AnswerID: 219388 Submitted: Saturday, Feb 03, 2007 at 00:27
V8 Troopie
replied:
I tow a 2.5m wide boat with my troopie and towing mirrors had been a problerm until I came up with this idea.
I made a bracket ( out of an old metal tent pole) and screwed it to the metal tube
snorkel. On the upper end is a mirror with a swivel mount. The mirror is far enough forward to clear the opened driver door frame and gives a good view back.
When not in use the screw holes just have the screws minus the bracket.
This idea possibly wont work with the newer plastic snorkels.
The rubber strap add on towing mirrors are useless on a troopie, they vibrate far too much at any speed other than crawling.
Klaus
Reply 3 of 7
FollowupID: 479940 Submitted:
Saturday, Feb 03, 2007 at 08:11
Member - Doug T (W.A) posted:
The rubber strap mirror I used was perfect , did not even move when buffeted by on coming trucks, I will do a photo and later after breaky and put it on my 4x4 webpage , about 2 hours time
members.westnet.com.au/dtilley/4X4.htm
Doug
 Click Image to Enlarge |
| Doug & Dusty
In the Shade
Gregory National Park |
FollowUp 1 of 2
FollowupID: 479960 Submitted:
Saturday, Feb 03, 2007 at 10:04
Did you put a Patent on it , ,I forgot to tell the other post too that my mirror frams are same used on the Traybacks, put them on myself, the top screws on where the standaeds come off, just had to make a hole for the bottom .
| Doug & Dusty
In the Shade
FollowUp 2 of 2
