Set Top BOX
Submitted: Wednesday, Feb 07, 2007 at 14:17
ThreadID: 42080 Views:6032 Replies:12 FollowUps:6
hI All,
does anyone know about set top boxes ? we've bought an LCD for the van and I 've some issues with the picture quality, the antenna is a happy wanderer and at home the picture is fine but in a poor reception area is terrible, went on a caravan site forum and they said a set top box would help greatly, not wanting to look a complete dork I dont know what they are what they do how much they cost or if I even need one , any body point an old codger in the right diection,
thanks mate,
Reply By: lewjack1 - Wednesday, Feb 07, 2007 at 15:00
dave,
a set top box is a tv receiver/tuner that changes the tv signal from analog . (the type of signal that all tv stations transmit at the moment) to digital which has a far superior picture quality upside picture quality great ,stereo sound ect
downside if reception is poor you may not get any picture at all. maybe only available in 240volts not sure if you can get it at 12v. or if so cost may be a problem . hope this helps
lewjack
AnswerID: 220399
Follow Up By: GaryInOz (Vic) - Wednesday, Feb 07, 2007 at 16:31
Wrong way around!!!
STB converts the digital TV transmissions to a video and audio signals that can be plugged into the back of most TV's available today (using the old picture tubes, and the newer flat panel displays - "A/V inputs")
Digital TV is more immune to noise and generally does not require as much signal as analogue, but unlike analogue TV (old Ch 2, 7, 9, 10, etc) the picture and audio quality comes to a very abrupt end at the lower signal levels ("digital cliff"), rather than "fading" into snow as analogue does.
I am sure there are some 12v STB's around, try a caravan supplier/builder, or some place like "The 12V shop".
FollowupID: 480989
Follow Up By: Polaris - Wednesday, Feb 07, 2007 at 16:35
We use a $59 one from Coles - MTV brand. It comes with a 240V/12V plugpack but will run straight from 12V in our motorhome.
On special this week also at K-Mart for $49.
FollowupID: 480990
Reply By: timal - Wednesday, Feb 07, 2007 at 15:01
Hi Dave,
Setting aside power supply in your van (which i presume is all ok for your TV), Set top boxes are pretty straightforward, but the Shop assistants tend to try and baffle you with their "knowledge". You have two types: SD, or standard definition and HD, or High Definition. Your TV manual will tell you if your TV is ok for SD or HD. the benefits of either are improved quality of picture and some extra channels (ABC2, SBS2). I live in a rural area and the TV reception was pretty average, but we bough an SD box for about $70 and it works a treat on our Plasma. The shop we bough it from tuned it in ,in-store, so literally all we had to do was plug it in, much in the same way as a VCR/DVD.
You can get them pretty cheap. around $50 upwards. Best bet is to find a store that doesn't try to bulls**t you and sell you something you don't need.
Hope this helps.
Tim
AnswerID: 220400
Reply By: robak (QLD) - Wednesday, Feb 07, 2007 at 15:07
Set top boxes (STB) recieve the digital signal sent out by tv stations. As opposed to the analog signal you currently recieve. The STB sits between your anetanna and the screen (TV). With a digital signal you will either have a great picture or none at all. STB start in price at around $100 and go up from there depeneding on their quality. Some have a hard drive which means you can record programs and veiw them later, or you can pause a programe while you go and make yourself a cuppa. Some also have two receivers which allows you to watch one channel and record another.
Where we live we've always had reception problems.
Firstly we bought a STB for about $120 which was supposed to have excellent reciever. It worked very well. We later changed to one with a hard drive but with a poorer quality reciever and therefore had to buy a special amplified antenna.
Hope that helps.
AnswerID: 220401
Follow Up By: robak (QLD) - Wednesday, Feb 07, 2007 at 15:10
Also, our STB has a transorfmer from the powerpoint so it may well be running on 12V.
Also don't bother with High Definition STB. The station don't sent out a HD signal yet so it'd be waste of money until they do.
FollowupID: 480979
Follow Up By: GaryInOz (Vic) - Wednesday, Feb 07, 2007 at 17:48
Some do in prime time, you will need a flat panel TV to display it with a minimum vertical resolution of 768 pixels (normally 1368 horiz x 768 vert, or greater)
FollowupID: 481007
Reply By: howie - Wednesday, Feb 07, 2007 at 15:07
the antenna you mention looks like an ordinary one with booster and amplifiers but is not a dish type.
i thought that if you were in a "poor reception" area you would get just that with a antenna.
this is the quote from their website, ring them.Phone 08 8376 2411
"By choosing the DX Active Zone antenna you will increase your chances of good television reception in all areas of Australia. Coupled with our excellent after-sales-service, we will fix any problem you have !!!"
all areas of australia????
aaahhh the wording is subtle. 'increase your chances'
the new lcd tv's like a fairly good signal to work, not like the old tube tv's.
the set top box will enable you to access digital stations, its just like a seperate tuner, put inbetween the tv and antenna.don't think they are more than $200.
in very remote areas i would be going van satellite.
good luck
AnswerID: 220402
Reply By: Member - Uncle (NSW) - Wednesday, Feb 07, 2007 at 15:26
Hi there Dave, we just went thru the same dramas last week in a poor reception area with our new LCD as well.
We are also running a happy wanderer, we purchased the 12 volt and 240 volt amplifier kit that is built for that antenna and problems solved. I think it was around 150 dollars all up. Cheers unc.
AnswerID: 220406
Reply By: Philip A - Wednesday, Feb 07, 2007 at 16:01
Just few points
Most or all TV stations broadcast in digital. Many have HD as well as SD.
Many if not most repeaters broadcast in digital. I live in the Central Coast NSW and all channles have SD digital and HD digital through the Bouddi and Forresters beach repeaters.
Interferencs is different on digital than on analogue. you will get loud bangs through the speakers and frozen picture.
But you do not get any ghosting, snow,etc etc.
My aerial tech told me that the repeaters are weakening the analogue signal progressively, and that analogue interferes with their digital signal.
He dropped in the other day and suggested I periodically retune my DSB, as the frequencies are moving. This I did and it improved my reception.
I have also bought a HD Digital USB tuner for my laptop. It comes with a little aerial which I found to be useless. Once attached to my home aerial I have perfect picture.
You would have to be right ion top of the transmitter for one to work.
Hope this helps.
Regards Philip A
AnswerID: 220409
Follow Up By: Craigww2 - Wednesday, Feb 07, 2007 at 19:12
At no stage are the networks turning down the power on the analogue. The only turn down will be when it is turned off. I work for the TV stations as a tech and due to the poor pick up of DTV analogue life is slowly extending. I use to be 2008 in the capital cities now I think it will be lucky to be 2015.
Digital needs to be 10dB down on level compared to analogue due to adjacent channel interferance.
Be careful there are a lot of antenna installers who try to feed the customer BS.
FollowupID: 481030
Reply By: ZukScooterX90 (QLD)Member - Wednesday, Feb 07, 2007 at 16:22
Dave we were getting problems with our tv antenna as well so i bought a Camec digital set top box $120 i think it is 12v or 240 it worked in a lot of places & the picture was brilliant,& most of the time no need to put up the antenna as long as we used the 12v booster.We were at a national park about 35ks from Devonport east had no signal with the set top box but put the antenna up & got picture without it ( the box) was snowy though.
Bob.
AnswerID: 220414
Reply By: Steve63 - Wednesday, Feb 07, 2007 at 16:22
High Dave, A set top will not improve the signal. The set top box may be able to auto correct information and give you a better picture though. It depends what is available. Sometimes a digital signal will be better and other times analogue will do a better job. Most metro stations transmit anolog, digital SD and HD. If the signal quility is very poor the auto correction mechanism will tend to make the picture pixilate or freeze up. Some boxes are easier to set than others. One I have set up all you do is turn it on and two buttons on the remote had it scans and auto set up all the channels. HD is available in cities and some contry areas. If the station holds a HD licence it must transmit 1040 hours of HD per year. If you are moving around you may need an antenna booster as well. Then it will be a bit of suc and see at each location.
Steve
AnswerID: 220415
Reply By: Motherhen - Wednesday, Feb 07, 2007 at 17:58
Dave, we followed the advice on the following link and got the DSE one for around $130 rather than the cheapest available. This is 240 v so has to run from the inverter. We will be able to use it in the house when TV signal changes to digital (wasn't that going to be in 2008?) Everything else is straight 12 v. We haven't really tested it yet, because we are not in a digital area. They don't improve picture in a poor reception area. They either give good reception or nothing at all.
We have found the happy wanderer antennae not brilliant compared to the house reception. The booster that we then got direct from happy wanderer was useless and my husband has ditched it.
Site Link
AnswerID: 220430
Reply By: time waster - Wednesday, Feb 07, 2007 at 22:07
We have had the same trouble not that we watch alot of tv but when we do i like a good picture bought the mini antenna with 12v booster works well if you have a half decent signal but when in the fringe areas you still get snow with the pic and with the lcd its seems to make it worse. We ended up buying sat tv complete kit for $430 AND IT IS THE BEST! takes slightly longer to set up but there is no going outside each time when you change channel to move the antenna you get 16 channels of digital reception.And when you look at it we paid $200 for the boosted antenna and pole so i should of got the sat first. And we use it at home too.
AnswerID: 220492
Follow Up By: Member - Mick M (QLD) - Monday, Feb 12, 2007 at 20:59
hi time waster,could you tell me were you purchased the sat set from,im also having reception prods, the sat sounds like the cure all, regards mick
FollowupID: 482044
Reply By: Dave Thomson - Thursday, Feb 08, 2007 at 14:38
Hi All,
thanks to everyone who replied we now have a much better idea and now know what we're up against, your help has been brilliant ,
once again,
Thank you,
AnswerID: 220574
Reply By: time waster - Tuesday, Feb 20, 2007 at 15:55
We bought the sat tv from satplus
AnswerID: 222928
