GUIV 4.2TD 20% power gain/2.5"exhaust?
Submitted: Thursday, Feb 08, 2007 at 19:40
ThreadID: 42125 Views:3400 Replies:11 FollowUps:10
I just spoke to Turbo glide in Wollongong, he suggests 2.5" pipe from under the passenger side back, not to touch the dump pipe, he will adjust the fuel to suit and by doing this he guarantees a 20% gain.
Due to the 2.5" exhaust he reckons the turbo will go up an extra lbs in boost.
He will dyno my truck before and after to show the power gains.
He recommends not doing anything that could make the truck run hotter.
I asked him about 3" exhaust, his advice was why spend the extra money on 3" dump and exhaust when he can get the same power gains with the 2.5" and fuel timing adjusted. It sounds like his expertise is in the fuel adjustment.
He quoted me $1,090 inc GST. Well he is a lot cheaper than West End and can guarantee the 20% power gain.
I am a little confused right now, because you blokes swear by the 3" exhaust and dump pipe set up.
Can anyone confirm the advise Turbo Glyde has given or even contradict him?
A little help here would be greatly appreciated.
Regards,
Babs.
Reply By: Member - Cruiser (NSW) - Thursday, Feb 08, 2007 at 19:53
Cant comment specifically on the advise you have been given, but, I can tell you that I had Turbo Glide fit a Turbo kit to my previous vehicle (80 series) and they guaranteed me a minimum of 30% improvement across the board and when the compared the dyno figures after fitting and fiddling to the figures before they started, I actually gained 48% in Kw and 50% in torque.
Gotta be happy with that.
I found them to be very knowledgeable and very friendly and their workshop is spotless.
Hope that that all hepls in some way.
AnswerID: 220623
Follow Up By: Member - Boo Boo (NSW) - Thursday, Feb 08, 2007 at 20:07
I used them about 2 yrs ago and am very happy with the troopys performance, I asked for and got a 30% increase, would recommend
Boo Boo
FollowupID: 481256
Reply By: Trevor R (QLD) - Thursday, Feb 08, 2007 at 20:26
I don't doubt for a second that they could get 20% more power with their setup but why settle for that, if you are going to increase power then get as much as you safely can. The 3" system with dump pipe will allow you to do more and get more power if you want it.
If you work yours hard does the temp gauge move now? my belief is they all have this tendancy and it is nothing to stress over so long as you are vigilant not to let it get too carried away.
Talk to as many turbo shops as you can so as to get a balanced view from "the experts". In the end it is your decision but I would not swap my setup for all the tea in China. (I was going to say..."I would not swap my 3" setup...." but then I thought this left me open for attack LOL!!!!) Any gain around 20% or more will put a smile on your face but more is better IMO.
Good luck, regards Trevor.
AnswerID: 220632
Follow Up By: babs - Thursday, Feb 08, 2007 at 20:50
Very sound advice Trevor, Thanks mate.
FollowupID: 481270
Follow Up By: Trevor R (QLD) - Friday, Feb 09, 2007 at 00:08
Babs,
Get the expected dyno results from W/gong mob and then get your hands on some dyno charts from other tune up mobs and compare for yourself. Mike Vine Turbo's (in Capalaba, Brisbane) has these charts and I feel sure he would email them if you asked for them, I also would, except I am away from home for a couple more weeks yet so if time is not important send me an email addy through member message and when I get home I will get some charts to you. You want more torque earlier on for easier towing.
Regards Trevor.
FollowupID: 481348
Reply By: Member - John - Thursday, Feb 08, 2007 at 20:38
Good luck.
The dump pipe on this system is a hell of a restriction, prevents the turbo from spooling up quickly and you will not get power from lower in the rev range.
"He recommends not doing anything that could make the truck run hotter." This set up will make your engine run hotter.
I have run tests with my truck and a mates. I have had the bigger exhaust, dump pipe and turbo fitted, he has had a bigger exhaust, dump pipe and fuel adjustments done, the EGT on mine is 225-250 degrees F lower than his after test runs over the same stretch of road etc. I am fractionally slower over the same stretch. Not very scientific, but real world and valid data.
I have gone from 72 kw to 120 kw at the rear wheels.
Can Turbo Glyde provide EGT data for this set up verus a standard set up?
It certainly sounds cheap enough, but, in my mind, 3" and bigger dump pipe is the way to go.
John and Jan
AnswerID: 220635
Follow Up By: babs - Thursday, Feb 08, 2007 at 20:57
John let me clarify, his with the dump pipe and fuel adjusted is running hotter than yours, is this a problem?
I'm worried about this heat issue as I tow a trailer with around 7-800Kg in weight and this is daily, so you can see my concern and boy I should could use extra power right now especially having the turbo cut in sooner.
Thank You.
FollowupID: 481272
Reply By: Member - Stephen M (NSW) - Thursday, Feb 08, 2007 at 21:19
Hi there Babs,have not had turbo fitted myself but have spoke to John at turbo glide and seems to know his stuff. Did you ask him how long he has been in the game for ?? some thing like 30 years so I would think he would know the answers to all your questions. My wife has had 3 customers of hers who have used turbo glide and swear by them. Service, knowledge,and care taken was the main comments which is the best advertising you can get. There is another mob (not westend diesel) that are very common mob but after speaking to them would not use them or recomend them. Shame your not a member other wise I would send to you who these people are with out advertising on here. At the end of the day you want something that is going to go well and still be reliable with out causing any damage to the engine. Steve M
AnswerID: 220649
Reply By: Member - John - Thursday, Feb 08, 2007 at 21:24
Babs, yes, his runs a lot hotter than mine and yes it is a hell of a problem. MTQ is the turbo I have. Lots of different ways to go with pipes etc etc. As I said, good luck........ :-)
John and Jan
AnswerID: 220651
Reply By: Truckster (Vic) - Thursday, Feb 08, 2007 at 23:30
have a look at the differences. there is massive restriction.
The larger outlet also changes how fast your turbo spools up, if you would like more power earlier, then the 3inch would be better. if you dont care, then go for it. price sounds ok. but you would hate to go the 2.5 only to want to change in a few mths.
so for $1090 you get an exhaust, and a pump tune? very expensive exhaust for not a complete system front to rear with mufflers, and a dump...
You will get a 3inch system for same price elsewhere (even beaudesert will cost that INC a dump in 3inch), and go the pump tune for fraction of the cost, which should be all it costs.. surely 1/2 an exhaust system isnt worth more than $600?
AnswerID: 220697
Follow Up By: Truckster (Vic) - Thursday, Feb 08, 2007 at 23:31
PS, left is the BDesert one, MTQ in middle (so Im told) and stock right..
FollowupID: 481338
Follow Up By: babs - Friday, Feb 09, 2007 at 00:11
Thanks Truckster, I would probably prefer the 3" set up, in your opinion would overheating be a problem with the turbo intercooled engine, refer to the weight I'm towing.
Regards,
Babs.
FollowupID: 481349
Follow Up By: Truckster (Vic) - Friday, Feb 09, 2007 at 15:30
Overheating can always be a problem when you pump more fuel into a diesel.
You wont know until you try really.
FollowupID: 481465
Reply By: Member - John T (NSW) - Friday, Feb 09, 2007 at 08:55
Hi Babs,
I had a couple of local places here in Tamworth NSW do the 3" exhaust, dump and tune late last year. I have a 2005 4.2TD that was putting 95 hp at the back wheels. It now puts 115 hp at the back wheels. The exhaust is made locally ( all mangrel bent) by The Muffler Man and the dump is supplied by DieselCare. I paid about $1200 for the work and I am very happy with the results. I have not observed any increase in temp gauge even with some days here in recent weeks being 40+ degrees.
Hope this helps
John T (Lifetime Member)
VKS-737 Mobile 2619
Selcall 2619
AnswerID: 220729
Follow Up By: babs - Friday, Feb 09, 2007 at 15:24
It helps heaps, thanks John.
FollowupID: 481464
Reply By: Member - DOZER- Friday, Feb 09, 2007 at 09:32
Babs
Beware....its a known problem that the td6 has a small turbo that restricts the exhaust getting out when on song......the turbo works on a pressure drop across it, make the exhaust larger, and the drop increases, therefore the turbo will boost earlier and faster. The dump pipe is the first thing after the turbo, where the gasses are flowing fastest, it needs to be biggest...as gas goes down exhaust, it cools and reduces its velocity, so u can reduce size further back.
More fuel equates to more heat. simple physics....dont increase it unless you put a bigger turbo on.
Whatever pressure you have in the inlet manifold, is also in the exhaust manifold driving the compresser....dont boost up too much, unless you also pay attention to all the restrictions....so in sumary, get a quote from someone to have a dump pipe made with 3 inch back to the rear diff muffler or further, t/d's are not noisy anyway.....clean up the piping to the intercooler and put a larger turbo on the motor (safari) and you will have heaps of power without heat.
AnswerID: 220747
Follow Up By: babs - Friday, Feb 09, 2007 at 15:34
Hi Dozer, useful info, I think I will opt for the 3" dump & exhaust set up especially if I do decide ever in the future to put a larger turbo the exhaust mods will be in place.
Now all I have to do is find someone reputable to do the job?
I was hoping I would not have to travel to far, I mean out of Sydney that is.
Babs.
FollowupID: 481468
Reply By: Member - Jeff M (WA) - Friday, Feb 09, 2007 at 18:35
I whacked on a 2.5" on the surf (it has a 2.5" dump from factory) with a lukey performance muffler. Twas ok, but recently I removed the muffler all together and just poked the pipe out the side behind the rear wheel - Now that made a difference, bloody huge difference. I'd recommend that to anyone and it only cost $80 bucks to get done at the local workshop!! Bloody fantastic now, it doesn't drop out of torque lock all the time while crusing through hills it just sits at 2000rpms and rumbles along nicley.
AnswerID: 220864
Reply By: Lock* - Friday, Feb 09, 2007 at 21:27
Hi Babs,
I just put a turbo, intercooler and 2.5" exhaust on my standard 100 series 4.2D Landcruiser and it runs a treat. Off the dyno the power went from 52.1kW to 108kW and the Torque from 440.2Nm to 925.4Nm. All this increase can be directly attributed to the combination of the turbo, intercooler and the 2.5" exhaust. The figures you were quoted for a 20% increase in power for the exhaust is about right, albeit a little on the high side. I also agree with the 2.5" exhaust as opposed to the 3". The figures that I researched could not adequately prove a noticeable power gain with the extra 1/2 an inch, however if you racing your machine then go for the bigger exhaust to get every advantage you can. The 2.5" mandrel bend exhaust also fitted better as the 3" pipe, in some cases, came very close to contacting other parts of the vehicle. I paid around $950 inc GST for the exhaust - fitted and tested (on the Dyno). I'm in the ACT and shopped around for the best price and advice in Sydney and S.E QLD and the local guys did the best job.
That's my experience - hope it helps.
Good luck
Lock*
AnswerID: 220901
Reply By: Member - Roachie (SA) - Friday, Feb 09, 2007 at 21:35
It won't matter what size pipe you put on the truck......it won't "give" you anymore power. The only way this all works is by the re-tuning and boosting the fuel delivery. It has to be done as a package.
The mechanic said he could g'tee you 20% increase just by upping the fuel and putting a 2.5" pipe from half way back, is probably telling the truth.
If you just bolted on a 3" dump pipe and exhaust system (without doing anything else), you won't experience any change in performance.
The idea is that you free up the exhaust system to be able to cope with the extra neddies being created by boosting the fuel and maybe the boost pressure etc.
Then, the limiting factor is gunna be the size of the turbo. For less than the amount of $$$ being mentioned above (ie $4 grand), I would highly commend the Denco turbo upgrade, which involves a new, bigger Schwitzer turbo, matching dump pipe and exhaust etc all for about $2700-.
I am not in favour of the MTQ upgrade as that one involves boring-out the guts of the original turbo; has to make it weaker as far as I'm concerned.
These are just my own personal experiences.
Roachie
AnswerID: 220904
Follow Up By: JamieMac - Wednesday, Feb 21, 2007 at 17:24
Roachie,
I have to disagree with your comment on the effects of exhaust and dump pipe only. I did this and the difference was immediate and noticeable.
I can not vouch for difference between 2.5" and 3" exhausts be they mandrel bent or not. However, I can vouch for experience with my TD6 after fitting MTQ 3" mandrel bent exhaust and dump pipe. I have a mate with same vehicle and his experience was the same.
JamieMac
FollowupID: 484043
