Member to post photos?
Submitted: Tuesday, Feb 06, 2007 at 18:10
pips
Hey guys, Do you have to be a member to be able to post photos on the
forum?
cheers pips :)
Reply By: Mad Dog - Vic - Tuesday, Feb 06, 2007 at 18:20
no, just have the photo hosted somewhere and post the link to it using the syntax at the bottom of the message pane where you type the message
220215
Follow Up By: pips - Tuesday, Feb 06, 2007 at 18:23
Ok thankyou Ray, although this sounds a little bit too complicated for my
computer skills O-o
480770
Follow Up By: Member - JohnR (Vic)&Moses - Tuesday, Feb 06, 2007 at 19:22
Its easy pips you will see at the bottom the leftat the end. The pic will then appear in the middle of the page without you taking a photo. You will see at the bottom of the window 'For Images' for the idea of the syntax. If there is a special page you can just copy the link in and it should find it for you. David really has done a great job with the
Forum linkages.
If you are a member you can get a rig pic and then a number of other pictures that your posts may refer too just by clicking on Add Gallery Picture at th ebottom of our members posting window.
480785
Follow Up By: Member - JohnR (Vic)&Moses - Tuesday, Feb 06, 2007 at 19:24
pips, the system actually skipped over the part I put in because it had the code it expected to see for a link. Just open up a reply window and you will see it below with 'For Images"
480786
Follow Up By: pips - Tuesday, Feb 06, 2007 at 21:53
Thanks John
I still dont get it so i wont
worry about it.
Thanks anyway
cheers pips :)
480816
