4WD light & front Shaft
Submitted: Sunday, Feb 04, 2007 at 11:05
ThreadID: 41954 Views:2254 Replies:4 FollowUps:7
hi just wondering if anyone would be able to throw some light onto this subject, i have a 89 model fj62 series landcruiser with H4 button on the dash, the 4wd light is stuck on which indicates car is still in 4WD when in H2. Front shaft is still spinning which ive been told shouldn't be i am lost as to how to get this vehicle out of 4WD
thank you
william
Reply By: Footloose - Sunday, Feb 04, 2007 at 11:14
Have you tried reversing for a few hundred metres ?
AnswerID: 219620
Follow Up By: fj62 - Sunday, Feb 04, 2007 at 11:48
i tried reversing as said still nothing
FollowupID: 480192
Reply By: fj62 - Sunday, Feb 04, 2007 at 11:29
I have tried reversing about 50m and nothing happened I will go and try a couple of hundred now..
Also can someone tell me the standard procedure for taking it out of 4WD.
AnswerID: 219622
Follow Up By: Member - Pesty (SA) - Sunday, Feb 04, 2007 at 11:39
Hi FJ
The standard procedure is to switch 4wd off, unlock hubs, and then back up a few metres.
Your switch h4 system is electric/vacum operated and you may have a faulty solenoid or something.
They are mounted high up on the firewall, 2 side by side, just near brake booster, well mine are anyway .
The vacum units are mounted on the transmission, so crawl underneath and make sure you havent knocked a hose or wire or something.
Hope this helps.
Cheers Pesty
FollowupID: 480189
Reply By: fj62 - Sunday, Feb 04, 2007 at 11:46
thanks Pesty i go out and have a play
AnswerID: 219624
Follow Up By: Member - Phil G (SA) - Sunday, Feb 04, 2007 at 12:47
Like Pesty said, you have a problem - either the relay that activates the system or maybe the vacuum hoses have been incorrectly connected. There was a post on this forum about 1-2 weeks ago explaining where this relay was located.
FollowupID: 480205
Follow Up By: Member - Phil G (SA) - Sunday, Feb 04, 2007 at 12:50
Found it:
Post No 41680
FollowupID: 480206
Follow Up By: fj62 - Sunday, Feb 04, 2007 at 12:52
thank u phil looking now
FollowupID: 480208
Follow Up By: Wayne (NSW) - Sunday, Feb 04, 2007 at 13:08
Phil,
I would have thought that if there was a vacuum problem, the lack of, the 4wd would disengage. It requires vacuum to hold it in 4wd.
Wayne
FollowupID: 480215
Follow Up By: Member - Phil G (SA) - Sunday, Feb 04, 2007 at 13:35
Yes Wayne you're correct. But if someone connected the vacuum up so it bypassed the solenoid, then it would be on all the time. I haven't seen this done, but I'd assume that its possible.
FollowupID: 480225
Reply By: fj62 - Sunday, Feb 04, 2007 at 13:24
thank U pesty and phil what info u have giving me on this problem has now been resolved bad vacume switch above master cylinder same as other guys problem the brown one
once again thank u very much guys and to all that helped
long live the FJ62 series
AnswerID: 219656
