2h leaking coolant
Submitted: Thursday, Feb 08, 2007 at 15:30
Goldsahara
Hi there all,
I have a mate who has a auto hj60 that is leaking coolant from,
well it seems to be from the oil cooler on the block behind the injection pump. I was wondering if anyone has had a similar problem and what needed to be done to rectify this problem.
Thanks,
Jim.
Reply By: Member - Davoe (Nullagine) - Thursday, Feb 08, 2007 at 15:38
there is a plate where the oil filter bolts to allowing coolant to flow out of the block and around an oil cooler within the plate - the plate is probably coroded and needs replacend (around $400) dont stuff around with second hand ones
220583
Follow Up By: Goldsahara - Thursday, Feb 08, 2007 at 21:58
OK cheers Davoe, Ill follow up on that info.
Jim.
481285
