UHF Radios
Submitted: Monday, Feb 05, 2007 at 20:07
Kath21
Hello everyone,
I am planning a 7 week trip around the top end during april, may, june.
Wondering what everyones recommendations are for a
UHF radio, there will be 3 vehicles travelling in convoy so the main thing is comms between the vehicles, but also for safety it will be our connections to the outside world should something go wrong.
How much range can we expect in areas such as the tanami and the
gibb river rd?
Thanks in advance.....
Reply By: Wayne (NSW) - Monday, Feb 05, 2007 at 20:17
Kath,
A good UHF in the area that you will be travelling will have at least 5km on flat road. The UHF works on line of sight. If there is nothing big between you and the other UHF you should be able to communicate.
The UHf's that are fixed into the vehicle should be 5watt. Hand held units can be 5watt but most are a lot less. They can be found wanting over any distance.
I have always used GME UHF radios, Australian made and work
well, but you must have a good aerial to go with it.
Check out your local 4WD
shop and they should be able to supply and fit.
Wayne
219991
Follow Up By: Wayne (NSW) - Monday, Feb 05, 2007 at 20:49
Kath,
You can also look here.
Site Link
Wayne
480574
Reply By: Sand Man (SA) - Monday, Feb 05, 2007 at 20:24
A 5 watt UHF Unit mounted in the vehicle with a quality outside aerial will give an approximate transmit/receive distance of 20 kilometres, or so, in the open.
If all you are needing is a "between vehicle" communication you may like to consider a hand held unit which is all you need providing one of the other parties has an in-car unit.
An in-car unit will cost you $300-$400 for a 5 watt transceiver.
A suitable (2 watt) handheld with full scanning capability costs about $170 and there is no installation cost or external aerial to worry about.
When looking at the safety issue, providing you can communicate with the other vehicles with the handheld unit, you could invest your money in an epirb device which will give you far greater safety backup than a
UHF radio, even though the epirb would be a device of "last resort".
219994
Follow Up By: Kiwi Kia - Monday, Feb 05, 2007 at 20:34
20 km range ? Only from the top of a mountain or via duplex repeater surely.
I use a magnetic base aerial internal at the back of my wagon and it works great for convoy use. I got the magnetic base to use till I fitted a new bull bar and got around to mounting an aerial but it works so
well I have left it where it is.
Ask around, lots of people have them these days. You could borrow a couple of hand helds and try them out. As already mentioned, there are several different models with different transmission power outputs, the higher the output power the greater the transmission distance and the greater the price. I reckon a 1 watt hand held is all you really need.
480565
Follow Up By: Sand Man (SA) - Monday, Feb 05, 2007 at 20:49
Kiwi,
Yes, 20 kms in OPEN country is not beyond most 5 watt transceiver/ independent ground antenna combinations.
480575
Follow Up By: Member - JohnR (Vic)&Moses - Monday, Feb 05, 2007 at 23:06
Kiwi, have done over 200 km on a repeater and have talked across Bass Straight on simplex on odd occasions from Western Victoria base their end mobile here.
Portland too across
water must be close to 100 simplex base to base and
my home antenna isn't high.
Open country as Sandman says is a possibility. even a probability.
I would prefer a 5 watt with good listening ability to a 1 watt radio too. 5 watts will transmit further. That is unless you only want to tell the driver what to do while walking a little away.
480629
Reply By: Mike Harding - Monday, Feb 05, 2007 at 20:28
In that case; forget UHF CB - full stop.
In good country simplex UHF CB may work out to ~50km (if you're lucky) in the High Country in Vic it is frequently limited to 1km.
If you want a "Get Me Out Of Here" radio then you should consider, sat phone,
HF radio or EPIRB - consider UHF CB to be of use for vehicle to vehicle comms and no more.
Mike Harding
219996
Follow Up By: T-Ribby - Monday, Feb 05, 2007 at 20:45
Hire a satellite phone for the period. For simple comms between convoy vehicles, buy a GME TX650 UHF CB Twinpack 1watt UHF-CB transceivers for $147 from here:
www.prestigecom.net.au/
T.Rib
480571
Reply By: Member - John and Val W (ACT) - Tuesday, Feb 06, 2007 at 08:06
Kath, as others have said, UHF is short range only. Under freak conditions and with very good aerials you might get longer range, but basicly, a 5 watt UHF vehicle mounted one is limited to 5 or 10 km. The aerial is important - a cheap 4.5 dB (about 1/2 metre stiff wire with a coil wound into the centre) will probably not get reliably to 5 km. 6dB is a good all round aerial, 9 dB is better, but only in flat country. The aerial should be mounted as high up as possible, and some types rely on using the vehicle body as a ground plane (sort of a mirror, which acts to double the length of the aerial), so mounting options may be limited.
You actually have 2 requirements - between vehicles, and to the outside world. UHF is great between vehicles, and as others have suggested, handheld UHF is ok and a lot cheaper for limited range (<1km) use. For reaching the outside world, use either
HF radio or a satellite phone; both can be hired. For a last resort, carry an EPIRB, but these are for serious emergencies only.
Have a great trip,
| J and V
- Albert Einstein
220103
Reply By: Member - Phil G (SA) - Tuesday, Feb 06, 2007 at 08:31
When it comes to range, the higher the better with an aerial. Roof mounted aerials always win in my experience. I've managed 70km line of sight (from the top of Mt Arden to the plain below, but up to 20kms is the usual on most roads.
Depending on the country you are in, UHF can be very useful for emergency comms, provided you are familiar with the repeater networks - have a map of their locations and the channels being used. It often puts you in touch with the nearest station, which is pretty darn good in an emergency. If there are no repeaters in the area, then its not much good.
220106
Follow Up By: Member - Phil G (SA) - Tuesday, Feb 06, 2007 at 08:40
Whoops, should have given you this link because it is exploroz!
Exploroz repeater list
480663
Reply By: MEMBER - Darian (SA) - Tuesday, Feb 06, 2007 at 08:53
Amen to much of the above from the regulars ('morning' team :-0)..... Re your UHF issues ....... I too reckon UHF is the pick for group travel comms or for something just a little further - I use the Icom 400 Pro - teamed with an elevated feed antenna on the roof, my retailer suggested this is as good as UHF gets in efficiency (it miht be true ! Other makes do this to of course, when setup properly). The Icom has a "repeater scan" function too - quick and easy to find repeater in range if you need one. Re safety - nobody should rely on UHF in remote areas IMO - why not HF or Satphone (hire or buy) - hiring costs shared across a group are very reasonable and it takes away most of the worry of remote area travel.
220114
