 1/4" ratchet ring spanner with enough sticking out to still turn a screw in a tight place.
I have seen small kits that have a mini ratchet handle and some bits .
The screw you take out is on the outside of the vehicle , it is under the part that the mirror swivels on screwed up from the bottom . There is one screw that holds the cover on and once you take it out there are 3 more screws that hold the mirror part on ( not adjustment screws , badly worded before sorry ).
When I did mine I took them out one at a time and put some loctite on them and the mirrors havent come loose again.
Hope this helps you out .
 Click Image to Enlarge |
| PATROL |
