Best unleaded fuel for Coleman Dual fuel stove
Submitted: Friday, Feb 09, 2007 at 17:38
ThreadID: 42158 Views:10597 Replies:10 FollowUps:2
Hi all,
Ive just bought my Coleman Dual Fuel stove.
Which is the best Unleaded Fuel to use (cleanest etc.)
Are the higher octane fuels better.
Is any particular brand (eg BP, Gull, Shell) cleaner?
Gav
Reply By: Member - Fizz (NSW) - Friday, Feb 09, 2007 at 18:29
If it will use Shellite (sometimes called "white petrol" or dry-cleaning fluid), that will be the cleanest and probably the safest. I bought a little stove that uses Shellite in 1961 and I still use it for trips and sometimes at home. But Shellite is a bit over twice the price of ordinary unleaded, or more than 4 times as dear if you get it from Bunnings!
AnswerID: 220862
Reply By: Member - Phil G (SA) - Friday, Feb 09, 2007 at 19:53
Coleman fuel ($15 for 4 litres), and Shellite are the best.
ULP is OK. Don't know that theres any difference between ULPs with stoves. If so, it wouldn't be much.
AnswerID: 220871
Reply By: Lyds- Friday, Feb 09, 2007 at 19:56
for everything you ever wanted to know about fuel stoves... www.bushwalking.org.au/FAQ/FAQ_Stoves.htm
I can't answer your question exactly, but I believe its a good idea to use shellite/coleman fuel every now and then
AnswerID: 220872
Reply By: Stu050 - Friday, Feb 09, 2007 at 20:08
G'day,
I always use either Coleman fuel, or shellite.
AnswerID: 220876
Reply By: nowimnumberone - Friday, Feb 09, 2007 at 20:34
weve had a coleman duel fuel for years
the best fuel we have found is the cheapest i dont think it makes a difference
unless you use ethanol blend then its better for the enviroment lol
AnswerID: 220887
Reply By: keepingitreal - Friday, Feb 09, 2007 at 21:12
Used to use Coleman Fuel (too pricey!!), no I use BP Ultimate (Higher octane), Works just as good. No Dramas!! Hope that helps. Regards Kirsten (NSW)
AnswerID: 220897
Follow Up By: slush - Friday, Feb 09, 2007 at 23:08
I use shellite, and if you buy it in bulk from diggers direct it is less than ulp.
FollowupID: 481591
Reply By: Keith J (QLD) bushcamper - Saturday, Feb 10, 2007 at 01:55
I only use Shellite in both of my Coleman stoves but it's good to know the option to use ULP is there.
I paid $42 for a 20lt drum of Shellite from the local Shell depot last November, seems to go up and down with the price of petrol.
AnswerID: 220916
Reply By: Brew69(SA) - Saturday, Feb 10, 2007 at 08:39
Don't waste your money on shellite or coleman fuel. Any ulp will do the job. Just carry a spare pump.
AnswerID: 220923
Follow Up By: pixiemops - Sunday, Feb 11, 2007 at 16:31
I agree just use unleaded petrol . Never had a problem yet and if I do just wack in a new generator. Far cheaper than the expense of the shellite over time.
FollowupID: 481803
Reply By: gazza60 - Saturday, Feb 10, 2007 at 18:48
Gday
have used the coleman duel fuel cookers and lights for 20 years and i think the coleman fuel or shellite are best.
Yes unleaded petrol is cheaper but i have found that the generator can cause more problems with unleadeed, but it is a good standby.
Lets face it , even on a extended trip the amount of shellite cost you would use in relation to the overall cost in negligable.
all the best
AnswerID: 220976
Reply By: MichaelR - Saturday, Feb 10, 2007 at 23:58
I would only use unleaded and not Shellite. It is vastly more expensive for no added benefit. It is a good idea to carry a spare (about $14) no matter what fuel you use. I have used our duel fuel stove on extended camping trips over the last 8 years, used unleaded and used 1 generator in that time. Even if the generator does require replacing more often using unleaded it is still cost-effective to use unleaded. It is also possible to give the generator a bit of a scrub-up if it gets blocked.
AnswerID: 221034
