New button
Submitted: Wednesday, Feb 07, 2007 at 23:58
Wayne (NSW)
I see there is a new search button. Top right.
Wayne
Reply By: Member - JohnR (Vic)&Moses - Thursday, Feb 08, 2007 at 09:10
may help to make searches more apparent when I get round to using it.
220532
Follow Up By: Member - JohnR (Vic)&Moses - Thursday, Feb 08, 2007 at 09:13
ok,
well it does a different function as the search on the
Forum header searches the
Forum and archive. Think it may add to some confusion as to where you search.
481135
Reply By: Member - Andrew (QLD) - Thursday, Feb 08, 2007 at 10:15
I for one couldn't the "site search" buttom on the
forum mainpage as the menu is still too wide for my screen settings.
220546
Follow Up By: ExplorOz Team - David - Thursday, Feb 08, 2007 at 12:55
Andrew,
Do a Refresh - this has all been resolved.
481172
Follow Up By: Member - Andrew (QLD) - Thursday, Feb 08, 2007 at 14:21
As WaynePD stated, this is what we are seeing (after refreshing, closing browser, waiting etc), myself on 1680x1050, 120dpi:
481189
Follow Up By: ExplorOz Team - David - Thursday, Feb 08, 2007 at 16:32
Oh 120dpi - I get it. Hard to fix that one - let me see what I can do with this one.
481216
Follow Up By: ExplorOz Team - David - Thursday, Feb 08, 2007 at 16:37
Andrew - What browser please?
481219
Follow Up By: Member - Andrew (QLD) - Thursday, Feb 08, 2007 at 17:01
IE 7.0.5730.11
481221
Follow Up By: Member - Andrew (QLD) - Thursday, Feb 08, 2007 at 17:04
Though i must state that FireFox 1.5 is doing the same thing....
481222
Follow Up By: Member - Andrew (QLD) - Thursday, Feb 08, 2007 at 17:19
96dpi setting will fix the problem on EO, however it kills everything else i enjoy :-) I realise that i can increase the fonts on the
forum area, however the rest of the site is very small due to my screen settings. :-( Can you suggest anything else to get around the problem as i prefer to run some specialised mapping programs at my original settings?
David, the "Denco Diesel" advertisement seems to be the only ad that will overlay on top of the menus, whereas the others hide behind as they should.
481226
Follow Up By: ExplorOz Team - David - Thursday, Feb 08, 2007 at 20:01
Leave it with me - I will see why this setting only appears to effect the menu code. and not the rest of the display. I am sure I can solve it I just need to determine exactly who, what and where the problem is. I will setup a test machine tomorrow the 120dpi and have a play. If I can solve it you will hopefully see it fixed automatically.
481252
Reply By: Waynepd (NSW) - Thursday, Feb 08, 2007 at 13:34
It gets stuck behind the sponsor ad, i assume the button i can see says help
220563
Follow Up By: Waynepd (NSW) - Thursday, Feb 08, 2007 at 13:37
ah geez now i have said that, it is working ok....bloody comoputers
481175
Follow Up By: Waynepd (NSW) - Thursday, Feb 08, 2007 at 13:39
I retract that retraction lOL
the ad with the purple background that talks about 100 series and other stuff seems to sit on top of the dropdown box from the search.....
481177
Follow Up By: ExplorOz Team - David - Thursday, Feb 08, 2007 at 16:35
Wayne,
Are you using a setting other than 96dpi for the system See Control Panel - Display - Settings - Advanced - General tab - DPI setting.
481218
Follow Up By: Wayne (NSW) - Thursday, Feb 08, 2007 at 17:37
David,
Normal Size 96 DPI.
What ever that means.
I am glad you toldme how to find the info.
I did not know that I had a normal size 96DPI
Wayne
481228
Follow Up By: ExplorOz Team - David - Thursday, Feb 08, 2007 at 20:02
Wayne are you only seeing the error when you open the search box or is the menu always going over the sides of the screen.
481255
Follow Up By: Wayne (NSW) - Thursday, Feb 08, 2007 at 20:16
David,
Sorry, wrong Wayne, I don't have a problem with the site.
Wayne NSW
481259
Follow Up By: Waynepd (NSW) - Thursday, Feb 08, 2007 at 23:32
Sorry David I had to go to work.
The only one that affects the search box is when the Denco Sponsor Ad is in the top position or the second position. The other sponsor ads are fine.
My setting is 96dpi
481340
Follow Up By: Waynepd (NSW) - Thursday, Feb 08, 2007 at 23:36
I see that the Denco Ad is a Flash presentation whereas the other 2 are pictures......
481342
Follow Up By: ExplorOz Team - David - Friday, Feb 09, 2007 at 15:48
Waynepd - Ad problem with the Denco and other flash ads should now be solved. I assume you are using Firefox as your browser as this is the only one that exhibited the issue (I think).
481471
Follow Up By: Member - Andrew (QLD) - Friday, Feb 09, 2007 at 15:57
No, both Firefox and IE have the same behaviour (
well on my system :-))
Novel idea to fix the problem with the ad ;-)
481474
Follow Up By: Member - Andrew (QLD) - Friday, Feb 09, 2007 at 16:01
ment to add that Novel idea to fix the problem would be to not allow the flash ad to appear in the first two positions on the column ;-)
Though i don't think that this may be acceptable to sponsors somehow....
481476
Follow Up By: Waynepd (NSW) - Friday, Feb 09, 2007 at 23:31
Hi David,
Yeh all is ok now that the flash is gone, It was the same problem with both Firefox 2 and Explorer 7.
481596
