Stripped Free Wheeeling Hub Mechanism
Submitted: Thursday, Feb 08, 2007 at 22:36
Brian B (Mackay Qld)
What causes a free wheeling hub mechanism (switch on front wheel) to become stripped?
Thats what is wrong with the drivers side wheel on my 1994 75 series cruiser ute.
Dont worry, i am getting it fixed, i already have the second hand part to give to the mechanic which i got for $65.
I was always curious lately that when i climb
sand dunes my back
wheels are all that spin, while my mates 4WDs get over no probs!
Just wondering how it would have become stripped? I am the 3rd owner,
161,000kms on the clock.
Reply By: Sand Man (SA) - Thursday, Feb 08, 2007 at 22:55
"Switch mechanism on the front wheel?"
Jeez, my vehicle has the old mechanical engage/disengage mechanism which makes it very simple and reliable.
Never had a problem stopping and engaging the front hubs, before I need to use 4WD.
Once though, I did suffer from "brain fade" and couldn't get into 4WD low range. (I was sober too). Had to stop, count to ten, then think....that's right....shift the auto selector to neutral first you dork....Duh!!
220687
Follow Up By: Member - extfilm (NSW) - Friday, Feb 09, 2007 at 00:51
that was your prob...... u had an auto :(........ glad u at least had a break from driving
481353
Follow Up By: Geoff (Newcastle, NSW) - Friday, Feb 09, 2007 at 07:52
Manual free wheeling hub is exactly what the man is talking about.
Standard on a 75 series.
The actuation mechanism looks a lttle like a selector switch with two positions, Free and Lock.
Geoff
| Geoff,
481369
Reply By: geocacher (djcache) - Friday, Feb 09, 2007 at 00:11
Depends what you are calling stripped.
I assume you are talking about the manual locking mechanism that I think you are.
Has it stripped the teeth off the engaging ring? That would be a serious failure. I've not heard of these fail in standard vehicles other than to start sticking. Unless of course you've done a v8 conversion or serious power upgrades.
More likely it's got
water in it and the workings are now sticking. You can turn the locking mechanism back and
forth but it fails to engage.
Usually a strip, clean and relube is all it takes, though surface rust on the spring that disengages it is not good.
Putting it back together is the key to success as it's a bit of an odd concept, but a google search on rebuilding AISIN locking hubs will point you in the right direction.
I'd suggest this is the issue and you'll end up with a recoverable spare.
They are easy to swap out on the side of the track if you get a failure but I don't know that I'd carry one as a spare, though I know others that do.
220703
Follow Up By: fisho64 - Friday, Feb 09, 2007 at 00:54
from memory the hardest part is getting the cone washers out?
481355
Follow Up By: Member - extfilm (NSW) - Friday, Feb 09, 2007 at 00:58
Almost 10 years ago, cruising through the
oodnadatta track my mates ute had a prob with the hubs.......... one was stripped due to another mate thinking he would play a joke and not unlock one of the hubs :( To strip the hub IMO is rather difficult as you can still lock it in by pulling the hub off, locking it into the right postion and putting the cover back on......... was slow but that is always the adventure huh
481356
Follow Up By: Gramps (NSW) - Friday, Feb 09, 2007 at 08:13
"due to another mate thinking he would play a joke and not unlock one of the hubs"
Save us all from 'mates' like that idiot.
481374
Follow Up By: luch - Sunday, Feb 11, 2007 at 15:06
fisho64
its eaisy to take out the cone washers........Ball peen hammer !
The hard part is finding them when they come flying out and you dont see where they go
481795
Follow Up By: fisho64 - Monday, Feb 12, 2007 at 02:35
where do you whack it?
481886
Reply By: Time - Friday, Feb 09, 2007 at 10:34
Reply By: Middle Jeff - Sunday, Feb 11, 2007 at 18:50
Hi Brian
Most likely got
water or CV grease onto it, they can also stick if you put to much grease on them, they only need a little. I just pulled
mine off to do some other things and found my drivers side had stuck in a little and damaged the cone inside. A new mechanism from Toyota was $70.
Have fun
Craig
221116
