internet while travelling
Submitted: Tuesday, Feb 06, 2007 at 17:59
ferris
I know this is a little off tropic, ok topic, but a mate is heading off to the great blue yonder for his sea change. I am wondering what are the best internet options available for the traveller, apart from internet cafe's.
Keep the shiny side up
Ferris
Reply By: Wayne (NSW) - Tuesday, Feb 06, 2007 at 18:09
Ferris,
Check with Telstra, they have a card that plugs into the lap top and picks up a CDMA signal."$X" amount for the card and then works on a pre paid plan like a mobile phone.
Used one at
White Cliffs last year.
Wayne
220204
Follow Up By: Diver1 - Wednesday, Feb 07, 2007 at 13:21
was gonna get one of these for our trip but it was going to be very expensive....basically it was cheap until you got an email with a pic on it then you were done for....
how's that cracked chassis(???) going wayne???? (i remember something being cracked....)
Laura
480951
Follow Up By: Wayne (NSW) - Wednesday, Feb 07, 2007 at 17:45
Laura,
I am not sure what a crack chassis has to do with this post but to answer you question.
It was the rear diff housing that I had problems with and fix it by replacing the diff housing in
Alice Springs.
I hope this clears things up.
Wayne
481005
Reply By: Sand Man (SA) - Tuesday, Feb 06, 2007 at 18:12
Not many Internet Cafe's available at sea:-)
Wirless modem cards available if he's within CDMA or NextG range, otherwise a link via a Satphone, depending on how great the "blue yonder" is.
220207
Reply By: amcjavelinsst - Tuesday, Feb 06, 2007 at 18:17
Look out with the CDMA card - card "modem" up front is 3 or 4 hundrerd. And the plans are not that great cost wise, but liveable - however, the big put off is that like the analogue network - CDMA will cease at the end of 07. However, at this stage, it is really the only option to go for.
Dont know if 3G phones can be hooked up to the laptop and used as a data call though - I would presume they can be, anyone else assist with that?
Graeme
220211
Follow Up By: Gerhardp1 - Wednesday, Feb 07, 2007 at 11:33
Yes, you can use the 3g phone to access the web from the laptop.
Tricky's had the CDMA card on special during Jan for $99
480928
Follow Up By: marq - Wednesday, Feb 07, 2007 at 22:58
Just rememer the power output of a mobile phone is much lower than an actual modem. (ie poorer signal)
481092
Reply By: howie - Tuesday, Feb 06, 2007 at 18:52
i have a nextg i-mate jasjam which has sms/xms/videocalls/internet/nextg/pocketmsn
and fings i have not worked out yet.
it's free on a $80 plan (or buy it) and you can add data packages to it.
i can bluetooth/usb/infrared to a p.c. and use it as a modem
just a thought
220225
Reply By: marq - Tuesday, Feb 06, 2007 at 19:45
If you can put up with the price - nextg.
Been using the USB nextg device on the super fast 1G plan, works
well whenever there is 1 or more bars on a cdma phone. VOIP works - but there is a delay of 1/2 second.
\It's good for looking up sat/roads on maps.google.com
220229
Reply By: SA_Patrol - Wednesday, Feb 07, 2007 at 17:35
It doesn't cost nothing to use the internet in the country libraries
220423
Reply By: Flash - Wednesday, Feb 07, 2007 at 19:04
I needed the net for work (and play) whilst traveling.
Went with the Bigpond NextG Modem and for $49.95 a month I get 1Gig and coverage almost anywhere. ... not cheap but it works very
well indeed (using it now, out bush).
If you go for the "card" option, you only get 200 megs a month for your $50- and a Gig costs $80.... ie: the Modem is a much better deal.
Also if you don't have others in the family at home who download movies etc (like I have) this would be the only internet access I'd need. For now I need ADSL at home too- that's another $50 pm!! Bugger!
220449
Reply By: Member - Arkay (SA) - Thursday, Feb 08, 2007 at 00:06
Depends on what you are going to use internet for too. Using anybody elses computer, in cafe library etc. for banking would be a heck of a risk. Or accessing anything else important to you that requires a password. Every keystroke you make on those computers can be tracked and saved and used by someone else after you have moved on.
Plugging your own laptop computer into somebody elses phone line is safer, but you need the right type of phone connection and modem in your 'puter. And have arranged it all with your internet supplier, and know their local-call-number to connect cheaply where you are. Some caravan
park operators will allow you to plug into their phone line for a short period.
Next G from your own laptop computer seems the most practical at this point in time. If you have long pockets. 'Course don't get any internet or phone
services in the real outback, no matter what you are using..
220508
